Old 05-31-2002, 02:50 PM   #1
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
Their is a screen in the Mass air flow sensor.  I know that in many v8s etc that you can remove the screen, and mildly port the Maf sensor itself.  The screen is normally used to "straighten" the airflow, and give a correct reading, but it is also a hinderance in flow.  By removing it in muscle cars, you can lean out the A/F mixture artificially by having the PCM think it is getting less air than it actually is.  Can you do the same on a 240sx?
Any other free mods to a stock 240sx?
__________
96 s14
300zx lsd
zeal b2's
AJ is offline   Reply With Quote
Old 05-31-2002, 03:04 PM   #2
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
wait?  arent most muscle cars carb'd?  why would they even need an MAF?
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 05-31-2002, 03:54 PM   #3
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
isn't that screen actually the wire that gets heated up in order to measure the flow?
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 05-31-2002, 07:10 PM   #4
Joe_M
Joe_M is an unknown quantity at this point
Send a message via AIM to Joe_M
We did this on my buddies 3000GT VR4 so I thought I would do it on mine.  I took the MAF off and there is no screening in it.  Not sure if it is the same for all S13's but mine didn't have any screening in it at all.
Joe
1991 240SX LE Fastback SOLD!!
1992 USDM OneVia CA18DET powered SOLD!!
1996 240SX Base Model Rockin' the 4 Lug
1995 240SX Base Model $400 project car... and it runs!
Joe_M is offline   Reply With Quote
Old 05-31-2002, 07:53 PM   #5
MarketPlayer
MarketPlayer is an unknown quantity at this point
mine didn't either, except for the actual sensor coil!  I have never seen a screen in a MAF.  If you are sure that the screen isn't what judges the amount of air, and there is a coil somewhere behind the screen then go ahead.  Just make sure your engine managment is good or else!!!!!!
MarketPlayer is offline   Reply With Quote
Old 05-31-2002, 09:50 PM   #6
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
the maf screen is there for a reason. it helps keep debris out of the tb and from entering the intake manifold.
on quests the main problems is the screen which gets a build up of dirt over time and causes the car to idle like shit. i would leave it there the amount of air it holds back is very minimum.
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
