Old 06-14-2002, 01:57 AM   #1
jyt747
jyt747 is an unknown quantity at this point
Engine light went on and I found out it's the "EGR transducer." What is this and what do I need to get to replace it? Where is it located and is the installation easy? Thanks in advance for your help! &nbsp;Any info would be a great help! &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
'96 5 spd SE; K&amp;N intake, apexi coilovers, apexi c/f fstb, clutchmaster stage 1 w/ lightened flywheel, b&amp;m ss, 5zigen fireball, jacobs ice pak. (NOW TOTALLED, RIP)
jyt747 is offline   Reply With Quote
Old 06-17-2002, 02:30 PM   #2
jyt747
anybody?
**bump**
Old 06-17-2002, 03:39 PM   #3
Alias
Alias is an unknown quantity at this point
Its an EGR Valve ( Exhaust Gas Recirculation). Look for a tube about 1-1.5 inches coming from your exhaust and follow it. On my 91' its on the pasenger side near the firewall. Its round, maybe 2 inches?
Alias is offline   Reply With Quote
Old 06-17-2002, 04:21 PM   #4
sxfro
sxfro is an unknown quantity at this point
Send a message via ICQ to sxfro
the egr on my 98 is on the leftside near the firewall right under the intake plenum,my check engine light is on for the same thing good luck getting that tube the runs to exhaust off with out removing the plenum,if you get the egr valve off clean it with some carb cleaner,its most likely carbon buildup.
sxfro is offline   Reply With Quote
Old 06-18-2002, 02:03 PM   #5
jyt747
Thanks for the info
