Old 08-21-2006, 05:58 PM   #1
ihateme4u
ihateme4u is an unknown quantity at this point
Need input on my KA-T setup
My setup looking to run soon:
JGS Starter Kit t3/t4 .63a/r
AMS Fuel System
Greddy V-SPL FMIC
Blitz BOV
Megan Racing SR Downpipe
Test Pipe
Autometer gauges
Apexi N1
Apexi SAFC II
ECU tuned by Enthalapy
Ka24de currently in the car has 119k, looking to push out around 300hp at least. Im open for suggestions/concerns on how i should go about this project and also what size injectors should i look for.
ihateme4u is offline   Reply With Quote
Old 08-21-2006, 06:37 PM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Look up some of the other KAT builds that have been done here. That can prove helpful. Read the FAQs. 500cc injectors should be enough.
Lots of info at ka-t.org aswell.
Old 08-21-2006, 06:38 PM   #3
ihateme4u
yea i posted on ka-t too, but i just wanna see what everyone thinks
Old 08-22-2006, 03:33 AM   #4
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Greddy V-SPL FMIC
Blitz BOV
Autometer gauges
Apexi N1
Apexi SAFC II
NO. This stuff is JUNK.
Maeda is offline   Reply With Quote
Old 08-22-2006, 08:31 AM   #5
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
if your looking to buy all of that expensive shit, then why skimp out on engine management, its not the parts that keep u from blowing up and making reliable power its the tune. So if i were u i'd look into an emanage, megasquirt, or bikirom setup
Slip Gypsies Blog
not sure if you realize this
Old 08-22-2006, 12:07 PM   #6
Maeda
Maeda's Avatar
You sir have no idea what you're talking about.
Enthalpy ECU + SafcII is a perfectly viable option.
Keep in mind the most expensive shiny shit out there isnt always the best.
Old 08-22-2006, 01:04 PM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
and you'll need:
-at least 550cc injectors
-fuel pump
I reccomend:
-maybe at least a blaster coil otherwise you might get blow out at the PSI you have to run for 300rwhp.
-metal headgasket (cometics are the shit!)
Old 08-22-2006, 01:28 PM   #8
ihateme4u
Originally Posted by NemeGuero
and you'll need:
-fuel pump
I reccomend:
yea from other forums alot told me 550 would be a good choice, and also the fuel pump, i forgot to put that in the list since it is a option in the ams fuel kit. Anything else would i need?
Old 08-22-2006, 01:31 PM   #9
NemeGuero
No more nissan.
NemeGuero's Avatar
No, I think that should be okay.
Upgrade your cooling of course.. and possibly look into an oil cooler.
Most turbo cars come with an oil cooler since (obviously) they run hotter.
As long as you have proper fuel delivery and ignition to match.. your set-up will be fine.
Old 08-22-2006, 03:21 PM   #10
punxva
punxva's Avatar
Trader Rating: (31)
im saying that he needs to not focus as much on brand names and that the tune is more important to keep it up longer, he could also use the JWT ecu
Slip Gypsies Blog
Old 08-22-2006, 04:25 PM   #11
KoukiJAR
KoukiJAR is an unknown quantity at this point
He couuuullddd use a JWT ecu....but i think he made the right choice by going enthalpy
KoukiJAR is offline   Reply With Quote
Old 08-22-2006, 05:10 PM   #12
undercoverdjay
undercoverdjay is making a name for him/her selfundercoverdjay is making a name for him/her self
Send a message via AIM to undercoverdjay
Enthalpy tuned ECU's are known to run rich, an SAFC will help out with this, also, a wideband O2 sensor (with a narrowband output preferably) and an A/F ratio readout is a MUST. SAFC's will help configure a lot seeing how a pretuned ECU is just that, a generic off the shelf tune that wont work 100% with your setup.
A tuned ECU, plus an SAFC 2 will help fine tune anywhere the ECU is lacking. My KA-T setup went together flawlessly with a stock automatic ECU (slightly more richer than a 5 speed) and an SAFC/ LC-1 wideband for managment. Also get around 30mpg off boost on the low throttle map.
undercoverdjay is offline   Reply With Quote
Old 08-22-2006, 05:19 PM   #13
NemeGuero
No more nissan.
NemeGuero's Avatar
except SAFCs suck
Old 08-22-2006, 06:07 PM   #14
undercoverdjay
ok, how exactly does an SAFC suck? if you have the money its an execellent way to fine tune a shitty tune. SAFC's suck only if you have no clue how to use it.
Old 08-22-2006, 06:14 PM   #15
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
he means that SAFC's are only bandaids for an already inadequate tune.
he's anal hahahaha
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 08-22-2006, 06:21 PM   #16
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
I can get a tuned ECU for the price of a used SAFC =]
So SAFCs suck...when theres somthing better and cheaper...unless you want the lil cool safc and the shiney buttons! OMG!!
TipStylez is offline   Reply With Quote
Old 08-22-2006, 06:23 PM   #17
TipStylez
Wait, is that possable? a AUTO ECU working on a 5speed car?
Old 08-22-2006, 06:24 PM   #18
NemeGuero
No more nissan.
NemeGuero's Avatar
bandaids on top of bandaids..
You have to realize that changing the AFM signal to the ECU (which is what an SAFC does) also changes other readings that affect each other in a not-so-good way.
and yes, you can use an auto ECU on a manual car.
Old 08-22-2006, 06:31 PM   #19
EchoOfSilence
:k eke:
Old 08-23-2006, 08:33 AM   #20
undercoverdjay
Auto ecu = no speed limiter/ 5 gear rev limiter
SAFC works fine for my every day daily driving and occasional "spirited" driving
My car throws a happy code of 55, and my A/F Ratios stay 15:1 off boost and 11.5-12 on boost. I think the SAFC is doing its job well.
I understand they're more of a bandaid on a broken leg sort of fix, but they work fine.
For me it's about adjustability so when I sell my SAFC at the end of the season and buy a bikirom, then we'll see how a pre tuned ECU fairs against that. On the other hand, if someone has no fucking clue how to use an SAFC or any kind of adjustable management, a plug and play pretuned ECU might just be the way to go.
At least you went with KA-T, hehe
www.ka-t.org is the only place for tech advice on the KA's, I caught some shit because I have both an SR and a KA-T, but they're an awesome bunch and some people are putting down some SICK numbers for not a lot of money.
