![]() Join Date: Mar 2003
![]() ![]() Feedback Score: 1 reviews
HELP: After Z32 Caliper install
ok..i installed the z32 calipers on my 240sx..and then i bleed each caliper twice and still i have this problem..nothign happens until the petal is nearly almost to the ground..im using stock 5spd MC but should it have this big of a difference?
-Cherry Red 91 Silfourty- ![]() |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
did you bleed your ENTIRE brake system??? if you didnt then thats your problem
Rear right, rear left, front right, front left...
Sfourteen |
bleed it again, and bleed the m/c too.
if they are junkyard calipers they could be fucked. alternatively, your master cylinder could have gone to shit if its an old one. wouldn't be the first time. |
calipers are on the right side..and i picked them up at NAPA..im thinkin its the master cylinder..but its juss that when i had the oem brakes on before..they they were breakin fine..bleeding the MC..haven't tryed that..tho that my be a problem because i've never and don't know how to bleed it....i juss know how to bleed the clutch...btw thanx for all these quick replies
![]() Join Date: Feb 2002
How did you bleed your brakes? Besides the order calipers your suppose to bleed in...did you build pressure on the pedal?
After I did mine, I stepped all the way on the pedal when bleeding the brakes...which was causing the brakes to work only when the pedal was almost to the ground. So second time around I stepped only half-way or where I would like the brakes to start grabbing and that solved my issue.
Goals are dreams with a deadline. L.H.O.O.Q. |
![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
^correct me if I'm wrong, but isnt the order, left rear, right rear, right front left front? I think thats how it is, and thats how I've awlays done it.
heh i did the proper order....but stepping it half way?..i could try to see if that works..juss thoguht some air mite stay in if i did it half way..
im not sure of the correct order.. but i always thought it was furthest away from the MC to the closest to the MC... thats what i did on my car and it worked...
Sfourteen |
#13 | |
Then that is what your missing...you have to do this to build resistance (or pressure) within the brake system. You won't get any air in your system given you keep your foot down half-way and whoever is underneath tightens the bleeder screw once all the air is out. BTW....for a solo job I highly recommend speed bleeders. I have a set and I did the job faster than with two people.
#15 | |
![]() Join Date: Oct 2005
#17 | |
![]() Join Date: Jan 2006
Make sure that the bleed valves are not on the bottom side of caliper. If they are, you need to switch the sides the calipers are on. I wouldn't be suprised if this was the problem. ![]() If thats not it, try bench bleeding the MC and use teflon tape on all of the fittings between the hard lines and flex lines. |
#18 |
![]() Join Date: Sep 2003
im bettin that the bleeders arent up hence the issue... calipers are on the wrong side...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#20 |
pedal..lol..ok thanx! anyways..yes its UP...heh the calipers are on the right sides..imma try the half step and then if that doesn't work then imma try adjusting the rod tomolo...thanx..and hopefully i'll get this fixed..
btw..mephisto...great sig..yours?
#21 | |
![]() Join Date: Mar 2002
my picture (i took it) but not my car.
It belongs to the boss of a friend of mine. Keep an eye out for a big fat fucking pic thread coming soon.
#22 |
i ended up buying a reverse pump with a container thing at a local kregan store..pumped out the air and got it done...i know there were the other ways..but..i had enough..and bothering some one to help me out was a pain..but with this...all it did was it sucked out the air outta the system pretty much a recycle device..anyways thanx for all your help!
#25 | |
#26 |
I dont have quite his problem but similar. Got the R33 GTS-T's fronts on only. (still waiting on parts for the rears) A little concerned. The pedal has some travel to it. Unforunately I had to make an emergency stop (figures, hrs after I did the install) And the pedal travel was hesitat and pretty soft. It did stop though. They stopped fine in normal crusing mode but that emergency stop took some time.
The only thing I didnt do was bleed the master cylinder should this be done? How do you do it? Also I didnt blead the intire system. I just did the front calipers I swapped. Could this be the problem as well? thanks.. |
#27 |
![]() Join Date: Apr 2004
when i first bled my old Z32 calipers it was kinda soft and mushey, then i got super blue fluid, ends up it takes LONG AS HELL to do a complete flush of the system. and i found out that supposidily due to the way the lines are run the correct bleeding is cycle is lt rear, rt rear, rt front, lt front. it's all about getting massive amouts of air out of the system.
#29 |
![]() Join Date: Aug 2003
for s13 nonABS, u want to bleed from the left rear first as tenchuu stated because it is the farthest line from the MC.
our hard lines come down the right frame rail and then split for the rear left and rear right calipers. The rear left is farthest away from the MC (not physically, but if you follow the hard lines, it is)
