Old 12-19-2006, 09:01 PM   #1
chingalong
chingalong is a well-known jackass
Wink 1997 Model Drivers side Power window won't go Up
My driver's side power window won't roll up.
I have not found any Motor yet, but how can I roll up the window
too cold to drive with an open window. Have not tried raising it manually
do not want to break it.
NEED YOUR PROFESSIONAL ADVICE Please@ Thank a lot.
reply to: [email protected]
chingalong is offline   Reply With Quote
Old 12-19-2006, 09:08 PM   #2
projectRDM
projectRDM's Avatar
Unbolt the window from the regulator, remove the regulator from the door, unbolt the motor from it, and manually raise the glass. Then reattach the window. If the motor is jammed there's no way to get the window to move unless it's off the regulator.
Old 12-21-2006, 01:08 AM   #3
idlafie
idlafie's Avatar
R....you sure know how to make life difficult!!..hahahaha...
Ching...before you go thru all that hassle make SURE you're power window motor is DEAD!!. Test the power window motor by hooking up two wires to a 12 volt power supply, (car battery, etc.).Before you start, disconnect the wiring harness that runs directly to the power window motor. Hook one end of the wires to the positive post & the other to the negative post. Take the other end of the wires that are not hooked up to the 12 volt power supply & CAREFULLY apply those wires that go directly to your power window motor. If your power window motor works, the window will either go up or click as it tries to go down. If it clicks as it tries to go down, then reverse the wires & then power the motor till it raises the window up.
Now if R is right & your power window motor is dead, then you're screwed!! You'll have to follow R's direction to get your window up.
Anyhow, hope this helps...
ID
Old 12-21-2006, 08:13 AM   #4
projectRDM
projectRDM's Avatar
I figured he had tried that already, but you make a good point to go through the electrical diagnostic, after all this is zilvia.
Old 12-22-2006, 01:34 PM   #5
red98s14
red98s14 is an unknown quantity at this point
Let's back it up one more step. Since the OP didn't say if the passenger side window works or not, are you sure the window lock button isn't down?
You'd be surprised how many people hit that by accident.
red98s14 is offline   Reply With Quote
Old 12-28-2006, 12:41 PM   #6
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
haha yea like my brother....
DoriftoPnoy is offline   Reply With Quote
Old 12-28-2006, 12:57 PM   #7
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
ya, check that and try holding the switch in the "up" position for 10 seconds or so. Mine gets stuck all the time.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 12-31-2006, 07:24 PM   #8
chingalong
Power window amps
Can someone tell me that maybe it is the Power window amplifier that is the
culprit instead of the Motor.
But where is it located. I opened the door cover and still unable to find
the culprit..
Please advise. thanks.
