Old 11-26-2006, 08:26 PM   #1
civilized_drifter
civilized_drifter's Avatar
civilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of light
Send a message via AIM to civilized_drifter
Exclamation bondo tips and tricks, any one?
im about to work on my front bumper and i was wondering if any one and some tips/tricks i could know about befor i screw up my bumper? im gonna be useing spot bondo/putty. thanks
civilized_drifter is offline   Reply With Quote
Old 11-26-2006, 09:02 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Bondo on plastic bumper??? Personally, i wouldnt suggest it on a bumper, bondo dont like that surface.
CLICK HERE!!!
Old 11-26-2006, 09:05 PM   #3
civilized_drifter
its a fiberglass bumper
Old 11-26-2006, 09:09 PM   #4
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
dont use bondo.
use kitty hair for sure.
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 11-26-2006, 09:33 PM   #5
fliprayzin240sx
yups...dont use bondo. Its fiber glass, so use fiber glass. Depending on what your doing to it, will depend on what fiber glass to use. If your just smoothing it out, sand down all the paint, then buy one of those resin/fiber hair mixed setup. For big cracks and fractures, do it right and buy the clear resin goo and fiberglass sheets seperate. Again sand the paint off, trim the crack so itll sit flushed against each side, cut a piece of fiberglass sheet to cover it, use a paint brush and lay the resin on the fiberglass.
CLICK HERE!!!
Old 11-26-2006, 09:38 PM   #6
Team Rootbeer
Team Rootbeer's Avatar
Team Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really nice
Send a message via AIM to Team Rootbeer
yes.....kitty hair.
and, skim coat of some gooooood shit to get it strait as glass, like Rage extreme or something.
not Bondo brand wal-mart shit.
use the LONGEST sanding block possible, that will help insure straightness.
Originally Posted by hotrodv
90% of the cars posted here are stock or with original rims painted black
I'm not an asshole but is the true..
Team Rootbeer is offline   Reply With Quote
Old 11-26-2006, 10:11 PM   #7
civilized_drifter
theres scratches everywhere on the bumper and i just want to smooth it out befor i paint it
Old 11-26-2006, 10:28 PM   #8
chmercer
chmercer's Avatar
um for scratches you dont want to use bondo? do you have a picture of your bumper
chmercer is offline   Reply With Quote
Old 11-26-2006, 10:29 PM   #9
kove
kove is on the path to ruinkove is on the path to ruin
use kittey hair and poly or high build primer for the scratches
kove is offline   Reply With Quote
Old 11-26-2006, 10:35 PM   #10
civilized_drifter
i dont have any pics, i can get some pics tomarro when im working on it more. my dad told me to use spot putty and hes been doin body and paint for 25 years for i took his advice
Old 11-27-2006, 01:25 AM   #11
usajdm
usajdm's Avatar
usajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond repute
s13
416 EVERCOAT putty. KittyHair is total overkill if all your doing is filling scratches. KittyHair is used to reinforce and mend cracks or small holes in fiberglass. Use multiple thin coats, rather then one thick coat toprevent air bubbles.
What the hell is "BALLER" or "GANGSTER" status, about a 240sx?
usajdm is offline   Reply With Quote
Old 11-27-2006, 11:34 AM   #12
chmercer
chmercer's Avatar
spoty putty is ehhhhh. it never really hardens since its only a 1 part filler. if its just scratches like 300 grit sandpaper you can just spray epoxy primer over it, hell the clear coat will even fill in 300 grit scratches. how bad of scratches are they. or what.
Old 11-27-2006, 12:20 PM   #13
soberjoeS13
soberjoeS13's Avatar
soberjoeS13 is a well-known jackass
hey all you need is to take a DA sander with some 320 grit sand paper and sand down the scratches and the entire bumper..NO MATTER WHAT you are going to have to do this any ways so the primer will stick to the bumper. I've been doing body work and painting for a few years now if you need more help on what exactly todo pm me ill help you out. good luck
soberjoeS13 is offline   Reply With Quote
Old 11-27-2006, 02:44 PM   #14
NemeGuero
No more nissan.
NemeGuero's Avatar
Tips: don't use bondo on a fiberglass bumper (as afore mentioned)
If you insist on using bondo use as little as possible.
Question: If your dad has been doing paint/bodywork for 25years.. why are you asking US for tips and not him?
Old 11-27-2006, 08:12 PM   #15
civilized_drifter
i wanted a second opinion,
Old 11-29-2006, 03:54 AM   #16
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
spot putty is exactly what you should be using; your dad is correct.
Body filler (bondo brand) is for worked metal surface. Although bondo brand body filler blows balls. Use Evercoat Z-Grip body filler, best on the market.
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-29-2006, 05:59 AM   #17
DrifteRs13
DrifteRs13's Avatar
DrifteRs13 is on the path to ruinDrifteRs13 is on the path to ruinDrifteRs13 is on the path to ruin
sorry im biteing on your thread but no sence starting a new one and waisting space for the mods. would you use spoty putty on a dorr that has a weird shaped dent that ccanot be poped out? the dent is has a seriece of dents all in one and its really bad looking, just needed a tip on how you fix it
1990 Acura Integra- Deer (mother fucker)
1993 240sx- still tickin
DrifteRs13 is offline   Reply With Quote
Old 11-29-2006, 08:30 AM   #18
koukimonster139
... how big is it
if its like a tiny ass dent then yeah just get it down to bare metal and use the metal glaze. If its bigger than like 2 inches or w/e use filler. Evercoats the good shit.
ho ha ho chi chi
Old 11-29-2006, 12:50 PM   #19
s13sr20detsilviastityper
s13sr20detsilviastityper's Avatar
s13sr20detsilviastityper is on the path to ruins13sr20detsilviastityper is on the path to ruins13sr20detsilviastityper is on the path to ruin
remember MORE is better when it comes to bondo! slather it EVERYWHERE! have a dent? DONT WORRY, bondo it!
also, after bondoing, primer the car and leave it like that for a long time and just tell everyone you are getting a real paintjob soon, different colors of primer will get you the ladies.
s13sr20detsilviastityper is offline   Reply With Quote
Old 11-29-2006, 01:06 PM   #20
chmercer
chmercer's Avatar
^^^ if you are gonna make a stupid asshole post at least have it be funny, look at some of mine for reference
Old 11-29-2006, 01:13 PM   #21
anyone with over 3 green feedbacks is OBVIOUSLY a tool
Old 11-29-2006, 01:33 PM   #22
koukimonster139
^ shits weak
shits wizeeaaakk
ho ha ho chi chi
Old 11-29-2006, 04:20 PM   #23
NemeGuero
No more nissan.
NemeGuero's Avatar
Originally Posted by s13sr20detsilviastityper
anyone with over 3 red feedbacks is OBVIOUSLY a tool
There.. fixed for your color-blind ass..
Old 11-29-2006, 07:49 PM   #24
Cash
Cash's Avatar
Cash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond repute
Send a message via AIM to Cash
www.dictionary.com
Cash is offline   Reply With Quote
Old 11-29-2006, 07:58 PM   #25
Terminus2k
Terminus2k is making a name for him/her selfTerminus2k is making a name for him/her selfTerminus2k is making a name for him/her self
haha yeah, learn to spell like a not retart
Terminus2k is offline   Reply With Quote
Old 11-29-2006, 08:09 PM   #26
koukimonster139
Are you kidding me ?
please tell me you meant to do that
I can see the cover now.
TERMINUS2K's
LEARNING TO SPELL LIKE A NOT RETART
You culd lern reel good to spel. gwaranteed
ho ha ho chi chi
Old 11-29-2006, 09:10 PM   #27
NemeGuero
No more nissan.
NemeGuero's Avatar
lol .
Old 11-29-2006, 09:12 PM   #28
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
This thread FOR ENGLISH is awesome.
Old 11-29-2006, 09:20 PM   #29
civilized_drifter
any ways back to the bumper im working on. i used the spot putty on some chips and deep scratches and im gonna get some thick primer to fill in the smaller scratches.
Old 11-30-2006, 01:19 AM   #30
nrg
All dents can be pulled out and repaired. You just dont fill in dents with body filler. that's not what it's for. You use a stud gun, then get a slide hammer to grab ont he stud and pull it out, tap around the area with special hammers. if done correctly your dent would look like it didn't exsit. You can also get it repaired through PDR (paintless dent removal/repair).
Body filler is only use to cover up metal work.
driftingisgay.com
