Old 06-23-2006, 03:02 PM   #1
SlappieBooBoo
SlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choices
s14 Rotor Scraping
Ok so heres the deal? When ever my car is rollin slow i get this weird scraping noise from the back rotors or so i think. When i apply the brakes it intesifies the sound. I don't know what it is, i imagine it is the brakes but they seem to be fine. what else could be scraping back there. also when i am going in reverse theres a humming sound and sometimes something sounds to be scraping REALLY loud. do you guys know what this could be?
SlappieBooBoo is offline   Reply With Quote
Old 06-23-2006, 03:08 PM   #2
Ritz S14
Ritz S14's Avatar
Sometimes there's debri on the pads. Try giving a firm stomp on the brakes, and let go before it locks up.
Have you inspected the pads?
Ritz S14 is offline   Reply With Quote
Old 06-23-2006, 03:51 PM   #3
S14DB
AFC #1
S14DB's Avatar
3 things come to mind.
1) There is contamination on the pads/rotors. couple heat cycles should get rid of it.
2) Rotor is out of true. The sound constant or whirring?
3)Parking brake is out of alignment. ether the adjuster or the caliper is out of spec. if it's the adjuster it's should go away after a while.
The thing I hope it's not is the caliper sezing up. I had one do it already and I think there was a video of one on here. The rear brake calipers are not that great of a design.
Old 06-23-2006, 04:10 PM   #4
2iv0 sx
2iv0 sx's Avatar
2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute
i need to take a look at mine also.. ive been recently hearing squeaks..
2iv0 sx is offline   Reply With Quote
Old 06-23-2006, 04:22 PM   #5
aznpoopy
aznpoopy's Avatar
loud high pitcted metal on metal scraping
low pad wear indicator. time for new pads.
Old 06-23-2006, 05:00 PM   #6
RPS1392
RPS1392's Avatar
RPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura about
I heard what to me sounded like a rock in the rear caliper for a couple of weeks, when I got around to pulling them apart the inside pad was gone and what I heard was metal to rotor contact.
RPS1392 is offline   Reply With Quote
Old 06-23-2006, 07:20 PM   #7
2iv0 sx
2iv0 sx's Avatar
dang i guess mine are goin out too.. more money to spend gosh!
Old 06-23-2006, 08:40 PM   #8
SlappieBooBoo
what about the sound when backing up??
Old 06-23-2006, 09:11 PM   #9
aznpoopy
aznpoopy's Avatar
its a big metal thing that is touching your rotor. it doesn't discriminate between backing up or moving foward.
get off the forum, jack up the car and take off your wheel. take a look at your pads. that will tell you real quick if that is the problem. it takes about 3 minutes to check.
Old 06-23-2006, 09:42 PM   #10
SlappieBooBoo
woah man chill i appriciate the help, but you have to realize that not everyone has instant acess to means of lifting a car and taking wheels off. i'll take some shit off and let you guys know what i think.
and there are 2 different noises i believe when i first bought the car it sometimes made that loud noise while backing up NEVER has done it moving forward, the noise when i am movie forward is much quiter and sounds slightly different
Old 06-23-2006, 09:59 PM   #11
S14DB
AFC #1
S14DB's Avatar
You don't have a jack? There should be a jack and a lug wrench in your trunk.
Old 06-23-2006, 10:06 PM   #12
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
I had almost the same problem, except when I reversed I got a loud grind/pop noise. The pads were worn diagonally from one corner of the pad to the other all the way down to the metal on the lowest worn down point. I did a caliper rebuild on the back (just the rubber seal). And I replaced the pads.
Neejay is offline   Reply With Quote
Old 06-23-2006, 11:53 PM   #13
SlappieBooBoo
hmmm yeah thanks
