Rebuilding a KA motor?
I have never rebuilt a car motor before and the price for rebuilding motors at a shop is insanely high. The only tools I have at home is a cherry picker and tools needed to attach/unattach bolts and nuts for now. I was wondering if there is a website where I can order rebuilding motor parts and the steps to perform the rebuild?
Yes, I look like that
![]() Join Date: Mar 2002
You didn't specify which year, so I aimed for the middle ground.
http://www.amazon.com/exec/obidos/tg...glance&s=books ... good luck |
![]() Join Date: Sep 2003
get a fsm, get a bin.... take the head off.......
follow the fsm i honestly say read the em section 3x over, keep all the parts numbered 1-4... get a micrometer in and out, get a engine stand.... get a parts washer...start following the fsm in taking apart the block. make sure... u keep everything numbered....would be wise to get a number punch set.. maybe ill do a write up, when i rebuild my block....
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#5 | |
any ideas on how long rebuilding a KA engine might take? |
for someone whos not mechanically inclined... i say for ever, but if ur thorough clean organized... and u follow directions well and have the money for the rebuild maybe a month... me... if i have all the parts in hand maybe a few days..
"Street racers don't need girls." -Lonely Driver Learning about cars one FLAME at a time ... (thanks to TNORD) |
i'll be cheaper to swap a lower mileage engine. But IF you're up for a task. Which i'd HIGHLY suggest having someone who knows what they're doing by you. Go for it. Good learning experience.
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole. |
#9 | |
thanks a lot! ^^ now all i need is a website that sells full rebuilding kits.. x_x |
Some of these can be a bit spendy, especially for a novice:
http://www.importperformanceparts.ne...ek-nissan.html http://www.amsperformance.com/store/...roducts_id=303 http://www.rpmmachine.com/enginerebu...nissantop.html http://www.nizzx.com/ http://www.hybridka.com/ ... I searched and found those, I suggest you go that route from here forward |
#11 | |
OK, after reading the guide, it says that I should only use OEM parts or bolts [I'm going to assume that I can use the same bolts that I took out]. Where can I get the OEM Nissan handbook guide? Or FSM. Last edited by EvenStar; 05-28-2006 at 02:24 PM.. |
i'd HIGHLY suggest an OEM rebuild kit aswell.
Hell one of the best Head Gaskets ont he market for the DE is OEM.
Btw, can anyone list the parts that I need to rebuild the whole motor? And what specific tools do I need when taking out bolts and such? The guide did not mention it and I just want to make sure of it when I order the rebuilding kit.
#14 |
just get a FSM it tells u everything u need..... search fsm, zeroyon "something that", theres a recent thread speeddreamz is hosting some fsm now....
#15 | |
![]() Join Date: Apr 2003
You can also get a shit load of zip lock bags as well. Label the zip lock bags to describe where the bolts came from. Mark bolts using whiteout, mark it in dots to describe what number from pattern so that it would be easy to put back together. |
#16 |
organization is always the key........ big vinnie how is ur build goin...... i guess u havent heard im goin sRAwR.....
#17 |
http://www.amsperformance.com/store/...hp?cPath=24_62
everything you need for your rebuild right there, ams is very respectible over here in Chicago
- 93' 240s13 - ![]() ![]() "BOOST IT" |
#18 | |
BOO on the sr!!!! I've actually decided to save my money on an HRT N/A built block 10.5:1 setup. All I have to do is install it. Also install the scraper and windage tray... Don't have a garage anymore........ But ehh just kidding about the sr, if you like it it's meant for JOO!!! |
#19 |
theres a place in vallejo that does knife edging for 250 i believe... im going to them for this build... to get my crank serviced...
