Old 11-23-2006, 02:24 PM   #1
slowmovingvehicle
slowmovingvehicle is making his/her stupidity well-knownslowmovingvehicle is making his/her stupidity well-knownslowmovingvehicle is making his/her stupidity well-knownslowmovingvehicle is making his/her stupidity well-knownslowmovingvehicle is making his/her stupidity well-known
EGI fuse
ok im talking about the EGI fuse(big green one) in the engine bay fuse box. first of all WTH is an EGI? lately it has been buzzing then i just take out the fuse then it goes away but when i put um back on it buzzes again so i just take it off again. then my brother tells me to take off the negative battery cable then put in the fuse. then just let it sit for couple minutes then put back on the negative cable. then the buzzing goes away. then when i tried to switch the fuse with the other green one next to it it still buzzes so i was thinking it may be the connection. so idk whats happening can someone help me with this.
slowmovingvehicle is offline   Reply With Quote
Old 11-23-2006, 06:13 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
had the same problem once check your ground to your starter ta see if its loose. if it is make sure its not. if not then its gotta some sort of bad grounding thats why its buzzing. if its bad i might have extra ones. cause i took out all the fuses from my fastback when i stripped it bare for extra parts for my coupe.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 11-23-2006, 07:42 PM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
also check out your fuel pump itself because there might be a wire grounding out, this happened to me one time
Slip Gypsies Blog
not sure if you realize this
