Old 07-02-2006, 07:07 PM   #1
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
s13 rear subframe mount bolt broke! need help!
I was installing rear subframe spacers and the passenger-side front subframe mount bolt snapped. The 17mm nut was frozen so I got my breaker bar and
POP!!! There is no access on the top of the bolt so I was wondering, how the
hell am I going to get a new bolt in there????
Any info would be great
s13coupedrfter is offline   Reply With Quote
Old 07-02-2006, 08:55 PM   #2
whitey240
whitey240 is an unknown quantity at this point
Have you tried using an ez out?
1993 Nissan 240sx - SR20VET VVL, GT30R || 11.3@122
whitey240 is offline   Reply With Quote
Old 07-02-2006, 09:45 PM   #3
s13coupedrfter
If you were to take the rear subframe completely out, it would be the 4 bolts hanging down out of the unibody that the subframe slides onto.
Old 07-02-2006, 10:14 PM   #4
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
^yea thats what he broke. I'm not sure about this at all, but you should be able to cut into the frame and replace the bolt. Maybe, maybe not. I'm not 100%.
DJPimpFlex is offline   Reply With Quote
Old 07-02-2006, 11:48 PM   #5
projectRDM
projectRDM's Avatar
Either cut out a box section of the frame and weld a new one in, or cut through from above, drill it out, and drop a new bolt through from the top. Either option is a shitload of work, good luck.
Old 07-03-2006, 09:29 AM   #6
s13coupedrfter
I think I'm going to try option 2, cut a hole to get access the the top of the bolt drill it out and drop a new one in. I'm trying to save myself some work by not having to take the subframe out. I'm going to the nissan dealer today and see how much the bolt/nut is and ask if they have run into this before. I'll post when I find out. Thanx guys for the suggestions.
Old 07-03-2006, 02:25 PM   #7
projectRDM
projectRDM's Avatar
Um, no. The bolt is not available separately. From the dealer you'd have to buy the portion of frame rail it's welded in. You'll have to cut one out of a salvage chassis.
Old 07-04-2006, 08:58 PM   #8
sciamop
sciamop's Avatar
sciamop is making a name for him/her selfsciamop is making a name for him/her self
Just as an FYI, this is a common problem on the E36 BMW. Except instead of breaking the stud, the sheet metal rips out of the floor! The solution for that car involves welding the broken stud back in with a factory reinforcement.
If you are on a budget, you should give option 2 a shot:
-- Just get an 8.8 bolt in the same length (and pitch if possible) as the broken stud, a nut (if the pitch doesn't match), a big (and strong ) washer, a 3/8"+ drill bit and a hole saw.
-- Grind off the remains of the old bolt and drill out the hole. This may take some time; you should probably buy a kick-ass drill bit for this.
-- Use the hole saw to drill an access point through the floor of the trunk. IIRC, the gas tank is fully aft of the rear x-member. You should confirm this before you go crazy with the hole saw.
If it doesn't work, remember that you have 3 other studs holding the rear x-member in the car!
Todd
91 SE-R
93 Coupe
http://www.whistlehog.com/blog
sciamop is offline   Reply With Quote
Old 07-05-2006, 03:56 PM   #9
s13coupedrfter
I'm still awaiting a call from nissan reguarding the part#. I'll try to take some pics of the fix so as soon as hear from nissan I'm going to start the repair.
Old 07-05-2006, 05:50 PM   #10
aznpoopy
aznpoopy's Avatar
which bolt is it exactly?
instead of getting another stud you could do this:
access from the top. drill through from the top. drill out the old stud. go to the hardware store and pick up strong extra long bolt with the same thread size. go back to the hole. bore it out and helicoil it. screw in the bolt from the top. weld the head of the bolt to the chassis. paint over.
Old 07-05-2006, 05:55 PM   #11
theronin
theronin's Avatar
theronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfection
Send a message via AIM to theronin
man, you know its bad when Russ considers something a shitload of work. good luck man keep us posted on how its going.
Originally Posted by HalveBlue View Post
That first picture is totally bad ass.
It just screams, "Hey, I'm a fucking Christmas Tree. What are you gonna do about it?"
theronin is offline   Reply With Quote
Old 06-03-2007, 04:48 PM   #12
spinktodo
spinktodo is an unknown quantity at this point
If anyone knows how this repair went or if that stud is available from Nissan, please let me know ASAP. I broke the very same bolt tonight and I'm searching for solutions... I'm pretty pissed off but I guess it could be worse. Luckly I have a spare beater Buick for times like this, but it still sucks ass... My shells so clean and I haven't had any problems with thing seizing thus far, so I can't believe this happened...
Thanks,
Jordan
spinktodo is offline   Reply With Quote
