if you put PS fluid in your power steering...
quick fix...tried searching for this but the info that I got was that the pump/rack are probably already ruined
![]() jackup front disconnect 2 12mm power steering lines that go into the rack (hard lines) let it drain, turn wheel all the way left and right (fluind will squirt!) fill resevior with ATF, let it drain, play with wheel loosen belt, add more ATF, turn pump by hand close/tighten everything, top off with ATF My steering was loud, and barely felt powered @ low speed because I put power steering fluid ![]() ![]() |
![]() Join Date: Dec 2002
Not really, the OE parts aren't 'ruined' by running PS fluid temporarily. It's the people who've used it since the car was new that have problems, a little bit for a short time is fine.
Read first post It say ATF no need to use the search button but actually reading the post.
Been a member before me and did not know this? I am not being a jerk, but just asking what do you run? |
![]() Join Date: Aug 2002
i just flush my ps system because it was leaking and my friend gave me some ps fluid to top it off. i used atf before but it got mixed and i searched that said ps fluid will fuck up your rack.
easier way imo, is to take off the return line on the reservior and let the fluid drain into a bucket or jar. no need to go underneath the car and deal with those hardline fittings. i didnt fill reseriovr with fluid all the way to flush out because i didnt have that much left in my garage, just added a little bit. i think i should flush again. |
#8 | |
s14| y34| 911 gts| exige s| 600rr| r3| 250r| 85 girlfriend ![]() |
so... how long would you consider a "prolonged period of time"? a month? a couple of months? a year?
![]() after my car has been running for a while (the engine temp stays normal though) there is a quite loud whining down sound from the engine bay when i brake at slower speeds (under 20mph?). do you think it's from my ps system? |
![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
How about this: I installed a rebuilt rack about six months ago. The remanufacturer actually specified regular power steering fluid and specifically stated that using ATF would void the warranty because of the seals they use in the rebuilding process. I even called to confirm, and made it clear that Nissan specifies ATF, and they said "yeah, we know, we get that question a lot, use PS fluid and NOT ATF."
Opinions?
E36 M3 - new project 1990 240SR - screamed down the road |
![]() Join Date: Sep 2002
Um. If they specifically said that then why wouldn't you listen to them, the people that rebuilt it, and listen to us?
My 240 vBgarage |
I just flushed mine and threw some prestone ATF In, It does feel smoother at idle and It seems to react quicker to my steering so I guess ATF is the way to go when It comes to original Nissan Racks.
#14 |
![]() Join Date: Aug 2005
i had plenty problems running PS fluid. It has a lower boiling point so it would always over flow and get all over the place. Put in ATF and problems went away.
#16 |
![]() Join Date: Jan 2006
The hydraulic properties of ATF are something that most people dont think about, its great stuff. Its good shit.
Using PS fluid instead of ATF is like using water in a recipe that calls for cream. Dont work no good. |
#17 |
I typed a nice writeup on the benefits and reasons for using ATF in the PS system not long ago, but I guess no one bothered to do a little research and just decided ask the same random questions again.
As for the usage of ATF, most Japanese manafacturers specify it in their cars, my LS400 uses ATF also, regular PS fluid clogs up the rack filter which is a very common problem on most Toyota/Lexus products. |
