Old 07-20-2002, 07:50 PM   #1
Mike98'240
Mike98'240 is an unknown quantity at this point
Got a 98 240sx about to reach 70,000Miles.
What all do you guys recommend I do for a good tune up?
Whatever.....Yeah'
Mike98'240 is offline   Reply With Quote
Old 07-20-2002, 11:26 PM   #2
aricanderson
aricanderson's Avatar
Trader Rating: (-1)
aricanderson is an unknown quantity at this point
Feedback Score: -1 reviews
This is what I did to an 89 240, if it helps:
Spark plugs, Spark plug wires, Distributor Cap, Rotor, Air Filter, Check Belts, Check Hoses, Check Vaccumm Lines, Check Water in Battery, Check/Fill Brake/Power Steering/Windshield Washer/Oil/Transmission fluids, Grease lube points, Fuel Filter, PCV Valve, O2 Sensor, Flush/Refill Radiator Fluid, Drain/Fill Differential Oil, Finally pull the ECU Codes to make sure that everything is running right.  If you need exact specs a chilton repair manual tells exactly what needs to be done when.
aricanderson is offline   Reply With Quote
Old 07-21-2002, 02:19 AM   #3
DSC
New Title
DSC is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (aricanderson @ July 20 2002,02:26)</td></tr><tr><td id="QUOTE">This is what I did to an 89 240, if it helps:
Spark plugs, Spark plug wires, Distributor Cap, Rotor, Air Filter, Check Belts, Check Hoses, Check Vaccumm Lines, Check Water in Battery, Check/Fill Brake/Power Steering/Windshield Washer/Oil/Transmission fluids, Grease lube points, Fuel Filter, PCV Valve, O2 Sensor, Flush/Refill Radiator Fluid, Drain/Fill Differential Oil, Finally pull the ECU Codes to make sure that everything is running right. If you need exact specs a chilton repair manual tells exactly what needs to be done when.</td></tr></table><span id='postcolor'>
That sounds good to me <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> I'm gona hit 60k probably tomorrow and I'm needing to do some of that I guess.
Only think I felt I ought to correct was you said to check/fill brake fluid. &nbsp;You should not add brake fluid. &nbsp;If it's low, that means your brake pads are wearing down, allowing the calipers to clamp down farther, allowing more fluid in the lines, thus less in the reservoir. &nbsp;If your brake light comes on (and it does when your fluid gets too low) then you need to change your brake pads...not add fluid. &nbsp;If your light isn't on but you top off your fluid, you will not know then your pads need to be replaced until they start scraping. &nbsp;I know because I've done it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'>
DSC is offline   Reply With Quote
Old 07-26-2002, 08:28 AM   #4
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Yes, but after 60k miles, it's still a good idea to replace your fluid.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 07-27-2002, 01:35 PM   #5
Mike98&#39;240
Mike98&#39;240 is an unknown quantity at this point
Went to NISSAN and the service tech told me that I did not need to change my differential fluid (drain/fill back up).
Also, they charge 70something for the Transmission fluid change. (drain/fill clean pan & filter).
What do you guys think about this???
Whatever.....Yeah'
Mike98&#39;240 is offline   Reply With Quote
Old 07-27-2002, 02:46 PM   #6
Anubis
Anubis's Avatar
Anubis is an unknown quantity at this point
Send a message via AIM to Anubis
I changed my engine oil, trans oil, and diff oil last week when my car hit 130,000! YES! I have mass miles but it runs slick.
Anubis is offline   Reply With Quote
Old 07-27-2002, 04:25 PM   #7
Mike98&#39;240
My question was though ... should I listen to the NISSAN service dude, and not get it changed or what?
How hard is it to do yourself?
Whatever.....Yeah'
Old 07-27-2002, 04:32 PM   #8
Anubis
Anubis's Avatar
well changin the engine oil is probly the most basic thing you can do of the 3, the diff oil is somewhat difficult while its still in the car, but can be done. And the trans oil for me was the most difficult. You can pick up a chilton book or something equal(repair manual) at like kragen or autozone and that would guide you thru all of them. If your not the hands on do it yourselfer, take it to a shop.
Old 07-29-2002, 03:54 PM   #9
Mike98&#39;240
Okay I finished my tune-up, and only thing I didn't do myself was Trans and differential change.
Transmission drain/fill, clean pan, filter - cost $61.08
Tomorrow I am going to the local shop to get my differential done, dont know exactly how much that is going to cost yet-
Whatever.....Yeah'
