Old 11-04-2006, 07:04 PM   #1
TurbLu
TurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-known
SR is having a mild boost issue???
When regularly accelerating (50% throttle) the engine will rev and boost all the way to 8k if needed... But at Full throttle it will have some type of limiter kick in at 5300rpms in any gear.. it feels like one atleast... or maybe a major misfire. Could it be my spark plugs???
TurbLu is offline   Reply With Quote
Old 11-04-2006, 07:51 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yea id start with your spark plugs, then check your maf, then also check for boost leaks
Slip Gypsies Blog
not sure if you realize this
Old 11-04-2006, 09:04 PM   #3
GSXRJJordan
GSXRJJordan's Avatar
it's not a limiter, its detonation. The end result feels like a limiter, but its the computer saying theres something seriously wrong with the A/F mix, due to too much air or fuel or not enough spark, so the computer goes into 'failsafe' and kills power. I'd suggest checking your plugs, gapping them if you havent done that, and checking for boost leaks - if that doesnt fix it, replace those nasty stock injectors with some bigger new ones
Old 11-04-2006, 11:20 PM   #4
staygold24
staygold24's Avatar
staygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enough
whats detonation feel like? sometimes my car will pop twice under full throttle but i dont know if thats normal or not. I just turned up the boost recently
staygold24 is offline   Reply With Quote
Old 11-05-2006, 01:23 AM   #5
GSXRJJordan
The popping at full throttle is from the exhaust, right? Not the cylinders themselves? I've had problems with some SR's TPSs, which arent calibrated, or sometimes wiring issues stop it from getting a full 5V... anyway, most of those are fixable, and not a huge issue none-the-less.
Old 11-05-2006, 03:34 AM   #6
TurbLu
OK guys heres my update-
Took out my plugs - GHOST WHITE!!! - LEAN!!!! - What could cause this:
I just recently had an issue with my stock fpr going out once I installed the Walbro. So I purchased a megan racing one of EGAY and set it for 42psi. Pulled out my plugs and their white. So I turned it up to 55psi for giggles and it still came out white... Shouldnt it have been running way rich??? What else could it be? Im running stock boost (8-9 psi), stock injectors, side mount and 91 octane.
Old 11-05-2006, 03:34 AM   #7
TurbLu
Oh stock DP and exhaust too....
Old 11-05-2006, 11:59 AM   #8
TurbLu
bump for morning help...
Im currently on the way to the yard to pick up another stock ka FPR..
Old 11-08-2006, 08:35 PM   #9
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
s13
Hey when you figure out what is the problemwith your sr le tme know i have the same problem minus the backfiring, s13 blacktop w/ s14 turbo nismo fuel pressure regulator, walbro fuel pump
georgesal is offline   Reply With Quote
Old 11-08-2006, 10:33 PM   #10
TurbLu
Yea the problem is my TPS... I only get it at WOT.... I spilled gas on the sensor when changing the FPR... that did it.... LOL
