Old 10-25-2006, 03:07 PM   #1
Jimmy Up
Zilvia.net GB Vendor
Jimmy Up's Avatar
Trader Rating: (52)
Feedback Score: 52 reviews
check engine light w/ gas
heres the deal, every time i go to put gas in this 89 240 after about 30min-1 hour the check engine light comes on for about 2 hours maybe more sometimes then goes off as im driving. can anybody shed some light on what might be wrong here. Thanks
Old 10-25-2006, 03:15 PM   #2
shuey_89240sx
shuey_89240sx's Avatar
shuey_89240sx is a well-known jackass
i don't know if this would set off the check light but...do you top it off every time you fill up because if you do then your float might be going out. but other than that hook up scan tool to your obd and see if it's got any codes
'89 240 hatch
'89 240 hatch
1995 pontiac firebird LS1 trade for you 240 call for info. (217) 251-3054
painters get all the chicks
shuey_89240sx is offline   Reply With Quote
Old 10-25-2006, 11:14 PM   #3
projectRDM
projectRDM's Avatar
SOHC cars don't have an OBD plug smart guy, nor do they have a CONSULT port.
Old 10-25-2006, 11:40 PM   #4
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
so nobody knows what i should do???
Old 10-25-2006, 11:58 PM   #5
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
Other than take your car to Auto Zone and let them pull the code(s) or pull the code(s) yourself......keep driving like usual....it is fairly common for the check engine light to play peek a boo every now and then.
Rayne is offline   Reply With Quote
Old 10-26-2006, 12:01 AM   #6
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
that sounds like the case here- thanks bro, appreciate the help.
Old 10-26-2006, 12:03 AM   #7
SlappieBooBoo
SlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choicesSlappieBooBoo has made poor choices
yes...go to kragen autozone what ever....get a scanner...and check the code to see whats wrong...we can't plud into your car sooo its hard for us to say with out the code...my guess is small evap leak or someshit like that
SlappieBooBoo is offline   Reply With Quote
Old 10-26-2006, 12:05 AM   #8
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
can they still pull a code even though its the 89 sohc?
Old 10-26-2006, 09:47 AM   #9
SlappieBooBoo
yeah...he was just wanted to get his post count up and didn't really explain....i don't know for sure so you might wanna do a little searching...but you can pull a code out of your consult port...and odb I port does other shit too i assume...hope this helps dude...seriously just got down to where ever scan it and the come post the code so we can give you more detailed awnsers
feel me craig?
