#31 |
you have a fax, a race shop set mine up for street and track so I can send you the printout off my s14
'92 C-West Sil/80 SR ***SOLD*** '95 Track car |
#32 | |
![]() Join Date: Mar 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
#34 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
These are specs Whiteline gives with their suspension setup for the 240SX:
Touring: Front: Camber: -1.5 deg Caster: L+7.5/R+7.0 deg Toe: 0.0mm Rear: Camber: -1.0 deg Caster: n/a Toe: 1mm in Sport: Front: Camber: -2.0 deg Caster: L+7.5/R+7.0 deg Toe: 0.0mm Rear: Camber: -1.25 deg Caster: n/a Toe: 0.5mm in Factory: Front: Camber: -1.50 to 0.0 deg (-0.75 deg nominal) Caster: 6.00 - 7.50 deg (6.75 deg nominal) Toe: 1.5 - 3.5 mm in, (2.5 mm in nominal) Rear: Camber: -1.67 to -0.67 deg (-1.17 deg nominal) Caster: not adjustable Toe: 0.0 - 5.0 mm in, (2.5 mm in nominal)
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
#35 | |
To the O.P.: Don't get too crazy. The rear doesn't need a lot of static camber anyway and you have camber plates in the front. You can adjust them when you need to. That's what they are for.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink. |
#36 | |
#37 |
great! Thank you guys!!!!!! Thats interesting that whiteline recomends setting left and right caster different..
thoughts? ALSO, WHY is an auto-x car terrifying on the freeway? Is it only because TOE OUT? Does it make the car super "turn happy"? I'm pretty sure caster and camber wouldn't have an effect on "highway driving" and thats all i could think of causing poor high speed, strait driving... Am i correct? |
#39 |
![]() Join Date: Apr 2003
This alignment is the result of experimentation with the factory numbers to improve road feel and to reduce inside edge wear on the rear tires that is common with the factory settings. These settings will add grip at the front and dramatically improve the feedback to the driver in the steering wheel. They will also reduce or eliminate inside edge wear on the rear tires, and I have gone as far as 24,000 miles on a set of Bridgestone S-02s with these settings. The car will still under steer slightly, but the aggressive driver will find much more predictable handling and significantly better feedback from the car. Obviously, these settings are still compromised for street use. Autocross, road race, and drag race competitors can use these as a baseline, but will probably require somewhat different settings to be competitive.
1. What is a Good Street Alignment? Front: Camber - 1.0 degrees Caster + 5.0 degrees Toe 0.00 mm Rear: Camber -1.5 degrees Toe in (total) 1.00 mm (on 255/40R17 tires this rear toe equates to .090 deg, i.e. .045 deg per side) (on 275/40R17 tires this rear toe equates to .088 deg, i.e. .044 deg per side) The Front and Rear Toe are critical to tire wear, even small deviations from spec may cause unusual wear patterns or excessive wear.
UGR.....SOMETHING WICKED THIS WAY COMES.... |
#41 | |
#42 | |
#43 | |
Its to keep your car from pulling on slanted roads, most roads will have crest on them, it kinda helps keeping it from pulling to the outside. Alignment guy tried to do it on mine, I told him to eat it. 2 degrees of camber on the front of a lowered 240SX for a performance oriented aligment is rediculous unless its on dry rotted Cooper Lifeliners. |
#45 | |
#47 | |
BTW - I don't agree that neg 2 in the front is ridiculous for any low mac-strut car. Neg 2 in the back is too much for me tho.
#49 | |
These specs are totally jacked. 5 degrees of castor? That's LESS than stock. There is absolutely no reason why you would want to run less than stock castor on a street or track or both 240sx. More castor increases centering feel of the steering wheel and provides better turn in, as well as providing more camber when turning, allowing you to run less static camber. This is good because you will still have a good straightline footprint for breaking, but you will have the camber when you need it. Also, those camber settings are wack. Less camber in the front than in the rear? I dunno what thats about. You should always have more front camber than rear camber on an s chassis. No wonder your car understeers. I'm not gonna go listing about a bunch of perfect specs, because there are no perfect specs. It totally depends on what the purpose of the car is, and what parts, and more importantly what tires you have on the car. However, some general, common sense guidlines: 1.) Run more camber than factory, with more camber in front than in the rear 2.) Increasing castor is good. 10 degrees is probably too much, but 7.5-9 is a good range. 3.) Toe out in front is scary 4.) Toe wrecks tires, not camber. Ohh, and setting up your car with uneven R/L castor settings is wack. Last edited by naed240sx; 11-10-2006 at 07:39 PM.. |
#50 | |
#51 | |
![]() Join Date: Jun 2003
You need more camber on macpherson strut cars to end up with the same compressed camber as double wishbone cars. I'd run 2.5 bare minimum, 3+ for slicks if I was going for handling. -mcrussellpants. |
#52 | |
![]() Also I really don't care what my wheels weight since they are really temporary. 2.5 or 3+ front and rear...what kind of handling (other than alter boys)?
#54 | |
Read who I am quoting. I'd think you'd at least understand it. Guys can't even figure out how to put in a basic stereo. I will agree though a good street alignment is not equal to track alignments. I have known ppl that paid to get realigned for street and track. Only Nissan driver doing this I know has a 350Z. At least you state what alignment specs you are dishing out. Street only, mixed, and various track situations all call for different alignments.
#55 |
good informative thread.
so what alignment shops do you guys go to? My car was too low to get on the rack yesterday. ended up using the ground for toe adjustment last night. Not precise but when you are limited, it works. placing flat boards againts each wheel, marking the ground, measuring the distance between the front and rear of these marks from each other, making some calculations. Bringing it to zero degrees. Camber im limited to fender clearance.
Keep it Classy |
#56 | |
They bitch and moan about me wanting specs other than the weakass stock ones though. |
#57 | |
Either of those places will have the boards and ramps to get you on the rack. These places usually don't do lifetime alignments though...I pay about $125 a pop and that is pretty standard for my area...a typical 4 wheel is about $90 here usually lifetime though.
