Old 09-02-2006, 02:21 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Need EMEDIATE KOUKI side skirt install help!!!
I'm trying to put my kouki skirts on my zenki. I'm having a small fitment issue in the FRONT. At the VERY FRONT of the skirt, where it wraps around the fender there is a little tiny lip. That lip prevents the skirt from sitting totally flush when i pull the skirt all the way tight.
If i leave the little lip where it LOOKS LIKE it should go, i have a quarter inch gap between the fender and the front of the skirt. Its hard to expain, but heres two pics.
Basically i'm wondering, IS THERE A SPACER OR WASHER that goes BETWEEN the skirt and fender where it is bolted together, or should i just shave that little lip off and slide the skirt back more???? PLEASE just look at your car for sec!!! THANKS!
gotta240 is offline   Reply With Quote
Old 09-02-2006, 03:50 PM   #2
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
When I yanked off my mudguards, I ended up with that space in the front too. Basically, I think you have that gap because you're missing the mud/splash guard like me. If you're picky then trim it, but then you'might have it sticking out a bit further at the rear.
WilloW is offline   Reply With Quote
Old 09-02-2006, 03:57 PM   #3
SimpleS14
SimpleS14's Avatar
That's odd, I don't have such a gap. I have the fender liner and a gromment (OEM bit) on the front and it fits just fine.
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 09-02-2006, 04:54 PM   #4
WilloW
WilloW's Avatar
Exactly, when I had my liner in place everything was fine. That so called lip is there to accomodate for the space that the liner takes up.
Old 09-02-2006, 05:41 PM   #5
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
no spacer, no washer, i dont have any fender liners or anything on and its flush... are you sure your installing it right? the small clip goes on the rear of the car for the end cap.. for the front use the lower skrew that your fender liner uses.
Sfourteen
dct223 is offline   Reply With Quote
Old 09-02-2006, 06:13 PM   #6
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
mine has no gap at all.... I have put it on w/ and without the clip for the endcaps, and it doens't make a huge difference. maybe you don't have the skirt fully pushed into the endcap?
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 09-02-2006, 06:26 PM   #7
gotta240
Thank you guys all VERY MUCH for the quick help.
Thats wierd that some have it perfect without the mudguards and some dont. SHIT.
To those who say "push it back". Do you see the little tiny "lip"? If i push everything back, that lil lip will be touching the fender, and will push the skirt OFF the car like 1/8 an inch... Kinda see what i mean?
ANyone else have NO muguard, or any other suggestions?
Old 09-02-2006, 09:24 PM   #8
DaPCWiz
DaPCWiz's Avatar
maybe the skirt was damaged and repaired? sand the "lip" down and make it fit... mine doens't have the "lip" that I think ur talking about...
Old 09-03-2006, 08:23 AM   #9
projectRDM
projectRDM's Avatar
Slide the entire skirt back towards the rear of the car 1/8 inch. It's not rocket science man.
Old 09-03-2006, 08:43 AM   #10
DaPCWiz
DaPCWiz's Avatar
from my understanding, if he pushes it back, there is a little nub at the 90 degree corner of the skirt, which he is calling a "lip". When he pushes it back, this nub offsets the end of the skirt from the body 1/8" or so. I suggested sanding down that nub as I don't think it should be there...
Old 09-03-2006, 02:21 PM   #11
gotta240
DaPCWIZ- THANK YOU. Will do.
And rocket science boy- No its not, but seeing how i dont have a spare set laying around, i dont know what should and shouldn't be on the skirt.
Old 01-10-2007, 08:21 PM   #12
redpotatoes
redpotatoes's Avatar
redpotatoes is on a distinguished road
I am a little late on this post but instead of recreating one I'll ask here.
How did you proceed for the install ? (from kouki to zenki) Needed to drill in the rockers ? Have you bought new plastic clips ? Used double side tape ?
You mention no mudguard, I have them, can they still be install afterward or not(I don't think they will fit). I think it would look better without but just want to know.
***Got my answer on other post****
redpotatoes is offline   Reply With Quote
