Old 01-23-2006, 09:18 PM   #1
AWDtoyota
AWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really nice
KA to SR Radiator Compatibility
The radiator on my twin cam KA just took a dump. I plan on swapping in an
SR20 in the future. So I was thinking of upgrading to a better radiator.
My question is....... do the KA and SR carry the same radiator? Or am I wasting my money by upgrading, only to have the KA radiator not work with the SR.
This is on an S13, with the plans to run a blacktop SR20, if it make a difference.
AWDtoyota is offline   Reply With Quote
Old 01-23-2006, 09:24 PM   #2
axiomatik
axiomatik's Avatar
the upper rad hose is on opposite sides between the two, you could find a hose to go across your engine in the meantime
Old 01-23-2006, 09:25 PM   #3
Dousan_PG
Dousan_PG's Avatar
upper hose is on wrong size for ka/sr
they run opposite sides
get another stocker for now upgrae when u do the swap.
Aaron
Pink GodziRa
Old 01-23-2006, 09:26 PM   #4
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
You would just have to make hosing because the upper radiator hose on the sr connects on the right, ka is on the left.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 01-24-2006, 12:07 PM   #5
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
So basically, the answer is no.
you can just get a stock-sized radiator for like $100. It's not that bad. Upgrade it later for the swap
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 01-25-2006, 09:17 AM   #6
KiDyNomiTe
KiDyNomiTe's Avatar
The answer is its up to him not no. It will work it just doesnt look pretty. My friends hachi has his 20v setup like that, but he has polished pipes and what not so it looks pretty.
It will look like this (but this is an m30)
PROCEED
Grip Gambler
Old 01-25-2006, 07:22 AM   #7
Max_PSi
Max_PSi's Avatar
Max_PSi will become famous soon enoughMax_PSi will become famous soon enoughMax_PSi will become famous soon enough
I seen setups with 2 pieces of hose and a pipe used before. Comes off the rad, straight across the fan shroud and then down to the block. Hose on either end of the pipe of course. It looks like shit honestly because the pipe used will just float in the air.
Max_PSi is offline   Reply With Quote
