Old 05-15-2006, 07:11 AM   #1
My240
My240's Avatar
My240 is an unknown quantity at this point
Send a message via ICQ to My240 Send a message via MSN to My240
s13 tranny sensors
i am in the process of converting my s13 from auto to 5 speed. i bought a tranny and the 3 sensors that are on the side had all been cut, this is not including the wheel speed sensor at the back. does anyone know what each of these sensors are for and how they wire up? thanks for your help
My240 is offline   Reply With Quote
Old 05-15-2006, 08:12 AM   #2
tre
tre's Avatar
tre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enough
You're local nissan dealership can tell you that
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole.
tre is offline   Reply With Quote
Old 05-15-2006, 08:22 AM   #3
g6civcx
g6civcx's Avatar
You need to get a lower engine harness that goes from the back of the gearbox from a manual gearbox. It plugs up to the engine room harness. If it's cut you have to manually wire them up yourself.
Old 05-15-2006, 08:36 AM   #4
My240
My240's Avatar
would you be able to explain that a bi5t further? i have no idea where the the harness would go into the engine room harness
Old 05-15-2006, 08:44 AM   #5
g6civcx
g6civcx's Avatar
Go to a local junkyard. If you can see one with a manual gearbox you could probably just unplug all the sensors and take out the whole harness.
If you don't have one you need to read the FSM. Try getting one from your local dealer.
If it's not possible you have to redo the wire harness yourself. That's as far as I can explain it because it is complicated. A shop would probably charge you 10 hours of labour to fabricate a gearbox harness from scratch.
Old 05-15-2006, 08:50 AM   #6
My240
My240's Avatar
alright man sounds good thanks for your help i really appreciate it. but if anyone else still has anymore input then feel free to put in your knowledge
Old 05-15-2006, 10:51 AM   #7
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
why not just forget about it, you dont need any of that shti, the only useful one is speed and that is on the main harness.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 05-15-2006, 01:02 PM   #8
My240
My240's Avatar
so you're saying that those 3 sensors don't even really have a purpose? like what do they do? are they for the back-up lights at all? i mean there has to be a purpose to them
Old 05-15-2006, 01:16 PM   #9
aznpoopy
aznpoopy's Avatar
get a FSM dude.
park neutral switch
reverse lamp switch
OD position switch
first two are obvious. i never figured out what the third one does. lol.
Old 05-15-2006, 01:18 PM   #10
tre
tre's Avatar
OD... maybe Overdrive? When the car tends to lean itself out to give you premo gas mileage on the freeway?
Old 05-15-2006, 01:26 PM   #11
aznpoopy
aznpoopy's Avatar
possibly. i think "OD" refers to 5th gear.
Old 05-15-2006, 01:48 PM   #12
My240
My240's Avatar
alright guys that was awesome. thanks for all your help.
Old 05-15-2006, 03:29 PM   #13
g6civcx
g6civcx's Avatar
It's the 5th gear indicator. The ECU does something with it, mostly for the top speed governor.
Old 05-15-2006, 04:06 PM   #14
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
The only two you need is the speed sensor in the back and the middle sensor. The middle sensor is for the back up lights. I only have those two hooked up.
240silvia is offline   Reply With Quote
Old 05-16-2006, 07:03 AM   #15
My240
My240's Avatar
sweet deal. thanks for the help guys i really appreciate it
Old 05-16-2006, 07:48 AM   #16
dopeassjackson
dopeassjackson is a well-known jackass
from the tail of the tranny it goes back up switch, OD switch then neutral i think. the speed sensor is in there some where also.
dopeassjackson is offline   Reply With Quote
Old 05-16-2006, 09:41 AM   #17
My240
My240's Avatar
keep the info commin. thanks. i ordered myself one of those service manuals on disc but it hasn't come in. but you guys are doing a great job
Old 05-16-2006, 10:44 AM   #18
mjjstang
never needed a service manual on disc, and ive done a lot of work, how bout www.zeroyon.com????? FRREEEEEEEEEEE
Old 05-16-2006, 11:30 AM   #19
g6civcx
g6civcx's Avatar
In his defense, zeroyon doesn't have the SOCH FSM and convertible add-on.
Old 05-16-2006, 11:44 AM   #20
My240
My240's Avatar
well my KA is DOHC and it's not convertible. but i never knew about that site til now. but thanks
Old 05-16-2006, 11:48 AM   #21
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
maybe a dumb question, but whats the purpose for the neutral sensor?
rancid240 is offline   Reply With Quote
Old 05-16-2006, 01:33 PM   #22
My240
My240's Avatar
i was wondering about that aswel. i mean you're gunna be pushing in the clutch anyways so i don't even think you'd really need the neutral switch. or do i?
Old 05-16-2006, 08:32 PM   #23
mjjstang
neutral is so you cant start the car when the clutch is not pushed in, at least this is what I think, I mean i can start mine in any gear i want with the pedal not pressed in, this is because I dont have my sensor connected. someone correct me if im wrong.
Old 05-16-2006, 08:53 PM   #24
g6civcx
g6civcx's Avatar
The neutral switch isn't used for starting. You can't start without pressing the clutch even if you're in neutral.
Old 05-17-2006, 12:01 AM   #25
mjjstang
o yah silly me, anway i can start it no matter what, so i got something unplugged
Old 05-18-2006, 07:20 AM   #26
My240
My240's Avatar
so the only sensor that i really need is the one the turns on my back up lights?? and what do i connect that to?
Old 05-18-2006, 09:41 AM   #27
rancid240
Trader Rating: (72)
Im guessing autos dont have a plug for that. Well on a manual when the shifter is in reverse the sensor will, I dont know the word, but it will have 0 resistance. So what Im thinking that either the positive or the negative (more likely the negative) wire to the reverse lights will connect to one of the prongs, the other to a gournd, and the sensor completes the circuit when its in reverse.
Old 05-18-2006, 09:57 AM   #28
My240
My240's Avatar
i guess that would make sense about the connection, so as soon as you put it in reverse you'd complete to power circuit and it would turn on the lights right?
Old 05-18-2006, 02:33 PM   #29
rancid240
Trader Rating: (72)
Thats what I am thinking.
Old 05-18-2006, 03:35 PM   #30
Slyce
Slyce is an unknown quantity at this point
take a look at this
http://ka24development.com/cwilfert/...lectrical.html
Slyce is offline   Reply With Quote
