Old 12-30-2001, 05:48 PM   #1
tarp
tarp is an unknown quantity at this point
My 240SX has about 49k on it (its a 97 SE) and the warranty is going to end in May. I heard the timing chain guides occasionally go bad around 60k miles, is this something I should worry about?
tarp is offline   Reply With Quote
Old 12-30-2001, 05:53 PM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
60K is when you should service it. Watch for tiny little clatters, if you hear them, rush to the dealer and have them replace the chain. They have to do it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>. They did it on my boyfriend's car (he had 65K when they'd done it. the upper guide had gone bad, so they replaced the whole chain). Do it before the warranty expires, it's SOOO expensive.
S13Grl is offline   Reply With Quote
Old 12-31-2001, 09:36 AM   #3
RoNx777
RoNx777 is an unknown quantity at this point
S13Grl is rite, i have an 97 model also (jus not SE) i check an i think the chain itself is about $400. So i would get it check if i wuz you.
RoNx777 is offline   Reply With Quote
Old 12-31-2001, 09:45 AM   #4
Nismos14
Nismos14's Avatar
Nismos14 is an unknown quantity at this point
is there any upgrade for the timing chain?
Nismos14 is offline   Reply With Quote
Old 12-31-2001, 03:17 PM   #5
FastNissan
FastNissan's Avatar
FastNissan is an unknown quantity at this point
Send a message via Yahoo to FastNissan
My timing chain didn't go until about 98k, I have an S13 but the timing chain setup is the same exept for the part that broke on mine they simply quit using in 95 and no longer make or sell the part. I swapped the chain myself, it is a dificult job, especially remounting the oil pickup.
(Edited by FastNissan at 5:59 pm on Dec. 31, 2001)
FastNissan is offline   Reply With Quote
Old 12-31-2001, 07:35 PM   #6
chickenmanq
chickenmanq is an unknown quantity at this point
Here's a question: &nbsp;Do the ka24e's have overhead clearance for the valves? &nbsp;I'm approaching 85,000 on my pickup, and I'm not planning on the timing chain being done until I get around to it (100,000 or so) or it breaks.
chickenmanq is offline   Reply With Quote
Old 01-01-2002, 01:40 PM   #7
FastNissan
FastNissan's Avatar
I'm not sure, but I can tell you that a Porsche 944 doesn't.
<a href="http://porsche-944-garage.tripod.com/tensioner.html" target='_blank'>http://porsche-944-garage.tripod.com/tensioner.html</a>
(Edited by FastNissan at 2:23 pm on Jan. 1, 2002)
(Edited by FastNissan at 2:25 pm on Jan. 1, 2002)
Old 01-01-2002, 01:57 PM   #8
tarp
What kind of noise would I check for to tell if the guides are going bad? Is it something persistant at all times, or a noise that subsides while driving...?
Old 01-01-2002, 02:15 PM   #9
FastNissan
FastNissan's Avatar
There is a clicking noise, it is always there it is just harder to hear when you are driving.
Old 01-01-2002, 09:51 PM   #10
tarp
I heard that violent shaking of the engine when you first start the car up for about 20 seconds, is also an indication of a timing chain problem. I've had this problem 2 or 3 times before, mostly in the summer, after washing my car, so I believe it has to do with a lot of moisture/humidity, is this weird or what? I havent had the problem at all recently.
Old 01-02-2002, 08:07 PM   #11
FastNissan
FastNissan's Avatar
I don't think that it is a timing chain problem, it probably does have something to do with the moisture.
Old 01-30-2002, 07:38 PM   #12
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from tarp on 9:51 pm on Jan. 1, 2002
</td></tr></table><span id='postcolor'>
tHAT IS FROM MOISTURE ON THE DIST. CAP. I THINK
Old 01-30-2002, 08:14 PM   #13
tarp
Thanks,
That makes sense.
