Old 08-20-2006, 02:22 AM   #1
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
Magnetic bearings?!
I found some info on magnetic bearings.
Originally Posted by SFK
The fact that a rotor spins in space without contact with the stator means drag on the rotor is minimal. That opens up the opportunity for the bearing to run at exceptionally high speeds, where the only limitation becomes the yield strength of the rotor material.
At Revolve, magnetic bearings have been designed with surface speeds up to 250 m/s or 4.5 million DN, where DN is the diameter of the rotor (mm) times the rotational spend (rpm). In order to achieve one quarter of this kind of speed with conventional bearings, a complex lubrication system is required.
No other type of bearing, can match magnetic bearings for shear speed.
Magnetic bearings open new possibilities for extreme high-speed applications such as machine tool spindles and turbo compressors.
if in corporated into turbos, spool time could be reduced and oil lines a thing of the past!!
undesiredshoe is offline   Reply With Quote
Old 08-20-2006, 04:33 AM   #2
yokotas13
yokotas13's Avatar
wowzers i want one
yokotas13 is offline   Reply With Quote
Old 08-20-2006, 08:45 AM   #3
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
They use this same technology on the worlds fastest "subway" train. But instead of oil lines you'd still have wires, and it would have to run on a 12-volt system. It would be interesting to see what develops.
spdfreek0o is offline   Reply With Quote
Old 08-20-2006, 01:30 PM   #4
undesiredshoe
Yea, one of the cons they stated is that you'll need to use electricity and the bearings would have to be bigger in size
Old 08-20-2006, 02:44 PM   #5
LB.Motoring
LB.Motoring's Avatar
yah an electro magnetic bearings FTW
Robby Leuer
Old 08-20-2006, 05:56 PM   #6
badboy6686
badboy6686 is an unknown quantity at this point
yes! now you won't blow your turbo becuase of a busted oil line, instead you'll blow it because of a blown fuse lol
badboy6686 is offline   Reply With Quote
Old 08-20-2006, 08:38 PM   #7
S14DB
AFC #1
S14DB's Avatar
What about the magnetic field drag? on the opposite end of the push their is a pull. Think how electric motors work.
Old 08-20-2006, 09:50 PM   #8
LB.Motoring
^ thats why it needs power... like "running" and electric motor..
Robby Leuer
Old 08-20-2006, 11:16 PM   #9
undesiredshoe
and pretty soon we'll have magnetic rod bearings, magnetic wheel bearings....everything will depend on electricity
hah i wish
