Old 08-03-2006, 03:56 PM   #1
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
EGR flow malfunction help
hey, what's up guys? I'm trying to diagnose my problem but I'm relatively unexperienced when it comes to diagnosing engine probs. Well, the FSM says to check the EGR lifting and releasing when increasing engine speed from 2k to 3.5k. How exactly do u know or see that the EGR valve is doing so? Isn't everything inside the EGR Valve so u can't really see what's happening? lol
thanks for the help.
shayrgob240 is offline   Reply With Quote
Old 08-03-2006, 04:25 PM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
What is it you're trying to fix that makes you think the EGR is bad?
The Exhaust Gas Recirculation valve is primarly used for emission purposes. Did your car fail smog?
The valve is located on the intake manifold, and opens a small passageway between the exhaust and intake manifold to allow a metered amount of exhaust to flow back into the engine. This reduces combustion temperatures and helps control the formation of oxides of nitrogen. The EGR valve is opened by the application of vacuum to its control diaphragm. Some also require a certain amount of exhaust back pressure before they'll open. On newer vehicles, the valve is electronic and uses one or more solenoids or a small stepper motor. The valve should remain closed while the engine is cold and at idle. It should only open once the engine has warmed up and is running at part-throttle. If the valve sticks shut (or is disconnected), NOX emissions will soar and detonation will often result (See Detonation and Spark Knock). If it sticks in the open position or fails to close all the way, it acts like a vacuum leak resulting in a rough idle, hesitation and possible stalling.
Many people get rid of it. But if you're trying to pass smog, then that's a different case.
Old 08-03-2006, 04:31 PM   #3
shayrgob240
CEL - P0400
EGR FLOW Malfunction
I would much rather fix the problem for a couple reasons
1) I like the environment
2) I sort of want to learn how to fix the prob.
thanks
Old 08-03-2006, 04:38 PM   #4
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Gotcha.
Change the vaccum hoses attached to it. You can get a pressure tester kit to see it fuctions properly. They usually have sensitive springs that actuate the diaphram and those get stuck/worn when they get old. You may need to get a new one. What year car is it? KA?
Old 08-03-2006, 04:48 PM   #5
shayrgob240
Originally Posted by ManoNegra
Gotcha.
It's a 95 and it's a KA. I did one of the tests where I took the vaccum line off the EGR and put my thumb over it. I then increased the engine speed and didn't feel vaccum at all from the EGR control valve.
Old 08-03-2006, 07:47 PM   #6
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Sounds like it's time to replace.
