Old 12-13-2006, 06:44 PM   #1
DrifteRs13
DrifteRs13's Avatar
DrifteRs13 is on the path to ruinDrifteRs13 is on the path to ruinDrifteRs13 is on the path to ruin
help need assistance pleace!!!!
ok just a few minutes ago my car started making this weird noise then all of a sudden it droped to 2500 rpm and the started to shake reallly violently, so i shifted same with 3 and 4 and 5th i only max out at 25000rpm and then it shakes, i took it to a shop and they said my catalck converter may be cloged or my maf isnt working right pelase help me!!!
1990 Acura Integra- Deer (mother fucker)
1993 240sx- still tickin
DrifteRs13 is offline   Reply With Quote
Old 12-13-2006, 06:58 PM   #2
smelly240
smelly240's Avatar
sounds like the maf might be unplugged... thats like safe mode or somethin. I know with stock inj my car used to run under 2500 with the maf unhooked, then at 2500 it farted out...
got a friend with a maf? u made sure hte maf was hooked right? check contituity from the maf to the ecu? check ref voltage at maf? check if maf ground is good? check your signal voltage out of the maf (there are 3 wires on a 93KA or SR one should be 5v, one should be ground and the other is signal out)
please remember - this things connected to the ecu - use a Digital Multimeter/volt ohmeter... analog bad
smelly240 is offline   Reply With Quote
Old 12-13-2006, 07:19 PM   #3
DrifteRs13
DrifteRs13's Avatar
Old 12-13-2006, 07:20 PM   #4
DrifteRs13
DrifteRs13's Avatar
ok this is the part that looked brok one day when i unhooked it, but this isnt a 240 so i knwo you know what i mean i just looked one of the progs were broken. please i really need to get this fixed and will it hurt my car to drive it like that, one of my friends said that a ball joint may have shot or somethign because iot happend wile i was driveing.
Old 12-13-2006, 07:33 PM   #5
PKaBooo69
PKaBooo69 is an unknown quantity at this point
that is your maf. in what way does it look broken (i cant really see the pic)? if its a wire then its not to hard to reconnect. If its a prong (Ithink thats what you were trying to say) see if you can open the harness housing and replace the pin or try using a pin extractor from the back. if it doesnt look broken you can always try cleaning it. take off the airbox and spray some carb cleaner in there under rev. (good idea to do reguardless)
you got a bigger pic so I can actually see it? how bout a pic of the prong?
PKaBooo69 is offline   Reply With Quote
Old 12-13-2006, 07:39 PM   #6
DrifteRs13
DrifteRs13's Avatar
no that is a diff car i was just giveing an example, but yeah one of the prongs are bent. so do i have to buy a new one or just end up geting a z32 maf instead
Old 12-13-2006, 07:56 PM   #7
PKaBooo69
if the prong is just bent then straighten it and make sure the wire is still connected to it on the inside. how did the prong bend? did you maf harness get disconnected when you were driving? Im a little confused. Depending on what happened and how it happen it may or may not be fixable.
a z32 maf would be a better route to go in the long haul anyhow. I'd replace with one of those. But if you are a little more descriptive or can give me a picture of what you are talking about I can try n help you fix it
Old 12-13-2006, 08:33 PM   #8
DrifteRs13
DrifteRs13's Avatar
i dont have a camera that works sorry but, i was trying to see before i knew anythign about maf sensors and stuff i unhooked the piece and i bent it , i replaced it and it worked again fine afterwards, but all of a sudden wile i was driving its starts shaking very badly (the whole car) SO THEN I SHIFTED AND IT KEPT DOING IT THReW ALL THE Gears.
Old 12-13-2006, 08:38 PM   #9
MasterOFDrift
MasterOFDrift is an unknown quantity at this point
Send a message via AIM to MasterOFDrift Send a message via MSN to MasterOFDrift
check that plug make sure it is connected.
If you want to upgrade to z32 maf you will need some type of Fuel control such as the apexi SAFC.
MasterOFDrift is offline   Reply With Quote
Old 12-13-2006, 08:41 PM   #10
PKaBooo69
or flash your ecu for it, i'll see if i can find a write up on how to do that. its been i long time.
Old 12-13-2006, 09:03 PM   #11
DrifteRs13
DrifteRs13's Avatar
thanks alot........
message legnth
Old 12-13-2006, 09:06 PM   #12
smelly240
smelly240's Avatar
wtf is ........
i told you what to check - what is the problem ? I explained it quite easily -
stick a t pin in the back of the wires goin into the maf plug - theres a white a black and a black and white... the black and white should be 12 volts - the white should give off voltages between 0 and 5 volts (car running - duh) and the blak should be grounded... if that isnt your case - read what i wrote before and check it all...
sounds to me like that bent prong isnt gettin continuity... diagnose the thing as i just explained - and if its related to your bent prong - solder a new plug from a same year car and get a new maf (junk yardin is fun - if u see a j30 or z32 get the maf, brakes (q45 too) or whatever else.
retuning a DOHC ecu requires a daughterboard - you cant just flash it
if u get a z32 maf you can use i believe 2 in and 5 out if im not mistaken on a KA with stock inj. (SAFC)
ford maf pic - good times./
Old 12-14-2006, 05:44 AM   #13
DrifteRs13
DrifteRs13's Avatar
the ... was because i wanted the post deleted but i count so i just used those to edit out the text. ok i will try that thanks.
Old 12-15-2006, 08:06 AM   #14
PKaBooo69
Originally Posted by smelly240
wtf is ........
not so. we ran mine z32 maf with a stock ecu. we got it to run fine i just cant remember how. I'll have to check with ol boy at stock garage or find the write up. we also ran bigger injectors (550s) with the stock ecu. they never worked perfectly (found out later the ecu thought they were bigger than they were) but he had a 13 that did. I still have that ecu in the garage down stairs somewhere. want it?
either way i quit wit the riggin n run a power fc now. but it can be done
Old 12-15-2006, 11:56 AM   #15
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Okay I'm trying to understand why he would get a Z32 MAF to put on a supposedly stock KA? That would cause him to run incredibly poorly wouldn't it? I don't know much about the difference in the two MAFs but I would think on a stock car, get a stock replacment. Problem solved.
As far as the bad prong on the MAF.....how the hell did that happen? did you jam it with a screwdriver, or drop kick it? those thing aren't easy to bend due to the recessed setup of the prongs in the housing. Wierd. I would just go to your local junk yard and source one out. Best choice....if you've got 50 bucks laying around that is.
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 12-15-2006, 12:51 PM   #16
DrifteRs13
DrifteRs13's Avatar
when i put it back in my friend hit it wiht a screwdriver to get it to set right , but idk it still worked after that,
Old 12-15-2006, 01:29 PM   #17
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Your car only revs to 2500 because it is in limp mode, because the ECU cannot read signal from the MAF sensor. It will stay like this until you fix the problem... Try it on your buddy's car, unplug the MAF and start the car, I bet you can't rev past 2500.
You said the connector was broken or damaged, try to fix it if you can and if not just buy a replacement MAF or connector. Don't get a Z32 maf, without proper install/tuning it'll make your problems worse not better.....
MELLO*SOS is offline   Reply With Quote
Old 12-15-2006, 01:41 PM   #18
Dream240
Dream240's Avatar
WERD, AS I THOUGHT...
Old 12-15-2006, 08:54 PM   #19
DrifteRs13
DrifteRs13's Avatar
ok i called the shop and they said it MIGHT be the disributor, dose that sound like a posiblity?
Old 12-16-2006, 08:28 AM   #20
aznpoopy
aznpoopy's Avatar
dude. they already told you what the problem is like 4 times.
Old 12-16-2006, 09:37 AM   #21
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Check out your MAF wiring & test with another MAF sensor before looking at the Distributor.
What makes these people think it's your distributor, clogged cat, etc? Anyone who knows Nissans, knows that if the MAF unplugged the car is put into limp mode with a 2500rpm rev limiter. Start there dude. GL
Old 12-16-2006, 09:47 AM   #22
turboboost12004
turboboost12004's Avatar
turboboost12004 is an unknown quantity at this point
yeah its your MAF, just try to fins a buddy with another 240sx then, swap out MAFs, if it works great! if it dosent well........
Sieze the day or Die regreting the time you lost
turboboost12004 is offline   Reply With Quote
Old 12-16-2006, 09:34 PM   #23
DrifteRs13
DrifteRs13's Avatar
i checked the cat, actualy i pulled my hole exhaust off and only running headers. still didnt work. well i will go down there and check it out they arnt open on the weekends so. sucks really bad
Old 12-16-2006, 10:10 PM   #24
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
sounds like the maf to me
something must be disconnected or leaking air
Drift Indy
Edgar is offline   Reply With Quote
Old 12-17-2006, 08:33 AM   #25
smelly240
smelly240's Avatar
OMG DUDE! I gave you specific instructions how to diagnose the car. I also told you its not the cat... It is something to do with the maf.
TO QUOTE MYSELF :
its really easy - and you keep ignoring the fact that its the friggin maf or the maf wiring.
you even have a "known" bent pin - and you still keep looking at other stuff.
Old 12-17-2006, 11:53 AM   #26
aznpoopy
aznpoopy's Avatar
this thread makes me lol.
person 1: maf
person 2: maf
person 3: maf
person 4: maf
original poster : hay guyz i chek the cat and it still no work wat is wrong/ lol
Old 12-18-2006, 05:49 AM   #27
DrifteRs13
DrifteRs13's Avatar
hah yeah funny, the shop said distributor because i already rulled out the maf, it worked, all air was getting to needed places. so again would a messed up distributor put the car in limp mode as well. This thread was created to help me not flame on something i ruled out almost 10 min after reading the fist responce.
Old 12-18-2006, 06:13 AM   #28
smelly240
smelly240's Avatar
you realize you messed up the maf right there... you didnt check the maf with a dmm did ya? air getting to the maf does not mean its working. 2hrs after you replied you still hadn't checked the maf. if you wanna change the distributor - do it - its your car, but i tried to walk you through this and you refuse to accept my advice.
Old 12-18-2006, 01:15 PM   #29
DrifteRs13
DrifteRs13's Avatar
i dont have it the shop dose i aprecieat the help trust me, but i think when i bent the prong, after driving it it just loosend and fell off. when i looked it wasnt there and i have been trying to find another one.
Old 12-18-2006, 05:09 PM   #30
smelly240
smelly240's Avatar
so wait - if you dont have a prong on the maf - why the heck are you trying to find the problem without fixing that!??!
If you took the car to a shop - they should have fixed it already. Like 10 people told you to get a maf, and you still want a distributor or a cat, or something else to blame even tho you know u have a bad maf.
i am sorry, but i cant help you...
