Old 01-30-2002, 01:43 PM   #1
luke20
luke20 is an unknown quantity at this point
It seems to me there is a lot of debate when is comes to the topic of a rebuilt motor in a street car.  A lot of people have said that a rebuilt motor (pistons, rods, sleeves, bottom end stuff) makes a bad street car, and can not tolerate stop and go driving.  Some say they burn oil, are noisy, and are just shitty until they warm up.  is there any truth to that?
luke20 is offline   Reply With Quote
Old 01-30-2002, 03:42 PM   #2
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
not true... it should not burn any oil........
you will have higher compression if u upgrade rods and pistons......
i would imagine the parts be stronger......
drifterx is offline   Reply With Quote
Old 01-30-2002, 04:28 PM   #3
luke20
I wouldn't think there would be any problem with driving a built motor daily, but I guess the argument is that since the pistons are forged aluminum, and the cylinders are usually ductile iron, there's two different rates of expansion, and in order to keep pistons from actually rubbing against the inside of the cylinders, large ring clearances are needed.  This causes the oil blow-by and the noise, when the engine is cold.  When the engine is warmed up, the proper ring clearances are met.  Weather there is any truth to that, I don't know.  Any opinions?
