Old 06-19-2006, 11:13 PM   #1
240sx=fast
240sx=fast is an unknown quantity at this point
ka24e help please!!!!
i am needing to know the tolerances for the lifters in a ka24e head.i just bought a engine and it sounds like a lifter it tapping.i need to know the tolerances so that i can fix this problem.thanks.
240sx=fast is offline   Reply With Quote
Old 06-20-2006, 04:50 AM   #2
RightWheelDrive
RightWheelDrive is on a distinguished road
Sohc uses hydraulic rocker arms. You sure its not a bent valve?
RightWheelDrive is offline   Reply With Quote
Old 06-20-2006, 06:05 AM   #3
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Timing chain slap?
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 06-20-2006, 06:25 AM   #4
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Is the oil clean and full? That will cause lifter failer.
Can you pinpoit where the tap is? Frunt back ect...
NIK90s13 is offline   Reply With Quote
Old 06-20-2006, 01:42 PM   #5
240sx=fast
not really,i just bought the engine and the guy sent me a video file of it running.i was thinking that it may be a sticking lifter because it does it only when it is first fired up,after it gets warm it smooths out.and the engine runs a little ruff when it is cold also.
Old 06-20-2006, 01:57 PM   #6
southjrz240
southjrz240 is an unknown quantity at this point
it can be the timing chain guides. then tend to make that sound. it is a very uncomfy sound
southjrz240 is offline   Reply With Quote
Old 06-20-2006, 02:01 PM   #7
240sx=fast
ya it doesnt sound very pleasant,lol
Old 06-20-2006, 02:50 PM   #8
CaoBoY
CaoBoY is making a name for him/her selfCaoBoY is making a name for him/her self
if it is the timing chain guides, then you should probably just get a timing chain kit....i had a slapping sound when i would first start up my car....found out...it was my timing chain guide...it broke, and was sitting in my oilpan.
pulling outta the game:
http://www.zilvia.net/f/showthread.p...wpost&t=119867
parting out, just let me know.
CaoBoY is offline   Reply With Quote
Old 06-26-2006, 02:38 PM   #9
240sx=fast
well just talked to the guy,and he said that it doesnt go away..........it just gets a little more quiet.......can this be a collapsed (sp?) lifter?i got a complete second head if bad comes to worst,but i just need to know how to eliminate some of these probs......
Old 06-26-2006, 06:53 PM   #10
NIK90s13
NIK90s13's Avatar
Pull your valve cover and check the timingchain and guides, check the lifters too, if you rotate the cam till the valves are closed you can feel each rocker arm to see if there is to much play.
Old 06-26-2006, 07:20 PM   #11
240sx=fast
do you know what the tolerance should be?
Old 06-26-2006, 09:36 PM   #12
NIK90s13
NIK90s13's Avatar
No, Hit the serch for factory service manual, down load the single slammer. I have a dohc motor (kade) and manual, I swaped the sohc motor out, I didn't have much intrest in it sorry.
I just serched and found this link, check it out. The hydrolic lifters don't ajust, so if you have slack then it is shot and you need new ones, hope this helps.
http://www.zilvia.net/f/showthread.p...ydrolic+lifter
Old 06-26-2006, 10:52 PM   #13
240sx=fast
yes it does thinks.i will just stick my others onto this head.i got some that are brand new,i am not to familiar with the nissan scene just yet.
