Old 08-04-2006, 11:42 PM   #1
iwillbeatyouup
iwillbeatyouup is an unknown quantity at this point
oil leaks
Hey, fellas.
This has been happening for awhile now.
as you will see a pic below.
Engine Oil leaks, when my car parked... that's the ground of my garage.
front of my car under the hood.
I took it to shop, they said whole bottom is pretty wet.
couldn't really find exact spot.
they said something being too old in my car... its 14 years old :yesnod
change gasket or something...
suspect anything? that maybe I can replace with.
thanks.
iwillbeatyouup is offline   Reply With Quote
Old 08-04-2006, 11:44 PM   #2
kandyflip445
kandyflip445's Avatar
There is a dye you can put in your oil that will glow under a special light. You can use that to find the leak.
http://www.autobarn.net/tratp3400060.html Here's one source. I'm sure there is more. Look up "oil dye" on google.
My 240 vBgarage
Old 08-05-2006, 12:42 AM   #3
rsxrcr87
rsxrcr87's Avatar
rsxrcr87 is on a distinguished road
Send a message via AIM to rsxrcr87
Front main seal?
rsxrcr87 is offline   Reply With Quote
Old 08-05-2006, 12:53 AM   #4
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I had oil leaking from the fuel pressure sensor, but mine didn't leak that much. It is next to the oil filter.
Jung918 is offline   Reply With Quote
