Old 05-28-2006, 11:42 PM   #1
AN89HATCH
AN89HATCH is a well-known jackass
Will 18x9.5 + 20 be teh same as 17x9+10??
I need to get spacers for the rear of my car. My fronts have a 25mm spacer brininging the front to a 17x9+10. I can not decide what spacer to ge for my rear wheels which are 18x9.5+ 35. Should I go with a 15mm spacer to bring the offset to 18x9.5+ 20? or should I go with a 20mm spacer bringing the rear to a 18x9.5+ 15? I am trying to get the rear wheels as flush, or to stick out a little more than the fronts thanks.
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 05-28-2006, 11:49 PM   #2
sw20>>s14
sw20>>s14's Avatar
how could they possibly be the same? for a 9.5 +20's outer rim to be the "same" for a 9" rim, the offset would have to be +14...
and for a 9" +10's outer rim to be the "same" for a 9.5's outer rim, the offset would have to be +16
sw20>>s14 is offline   Reply With Quote
Old 05-29-2006, 01:39 AM   #3
AN89HATCH
Ok let me try this again up front I have a 17x9 +10 wheel. It stick out past the fender maby 5mm My rear is a 18x9.5+ 35, and it is sunken in prob by 2 mm. I am trying to get my rear wheels even or to stick out past my front wheels. The way my car is now my fronts are flush, and my rears are not as flush as the fronts, and it looks bad. I am wondering will a 15mm spacer be enough for the rear, or should I go with a 20mm spacer for the rear? But i think you answerd my question. the rear offset will have to be a +16.
slide your ride.com
Old 05-29-2006, 04:41 AM   #4
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
isn't 1 inch like 25mm?
gotta240 is offline   Reply With Quote
Old 05-29-2006, 10:11 AM   #5
SoSideways
SoSideways's Avatar
1" = 25.4mm
.5" = 12.7mm
Old 05-29-2006, 03:06 PM   #6
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
yes 9 +10 = 9.5 +16. So to go from 9.5 +35 to +16 youd need a 19mm spacer. So a 20mm spacer should do.
Use this for reference:
http://www.1010tires.com/WheelOffsetCalculator.asp
Nizzan4u2nv is offline   Reply With Quote
