Old 12-31-2005, 12:48 PM   #1
KingKong8247
KingKong8247's Avatar
KingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of light
Send a message via AIM to KingKong8247
RUCA bolt stuck
Any tips on how to get the RUCA bolt out? It is the one more towards the gas tank, the one I think that is used for adjusting camber in the rear. I got the nut off but the bolt just will not come out.
Im hitting it with a hammer jamming a screwdriver in there and nothing
90 240sx Coupe
KingKong8247 is offline
Old 12-31-2005, 01:05 PM   #2
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
i would say try heating it up but with the gas tank near i dont know if thats a good idea. try a breaker bar.
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline
Old 12-31-2005, 01:09 PM   #3
Dousan_PG
Dousan_PG's Avatar
the eccentric bolt slipped and is not lined up proper w/ the bolt. the bolt has a valley running along it. the ecentric bolt has a little point that should go into tha valley
you need to lie them up again and then you canslide bolt out
i sugged putting the nut back on and usinga breaker bar on the head of the bolt until the point lines back into the valley
then remove the nut and hit the bolt out w/ a hammer
been there donethat. just takes a bi tof time and patience and it willpop right out.
Aaron
Pink GodziRa
Dousan_PG is offline
Old 12-31-2005, 01:12 PM   #4
KingKong8247
wow just relized the bolt is stuck on there good. The washer on the opposite side has moved out of its groove and is on the something whatever look at the pic wish me luck getting this off
You can kinda see it here the thing isnt in the groove
90 240sx Coupe
Old 12-31-2005, 01:15 PM   #5
Dousan_PG
Dousan_PG's Avatar
see my post you ll have it fixed real fast like
Aaron
Pink GodziRa
Old 12-31-2005, 01:29 PM   #6
KingKong8247
Thanks guys I actually used some vice grips and turned the head of the bolt till it lined up. Got it off nice and easy
90 240sx Coupe
Old 12-31-2005, 02:48 PM   #7
Ritz S14
Ritz S14's Avatar
Whoa. Fucking thanks guys. I'm installing my RUCAs now too. w000t.
Thanks jon wayne for searching for me
Ritz S14 is offline
Old 12-31-2005, 08:24 PM   #8
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
that problem cursed me for VERY long. Figured it out after a while though.
DJPimpFlex is offline
Old 12-31-2005, 09:14 PM   #9
Ritz S14
Ritz S14's Avatar
Did exactly what dousan said. It works. Perfect.
But haha I kinda stripped the bolt thread cause I turned it so many times. But whatever, it works. DONE.
Just gotta do the passenger side after the weekend. GOod thing I have 2 cars.
Ritz S14 is offline
Old 12-31-2005, 09:30 PM   #10
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
torch it.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline
Old 12-31-2005, 11:00 PM   #11
andrewmp6
andrewmp6 can only hope to improve
try soaking it with wd 40 and beat it out or heat it up with a torch or somthing
andrewmp6 is offline
Old 12-31-2005, 11:20 PM   #12
S14DB
AFC #1
S14DB's Avatar
Originally Posted by theicecreamdan
torch it.
BOOM1!!
S14DB is offline
Old 06-12-2006, 07:17 PM   #13
angrychickens
angrychickens's Avatar
angrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the rough
Send a message via AIM to angrychickens
its like every problem i have ever had has happened to someone before
god bless the search function
angrychickens is offline
Old 06-12-2006, 11:21 PM   #14
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
use rust penetrating spray dude it works all the time and do not use WD40 that doesnt work at all what people say. you can find it at any local auto shop or store. WALMART man hahahaha lol
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline
Old 06-12-2006, 11:22 PM   #15
s13silvia123
forgot ta say that when you put the rust penentraign spray you leave on for like 5 ta 10 minutes. after that easy going.
Old 06-13-2006, 12:17 AM   #16
RightWheelDrive
RightWheelDrive is on a distinguished road
Use Dousan's way, its the right way. just turn the other side of the bolt until it lines up with the valley so it can come out or else no amount of penetrating lube with help. Just turn the bolt and the washer will nudge up against the subframe so that you can torque it. Just look at how the bolt is shaped and how the washer is shaped and figure it out. This happened to me and it took 2 seconds to see what was going on. I trust you can do that same. Good Luck.
RightWheelDrive is offline
Old 06-13-2006, 12:39 AM   #17
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
ya and you guys did not look at the date of this thread. Its 6 months old!!
New Video
Buy my mounts!
drift freaq is offline
Old 06-13-2006, 12:47 AM   #18
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Baka!
To maintain topic flow, used the same method Aaron described when I encountered this problem. A little PB blast made it smoother...
Please close...
zero.counter is offline
Old 06-13-2006, 01:12 AM   #19
S13Eye
S13Eye's Avatar
S13Eye will become famous soon enoughS13Eye will become famous soon enoughS13Eye will become famous soon enough
Send a message via AIM to S13Eye
Those can be a pain to take off. Sometimes its just better to cut them off with a sawzall. If you are lucky, the bolt isn't completely seized - in that case heat the bolt, and spray it with penetrating oil. The oil will sizzle and smoke, but keep spraying it and leave it to sit for a while. Then use a screwdriver or a prybar to wedge between the washer and flange, and hammer it in. Once the screwdriver is hammered in a little, turn the bolt so the washer rotates with the screwdriver still wedged in there, and slowly the rust will break lose and gradually you can get the washer to come off the bolt.
Its a lot easier to just cut it off though.
S13Eye is offline
Old 06-13-2006, 07:54 AM   #20
Phlip
Yes, I look like that
Phlip's Avatar
Question was answered before the thread was older than hell, please don't do this, people.
Weirdo
And I write too!
Phlip is offline
