Old 05-21-2006, 02:17 PM   #1
driftskeetka24e
driftskeetka24e's Avatar
driftskeetka24e is an unknown quantity at this point
Send a message via AIM to driftskeetka24e
Help me with my s13 problems.(revs&brake lights)
So my car will not rev past 5k, what could be the cause of this?
Also my center brake lights are on regardless of braking or not but only when my lights are on. So when my lights are off my brake lights work fine. But when my lights are on the center brake lights are on non stop while the outside ones work. So please help me out.
Thanks in advance i hope i am clear enough with my problems if not ask questions please.
driftskeetka24e is offline   Reply With Quote
Old 05-23-2006, 04:08 PM   #2
driftskeetka24e
can anyone help me out ive tried injector cleaner and that hasnt helped and checked my maf connection
but can anyone help me out or give me sugestions please!
Old 05-23-2006, 04:24 PM   #3
ALTRNTV
About the lights, are the bulbs double filament, or just one?
ALTRNTV is offline   Reply With Quote
Old 05-23-2006, 07:31 PM   #4
driftskeetka24e
the bulbs are double filament. hope you can help me now
Old 05-23-2006, 08:04 PM   #5
g6civcx
g6civcx's Avatar
The third high-mount brake light should only be on when you are braking. It should not come on with parking lights.
You most likely wired it wrong. I think you inadvertently hooked the third brake light to the parking light signal. When the parking lights are on, power is sent to the the brake light. When the parking lights are off, it works normally. The parking lights signal is overriding the brake signal.
Check the wiring to the brake light.
Old 05-23-2006, 08:19 PM   #6
FRpilot
FRpilot's Avatar
i have a weird problem also.. seems like my third brake light never turns on even when braking. only the regular brake lights come on. i figure it cant be the wiring since the third brake light is connected by an interior harness that ive never touched but the regular brake lights work.. must be the bulbs out
FRpilot is offline   Reply With Quote
Old 05-23-2006, 08:56 PM   #7
g6civcx
g6civcx's Avatar
Check bulbs.
Old 05-23-2006, 09:37 PM   #8
driftskeetka24e
dude its not my brake light on the hatch...its the center brake lights and it was workin and i havent messed w/ my wiring so any other suggestions. also they work fine either off or on when my lights are off but if my lights are on either headlights or parking lights the outside brake lights are dim and light up when i brake but the center brake lights look like im braking 24/7
any other suggestoins?
thanks
Old 05-23-2006, 09:55 PM   #9
Phlip
Yes, I look like that
Phlip's Avatar
Make sure you have the correct bulbs in all positions, that seems to be the most frequent encountered problem
Weirdo
And I write too!
Old 05-23-2006, 11:34 PM   #10
driftskeetka24e
my shit was working fine and it just started doing this...i checked the bulbs they are all good
also any suggestoins on my engine not revving past 5k?
thanks
Old 05-24-2006, 09:05 PM   #11
driftskeetka24e
so heres some pix and more info to help out
lights off no braking: ( no lighting )
lights off braking: ( only outside lights )
lights on no braking: ( lights on, outside dim inners bright )
lights on braking: ( everyting lit up )
probably bulbs right?
Old 05-25-2006, 02:52 AM   #12
g6civcx
g6civcx's Avatar
The inner lights should work the same as the outer lights. Your outer lights are working correctly from what I can see.
Did you recently rewire the taillights? It looks like you have the wiring wrong for the inner bulbs. I think you hooked up the brake signal to the wrong filament, and I don't think you hooked up your parking signal at all.
Looking vertically at the inner taillight harnesses on both sides, it should go Red/Blue for parking, Red/Green for braking, and Black for ground. Check that first. Most likely you have it backward on your body harness.
I also noticed that your center brake light doesn't work. Check that before you get a ticket.
Old 05-27-2006, 02:07 AM   #13
driftskeetka24e
can u get a ticket for that not working? cuz it is gone now i just shaved it today
Old 05-27-2006, 02:13 AM   #14
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
you can if the cop wants to be a dick about it
IAM_SO_sLOw is offline   Reply With Quote
Old 05-27-2006, 02:27 AM   #15
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
cop prolly wont even notice it's not there
are washington police even that anal?
they might just think its a ford probe or something
kouki_s14 is offline   Reply With Quote
Old 05-27-2006, 11:29 PM   #16
driftskeetka24e
well once it is shaved there is no evidence of it being there so impossible to get a ticket for something that doesnt work thats not even there
Old 05-28-2006, 08:32 AM   #17
street_white180sx
street_white180sx's Avatar
street_white180sx is an unknown quantity at this point
hey for ya car not being able to rev past 5 grand check fuel pressure. your fuel pump might be on the way out
1993 S14 Silvia Slant Top, Blitz Bov, Fmic, Catback exhaust, HKS evc 3
street_white180sx is offline   Reply With Quote
Old 05-28-2006, 03:20 PM   #18
g6civcx
g6civcx's Avatar
If the cop is stupid then it won't even be noticed, but if the cop is out for justice that's a violation of federal law. The worst case would be they'll impound the car until you show up to claim it with a new hatch with high-mounted third brake light.
I don't think they'll notice though.
