Old 07-15-2002, 10:41 PM   #1
aqwkmf
aqwkmf is an unknown quantity at this point
what would be the best route to get into those times with a 180sx? i could do the sr20 swap or i have access to KA's that i could get completly rebuilt then turbo. what to do? what other mods will be neccessasay(sp?). what will this aproximatly cost? btw....this is a long term goal so dont knock me plz. i could buy aanother Z32 or mod the S13...im starting to like the s13 though <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/satisfied.gif" border="0" valign="absmiddle" alt=':satisfied:'>
aqwkmf is offline   Reply With Quote
Old 07-16-2002, 09:36 AM   #2
Zemus
Zemus's Avatar
Zemus is an unknown quantity at this point
Send a message via AIM to Zemus
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (aqwkmf @ July 15 2002,12:41)</td></tr><tr><td id="QUOTE">what would be the best route to get into those times with a 180sx? i could do the sr20 swap or i have access to KA's that i could get completly rebuilt then turbo. what to do? what other mods will be neccessasay(sp?). what will this aproximatly cost? btw....this is a long term goal so dont knock me plz. i could buy aanother Z32 or mod the S13...im starting to like the s13 though <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/satisfied.gif" border="0" valign="absmiddle" alt=':satisfied:'></td></tr></table><span id='postcolor'>
Well lets see, get the KA-T if you have a 91+ 89-90 it isent really worth it, get a new computer from JW and get new pistons and cams and rods (low COMPRESSION PISTONS like 8.5:1) and then up the boost and get the standard bolt ons, and you might be near their, cuz more than likley you will be running around 300HP depending on where you set the boost
Zemus is offline   Reply With Quote
Old 07-16-2002, 10:02 AM   #3
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
I would say mod the s13.You have to get new pistons and rods and if you want real power.Port polish bore and re-ring.Then put a good size turbo like a straight TO4E ball bearing turbo and crank that boost up to about 15psi+ and rip it open.Civickilla did a 13.34 at 14-15 psi on a small t28 ball bearing turbo on his sr and only laid down 246hp with 270 ft/lbs of torque.That is only imo.
BEISSEN is offline   Reply With Quote
Old 07-16-2002, 10:22 AM   #4
TheTimanator
TheTimanator's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (BEISSEN @ July 16 2002,11:02)</td></tr><tr><td id="QUOTE">Civickilla did a 13.34 at 14-15 psi on a small t28 ball bearing turbo on his sr and only laid down 246hp with 270 ft/lbs of torque.</td></tr></table><span id='postcolor'>
thats weird. &nbsp;I thought SR produce more horsepower than torque due to the smaller engine size. &nbsp;I would expect those numbers from a KA-T not an SR. &nbsp;But, of course I mighht be wrong
Old 07-16-2002, 10:37 AM   #5
TonysS13
TonysS13 is an unknown quantity at this point
89-90 not worh it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>?
u on crack man <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>/
i know a guy with a 90 that runs 12s fool
dont put down the ka sohc
im building one as we speak
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'>
RB25DET Powered S13
TonysS13 is offline   Reply With Quote
Old 07-16-2002, 11:24 AM   #6
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
boost in any motor is possible to get into the 12's
i ran a 12.3 at 22psi on street tires
u can get into the 12's with the sohc with slicks with like 15psi
and higher boost without slicks
so it is possible and can be done in any motor. some may need more work than others.
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline   Reply With Quote
