Old 10-03-2006, 08:01 PM   #1
CSXTacy
CSXTacy's Avatar
CSXTacy has a little shameless behavior in the past
Fuel rail dry as a bone!!! help!!!!
ok i just returned from working on a buddy of mines 89 coupe he just put a SR in. we got to crank the engine and it cranks but doesn't start fuel pump is priming and there is fuel at the Fuel Pressure Regulator but when we remove the fuel pressure regulator from the fuel rail, it is dry as a bone inside the fuel rail as if there is no fuel getting past the fuel pressure regulator. so with the regulator removed from the fuel rail we tried cranking the engine again and still no fuel was comming out of the fuel port that goes into the fuel rail. we removed the return fuel hose and it was dry as a bone as well. the vaccum port we are using for the FPR is the top smaller port off the throttle body. is there any tests to tell if the fpr is faulty?? how much fuel should be flowing through the regulator while in crank??? the vehicle will run when shot with starting fluid through the throttle body but as soon as the starting fluid is gone the engine dies! any other suggestiions??? i searched the archives and could not find any fuel problems that relate to my situation so any insight or maybe a link to a previous post concerning this problem would be greatly appreciated.
CSXTacy is offline   Reply With Quote
Old 10-03-2006, 08:55 PM   #2
projectRDM
projectRDM's Avatar
Nice one sparky. That's just pathetic.
Fuel hoses are backwards. The FPR is on the return side, not the feed side.
Old 10-03-2006, 09:30 PM   #3
steve shadows
steve shadows's Avatar
yes, or if his fuel pump is gone...or maybe the fuel tank is full of xtacy...
whatever
stop smuggling noob
seriously tho is there any fuel at all coming out from the line from the pump?
Like Me on FaceBook !
Old 10-03-2006, 10:04 PM   #4
CSXTacy
CSXTacy's Avatar
duh
yea there is fuel pressure at the regulator but it just does nothing when i turn the key to on position i hear the pump prime but no fuel gets past the FPR the hose comming from the fuel filter is the one connected to the fpr
Old 10-03-2006, 11:27 PM   #5
Nuisance Crew
Nuisance Crew is an unknown quantity at this point
Um that was your answer, fuel pump, to fuel filter, to fuel rail, to fpr, to return line
Nuisance Crew is offline   Reply With Quote
Old 10-03-2006, 11:41 PM   #6
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
what a dumb ass
95zilvia is offline   Reply With Quote
Old 10-04-2006, 09:48 AM   #7
projectRDM
projectRDM's Avatar
FUEL HOSES ARE FUCKING BACKWARDS
What part of that wasn't clear?
Old 10-04-2006, 10:05 AM   #8
HyperTek
If the fuel lines was hard to figure out, id hate to see how the wiring was done =x
Keep it Classy
Old 10-04-2006, 10:08 AM   #9
Gnnr
Gnnr's Avatar
lmao @ R240NA post
Gnnr is offline   Reply With Quote
Old 10-04-2006, 01:45 PM   #10
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
so what you guys are saying, is the fuel lines are backwards? :hammer:
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 10-04-2006, 05:28 PM   #11
mrmephistopheles
mrmephistopheles's Avatar
No no no, obviously it's not clear to anyone that the FUEL LINES ARE BACKWARDS.
Originally Posted by PHLIP
Old 10-04-2006, 05:40 PM   #12
95zilvia
Maybe the fuel lines are backwards.
Or. it could be the fuel lines are backwards.
Or in a really weird case, that you put the fuel lines backwards.
Check to see if the fuel lines are backwards, and if they are,
then the fuel lines are backwards.
If you check everything and can't find out what's wrong, double check the fuel lines again to make sure they aren't backwards.
Old 10-04-2006, 06:49 PM   #13
ThatGuy
Admin Asshole
ThatGuy's Avatar
SENIL LEUF
If that's too subtle for you... the fuel lines are backwards.
Old 10-05-2006, 11:28 AM   #14
BC240
BC240's Avatar
BC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enough
Make sure your blinker fluid is full
BC240 is offline   Reply With Quote
