Old 08-22-2006, 08:52 PM   #1981
McRussellPants
Caster will fix fire wall, hammer will fix front tub.
McRussellPants is offline
Old 08-22-2006, 09:30 PM   #1982
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
Wonder how low I can go with 15's and full aero without my shit breaking off right away
Drift Indy
Edgar is offline
Old 08-22-2006, 10:04 PM   #1983
nisans13turbo
nisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nice
You will be plowing the kids off the streets with your front bumper on 15's + aero.
nisans13turbo is offline
Old 08-22-2006, 10:24 PM   #1984
Z3NK1
Z3NK1's Avatar
Z3NK1 is an unknown quantity at this point
Originally Posted by phreze
another lol, 17's though
Z3NK1 is offline
Old 08-22-2006, 10:35 PM   #1985
Edgar
Edgar's Avatar
i figured what about version II with some 16's
Drift Indy
Edgar is offline
Old 08-23-2006, 01:11 AM   #1986
2iv0 sx
2iv0 sx's Avatar
2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute
damn those wheels are turnin into the next FNs.. i had my mind set on em too
PS- Z3NK1 sideskirts please
2iv0 sx is offline
Old 08-23-2006, 06:32 AM   #1987
TheTimanator
TheTimanator's Avatar
ha, my car is gonna just like yours Z3NK1 except I'll still be on 15's for a while.
TheTimanator is offline
Old 08-23-2006, 06:58 AM   #1988
P4rD0nM3
P4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of light
Timanator, join the group then. Rofl.
Zenki + Chuki/180 Side + Kouki Rear...Rofl. Classic. I be the red, Z3n be the white and you be the grey.
P4rD0nM3 is offline
Old 08-23-2006, 07:56 AM   #1989
mr_240sx
mr_240sx's Avatar
how much caster would i need? i know its a vage question but i dont really know what caster does so thats why..... caster move the wheel towards the front of the car?
mr_240sx is offline
Old 08-23-2006, 11:22 AM   #1990
axiomatik
axiomatik's Avatar
google, my friend:
Alignment Terms Explained
axiomatik is offline
Old 08-23-2006, 11:27 AM   #1991
naed240sx
naed240sx's Avatar
naed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the rough
How much castor? Depends on how low you are and how much of a problem you have with hitting the wiring harness or firewall. With my kts on full low and 235/40s and stock castor, I had no problems with hitting the harness. This is because I relocated it to the engine bay, and made a custom plate covering the small portion of it that went from the firewall to the hole leading to the engine bay. The plate kinda tucked the harness flush against the firewall, and I never even rubbed the plate. Again, this was with only like - 7.5 degrees castor (stock at that ride height).
Castor is the measure of the inclination of the strut when viewed from the side of the car. Castor determines the amount of camber gain per degree of steering angle. The more castor you have, the more camber you have at full lock.
I'm running like 8 degrees castor with my spl rods, but could go up to around 9.5. I have tons of firewall clearance now.
Buy yourself some adjustable front tension rods and just play around with the settings untill you find one that gives you the clearance you want.
naed240sx is offline
Old 08-23-2006, 11:44 AM   #1992
McRussellPants
Originally Posted by 2iv0 sx
damn those wheels are turnin into the next FNs.. i had my mind set on em too.
Nah, Poor people can't sling the 600$ difference over FNs so I think I'm safe.
Old 08-23-2006, 12:21 PM   #1993
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
plus you wont see the xd9 on many hondas and random cars too. i saw a tacoma with fn's.
caster pulls your wheel forward (more of it). if your doing this just to not hit the wiring harness, you stupid. just relocate it. all you have to do is pull the fender and ziptie it up higher.
adding caster will also lower your car, and change the rest of your alignment, it will add - camber, and toe out (i beleive for the toe, couuld be wrong).
if your car just parks around, and you drive it to the mall and back it doesnt even matter, if you drive it you might want an alignment after you add caster.
you can run between like 6 and 11 degrees of caster. when i was really low i had 11 on one side lol. try like 8-9, then youll need to hammer the front of your fender area. id recomend doing this when your fender is already off for the wiring, just to be safe
driftparty.com
hitman is offline
Old 08-23-2006, 12:48 PM   #1994
chmercer
chmercer's Avatar
18s are different.
To be low on 18s on an S13 you have to stretch and sink or have retarded spring. Id imagine the only way I could clear 18x10 +0 that it would have to be would be with a 215/40 or something wack like that. 18x9 I could clear with a small tire, but 18x9 XDs look wack.
Its impossible to keep wide 18s out of the front on S13, lindsay breaks/broke tie rods/has tire rammin into everything, D-money is running 2in of preload and his tires still clearance into the fender. Fukada shows on 18x10 up front but still runs 17x9 on the track.
18s up front is rough, and I didn't want to deal with it and I like the way 17/18s look.
wrong
225/45/17 is like exactly the same rolling diameter as 225/40
lindsay broke shit cause he would hit his firewall on lock which is easily fixed with caster
darnells wouldnt rub if he had more camber
i dont know who fukada is so i have no retort for that
also big hammer > fender tub
LOL my rep "chmercer is a glorious beacon of light"
chmercer is offline
Old 08-23-2006, 01:08 PM   #1995
TheSquidd
TheSquidd's Avatar
Alright, well here's a question for you lowies.
My front end rubs on 17x9 +19 MB gay wheels with 215/45/17's when I drift on anything but a flat surface. It rubs well enough to fuck up a drift, and I have an event coming up I don't want to be dealing with this AT the track. Soo...
Should I:
A. get 40 series tires (205? No cheap 215/40/17's I can find)
B. Lift the front up a bit
C. Just keep sledging the wheel wells (it doesn't seem to be doing anything anymore. I think it's sledged out.)
D. Adjust my tension rods? Should this be done by a professional alignment shop or should I just do it ghetto style like everything else.
E. Eat crap and die.
TheSquidd is offline
Old 08-23-2006, 01:21 PM   #1996
Flybert
Use 235/40/17 up front and whatever else you have out back. When you are done at the end of the day, put the 235/40/17 out back and the 215's up front but make sure you have enough room for them back there or just dial in the camber to clear.
Flybert is offline
Old 08-23-2006, 01:36 PM   #1997
VROOOM
VROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfection
I had FN's on my civic but they were forged! who has actually had the forged FN's???
VROOOM is offline
Old 08-23-2006, 02:14 PM   #1998
Hailtothesilvia
Hailtothesilvia's Avatar
Hailtothesilvia is making a name for him/her selfHailtothesilvia is making a name for him/her self
Send a message via AIM to Hailtothesilvia
Should I:
F. get wider fenders
G. i got my 215/40/17 ST115 from Discount tires for I think $85 shipped, reasonable enough
TAOspeedwagon II
Hailtothesilvia is offline
Old 08-23-2006, 02:16 PM   #1999
TheSquidd
TheSquidd's Avatar
H. I don't rub the fenders. I rub the firewall / wheel wells. ^_^
Old 08-23-2006, 02:21 PM   #2000
Yuri
Ghost of Zilvia past
Yuri's Avatar
XD9's are more like the new Work Emotion CR Kai if anything. (I have a feeling Agle Minerva's will be the rich man's XD9 soon enough....)
Yuri is offline
Old 08-23-2006, 02:37 PM   #2001
Sean
Sean is an unknown quantity at this point
your tire is too tall.
Sean is offline
Old 08-23-2006, 02:40 PM   #2002
Flybert
So are they bringing them back?
Flybert is offline
Old 08-23-2006, 02:41 PM   #2003
TheSquidd
TheSquidd's Avatar
Thanks! I will take your recommendation and get some 215/40/17's for the event!
Old 08-23-2006, 02:56 PM   #2004
Dousan_PG
Dousan_PG's Avatar
no they arent haha
i think minervas weighed a pretty penny too
its been a while since i lifted some up
anyways minervas are discontinued
and havent heard anything about them coming back
finding good sizes is rough!
Aaron
Pink GodziRa
Dousan_PG is offline
Old 08-23-2006, 03:12 PM   #2005
Yuri
Yuri's Avatar
haha, what I said was based on the interest that Minervas seem to be getting all over the place now, and wheel company's historys of bringing back styles that have become popular and sought after even after they were discontinued.. i.e. SSR with the reverse mesh, alot of stuff here at work, etc.
Yuri is offline
Old 08-23-2006, 03:19 PM   #2006
CrazyIvan
CrazyIvan's Avatar
CrazyIvan will become famous soon enoughCrazyIvan will become famous soon enoughCrazyIvan will become famous soon enoughCrazyIvan will become famous soon enough
I fixede that w/ a 5lbs hammer and some elbow grease
powder-coated.com - I do Custom Powder Coating
CrazyIvan is offline
Old 08-23-2006, 03:22 PM   #2007
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Big hammer fails when your car is too low. I rub quite a bit on top and on the firewall. But the firewall rubbing is due to my small amount of caster, should be changed soon. I have 235/40/17 up front and not going smaller or bigger, rubs up top but probably going to raise the car slightly.
PROCEED
Grip Gambler
KiDyNomiTe is offline
Old 08-23-2006, 03:26 PM   #2008
Irukandji
Should I:
I have the same wheels on front and had the exact same issues.
I just spent an hour or two pounding the living shit of the inner fender wells. Get all the little tabs that are sticking out as well above and behind the wheels. After you're done pounding the fender well in, do it some more.
After that I just lightly spray painted over all the spots that I pounded in, and checked it a week later. If the paint rubbed off, you gotta pound that spot in some more.
BTW I'm running 225-45 which are kinda fat, but it will clear with proper alignment and fender banging. Try getting your caster set at 7 at a race alignment shop.
Irukandji is offline
Old 08-23-2006, 03:39 PM   #2009
phreze
phreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of lightphreze is a glorious beacon of light
Send a message via AIM to phreze
Yeah xd-9s will be pop because you can get biggest sizes and lowest offset in 4 or 5 lug. I haven't seen any around me yet and if I only see 10 people with them online who cares? Plus if they ever start becomeing common I will switch wheels or custom powdercoat them.
What size/brand tires are you other xd-9 people running? I'm rocking 215/45/17 f and 235/40/18 r. Might move up to 235/40 in the front next time.
"If you rock knock-off, you are part of the problem" -myself
phreze is offline
Old 08-23-2006, 03:43 PM   #2010
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
That's my problem too. I rub up top. I pounded the wheel wells, and they're fine now. That was an 18x8.5 +25 with a 225/40.
upSLIDEdown is offline
