Old 06-15-2002, 08:50 PM   #1
Da808aZnRaVr
Da808aZnRaVr is an unknown quantity at this point
Send a message via AIM to Da808aZnRaVr
ok i jus found out that i might have a bad O2 sensor...would anyone happen to know how much a new O2 sensor costs and if i would be able to install it myself...if i am able to install it myself would anyone be able to give instructions on how to do the install...thanks!!!
95 240sx SE,custom dual apex n1, 17" rims,tanabe sustec front STB,nismo rear STB,intake,tanabe sustec pro coilovers,autometer guages, soon to have stock 97-98 side skirts and rear mud guards and bomex drift wing
Da808aZnRaVr is offline   Reply With Quote
Old 06-15-2002, 09:15 PM   #2
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
$17.50 from the local parts store. i have a `90, and from what i remember, you have an s14. maybe someone can explain the installation in detail. it was easy for my s13.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 06-15-2002, 11:41 PM   #3
gh6o6
gh6o6 is an unknown quantity at this point
disconnect wire to o2
get the biggest vice grip you got
clamp that bitch at the bottom on the bolt looking piece
hit/bang/hammer/whatever it takes to get the thing off
tighten the new one on and connect wire
oh yeah it on the header...
gh6o6 is offline   Reply With Quote
Old 06-16-2002, 12:31 AM   #4
wherezmytofu
wherezmytofu is an unknown quantity at this point
if u want 2 make it easier on urself...just buy the oz sensor socket...it's like a 9/16 or sum shit with slice thru it for the wire &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
wherezmytofu is offline   Reply With Quote
Old 06-16-2002, 09:29 AM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
I did this yesterday. &nbsp;a 7/8 wrench works perfect for removal and installation. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> &nbsp;I got the one with the OEM plug attached so it was like $30. &nbsp;I think I ended up paying ~$10 for a rubber boot though, so.. &nbsp; &nbsp;
Do you know where it is? what do you know so we can fill in the blanks
Old 06-16-2002, 04:44 PM   #6
mr0072003
mr0072003 is a well-known jackass
I have a 95 SE and have had to replace both my 02 sensors on the header and the exhaust. &nbsp;Both were actually easy to do, good old crescent wrench but my only problem was on the install of the lower 02 sensor (exhaust). &nbsp;Apparently the o2 sensor that was installed prior had stripped the thread on the exhaust pipe. &nbsp;Bad thing. &nbsp;At this point I only had 2 options, new exhaust pipe from dealer (about 300-400 hundy) or try and find a fitting at the junkyard. Well one thing I found out was trying to find a 240 in a junkyard is a pretty rare thing. &nbsp;Personally I did not find any240 but Nissan uses the same size threading for all the sensors. &nbsp;So I bought one off an 88 Maxima, and had a shop add threading part to my exhaust. &nbsp;Labor and parts was 45 bucks.
20 for the Exhaust manifold from the Junk, and 25 for labor, ouch. &nbsp;So if you do not have any thread issues you should have no issues. BTY
Intake o2 sensor: 60-65 at the dealer. &nbsp;30 at the local part store. &nbsp;Dealer parts always recommended.
Exhaust o2 sensor - 80-85 at the dealer. &nbsp;Dealer part only
Hope this helps
Pete 95 SE &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/eh.gif" border="0" valign="absmiddle" alt=':eh:'>
mr0072003 is offline   Reply With Quote
Old 06-16-2002, 07:11 PM   #7
1997 240SX SE
1997 240SX SE is an unknown quantity at this point
Just thought I'd add that if you have an Autozone nearby you can rent an O2 Sensor socket kit for $15 and when you bring it back you get your $15 back. That socket makes it very easy for removal and installation.
1997 240SX SE is offline   Reply With Quote
Old 06-16-2002, 11:48 PM   #8
rotaryknight
rotaryknight is an unknown quantity at this point
Bosch makes great O2 sensors. &nbsp;They pretty much make one for every car.
They even have a heated 4 wire one if you ever run leaded race gas at the track.
Daily Driver- 91 240 SX SE...S13 Blacktop
HKS FMIC, EVC IV, W/G, Racing Suction, DP, Dual Drager, springs/pillow ball mounts
Whiteline sway bars
Tokico blues
Koyo Radiator, Fluidyne fan
J30 VLSD
stock exterior.
Fun Car- 94 FD3S (TO4S). The White HKS FD in FnF......may she rest in pieces.
rotaryknight is offline   Reply With Quote
Old 06-17-2002, 03:46 AM   #9
Da808aZnRaVr
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ June 15 2002,11:29)</td></tr><tr><td id="QUOTE">Do you know where it is? what do you know so we can fill in the blanks</td></tr></table><span id='postcolor'>
ok i know where the exhaust O2 sensor is cuz thats the one that my air/fuel ratio guage is hooked up too...now where is the O2 sensor on the header?...and which one is usually the first to need to be replaced?
