Old 11-30-2006, 12:21 AM   #1
dwadia
dwadia is making his/her stupidity well-knowndwadia is making his/her stupidity well-knowndwadia is making his/her stupidity well-known
SR Can i safely run "6"-heat range spark plugs with my setup?
I have a redtop in my 1995 240 which has several mods. It has a gt3071r, jwt s4 cams, 740 injectors, etc etc. I bought it with most of the stuff already done. The previous owner dyno'd it at 430+ hp at 26 psi. However, i generally run 12 or 15 psi and the MAX i would run is ~18 (very rarely). It's running very rich and the plugs are currently quite black. They are bkr7e's. I know the 7 heat range is necessary for 20+ psi, but at the levels i'm running can i try a bkr6e and see if it runs better? Would there be any risk with that?
Also, what should i gap them to? And is there any relationship between heat range and what the gap should be? If so, please tell me what the gap should be for both a 6 and a 7. Thanks.
dwadia is offline   Reply With Quote
Old 11-30-2006, 12:39 AM   #2
IngS14
IngS14's Avatar
IngS14 is making a name for him/her selfIngS14 is making a name for him/her self
Send a message via AIM to IngS14
you need heat range 9 or atleast 8.
IngS14 is offline   Reply With Quote
Old 11-30-2006, 01:31 AM   #3
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Are you serious?
Jung918 is offline   Reply With Quote
