Old 12-20-2006, 11:56 AM   #1
nissandr1ft
nissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura about
Send a message via AIM to nissandr1ft
Fuel Pressure?
I'm having problems with my mainly stock KA breaking up at High RPM's. I'm basically gonna do a basic tuneup to make sure the plugs, cap, and rotor are good. I doubt thats the problem so I wanted to check my fuel pressure, but the only pressure tester I have isnt an inline tester like shown in the FSM. If I just put a pressure tester on the feed line, and put the key in the ON position what should my readings be? I tried it earlier, and only showed 20lbs, where as with the inline tester the FSM shows 34lbs with vacuum, and 43lbs with no vacuum.
Steven
www.carolinanissans.com
nissandr1ft is offline   Reply With Quote
Old 12-20-2006, 12:29 PM   #2
BC240
BC240's Avatar
BC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enough
I think you answered your own question. 34 w/ vac 43 no vac. Could you define "breaking up" at high rpms? could be a dying fuel pump.
BC240 is offline   Reply With Quote
Old 12-20-2006, 12:33 PM   #3
nissandr1ft
Well if you take it to about 5500+ WOT it will start popping, and quit accelerating. I figure either the coils trash, or the fuel pumps not up to par.
Old 12-20-2006, 12:36 PM   #4
tre
tre's Avatar
tre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enough
see my fuel pump went out on me VERY randomly. never had anything like that happen. Just after one track day drove to get food. then came out car wouldn't start.
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole.
tre is offline   Reply With Quote
Old 12-20-2006, 01:04 PM   #5
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
have you replaced the fuel filter lately?
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 12-20-2006, 01:16 PM   #6
nissandr1ft
Yeah the fuel filter is a 300zx one that I threw in a few monthes ago...blew threw it to make sure it wasnt clogged when I threw the motor in.
Old 12-20-2006, 01:31 PM   #7
nissandr1ft
Im almost positive its the pump now that I look at the plugs. I checked the gaps to make sure they were all relativly close to .040, and the coloring shows lean/hot... I think.
Old 12-20-2006, 01:34 PM   #8
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
If the fuel filter was brand new then you shouldnt need to blow through it? Poor exhaust aka bad cat could cause it to start to loose power at higher RPMS because the engine cant push out the exhaust? Your gas tank is clean?? Even if you put a new filter you could still pull sludge from the tank and clog the filter again??
Try putting a hardline in place of the fuel filter and see if it still stumbles??
davirene is offline   Reply With Quote
Old 12-20-2006, 01:39 PM   #9
tre
tre's Avatar
wow .040 is pretty big. .032/.030 is better for your ka lol
Old 12-20-2006, 01:41 PM   #10
nissandr1ft
Not brand new, it was used on my last motor for a month or 2. Theres not a cat, nor any emmissions equipment on the car. Ill check the gas tank in a sec, but I didnt have any problems with the filters getting clogged with the last motor. The FSM said .039-.043in (1.0-1.1mm) for the spark plug gap. Ill close the gap, a bit and see what happens.
Old 12-20-2006, 01:48 PM   #11
BC240
BC240's Avatar
If your not getting enough fuel that narrows your options quite a bit. change your fuel filter to a new stock one but most likely its your pump. When I test drove my car to buy it I told the guy it felt really slow and he responded "Its not a race car, dont expect it to be fast".
After I bought It I changed the filter and it was still choking, Right before I was gonna change the fuel pump it died on me. After replacing it the car was fast as hell. Also make sure if you get a pump to get a new filter condom for it, they dont always include them.
Old 12-20-2006, 01:49 PM   #12
nissandr1ft
Yeah after looking at the plug, Im leaning towards the pump myself. I wont be able to go grab another one till tommorrow.
Old 12-20-2006, 01:52 PM   #13
tre
tre's Avatar
here's a tip. i learn a lot from B at the Nissan Dealership. Its cheaper to get a fuel pump from schucks because its teh same thing cept it doesn't say nissan on it lol. He recommends me where to get parts lol.
Old 12-20-2006, 01:57 PM   #14
BC240
BC240's Avatar
I think mines a carter and its loud as hell, I think Walboros are pretty loud to. If you want a nice quiet one buy OEM
Old 12-20-2006, 01:58 PM   #15
nissandr1ft
Im gonna throw a freinds old pump in to try, since he just replaced his with a Walbro. Not to worried about noise...S14 mani->3" SR DP->3" test pipe->3" exhaust is not the quitest thing out there.
Old 12-20-2006, 02:00 PM   #16
tre
tre's Avatar
LOL OEM is not always quite. mine whines like a bitch. if i didn't have exhaust i'd hear it all the time :P
Old 12-20-2006, 02:05 PM   #17
drew935
drew935's Avatar
How's the ignition coil? Have you checked the secondary to see if it is still in spec?
I'm driving fast
-drew
Old 12-20-2006, 02:09 PM   #18
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
ok i dont know why nobody has told you yet, but those plugs are done. fried. way too hot/lean. you need new plugs after you figure out why its so lean.
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 12-20-2006, 02:16 PM   #19
BC240
BC240's Avatar
hah good point, I hope you didn't put those back in.
Old 12-20-2006, 02:19 PM   #20
nissandr1ft
On that topic whats everyones opinions on plugs...my freind that works at Nissan swears by NGK iridiums, I know most turbo guys go copper, and factory was platinum. I realize with copper you have to replace them more often, but other than that will there be a downside? If I know Im getting the correct fuel pressure, and its still breaking up the coil was going to be replaced next month by a MSD blaster SS anyways.
Old 12-20-2006, 02:25 PM   #21
BC240
BC240's Avatar
Im single tip platinum right now but ive also heard good things regarding iridiums. Im gonna have to let someone else drop the science on you. Either way if your not boosted plugs wont make a huge difference.
Old 12-20-2006, 02:41 PM   #22
nissandr1ft
I just talked to another freind whos sort of a local guru who told me tanish color plugs are fairly normal for an N/A car. He mentioned high EGT's due to cruising, and the the stock ECU running pretty lean.
Old 12-20-2006, 02:57 PM   #23
drew935
drew935's Avatar
may get an afr reading at wot. I replace my plugs once/yr with stock NGKs and they're just fine on my car. Have run seafoam yet? I do that once/yr as well. Last time I did it(Just recently), there was no smoke out of my exhaust. That's how clean my car is running. If there's a lot of carbon buildup, then you'll see smoke out the exhaust like the space shuttle.
I'm driving fast
-drew
Old 12-20-2006, 03:10 PM   #24
180sxsun
180sxsun's Avatar
180sxsun is a well-known jackass
where can i get that seafoam stuff and how do i use it? (ive never heard of it before nor used it)
jes jerk on it
180sxsun is offline   Reply With Quote
Old 12-20-2006, 03:22 PM   #25
drew935
drew935's Avatar
/\ you get it from the store. Search it on here as it has been posted before. Run it through your brake booster vacuum line and have it sip it from the can and into your int. mani for short.
I'm driving fast
-drew
Old 12-20-2006, 07:49 PM   #26
nissandr1ft
Yeah I seafoamed it when I threw in the motor, but I tryed another fuel pump. I checked the pressure the same way I did with the old pump, and it read 50psi. Worked like a dream and runs great, thanx for the info guys.
Old 12-21-2006, 09:41 AM   #27
drew935
drew935's Avatar
good deal
I'm driving fast
-drew
Old 12-21-2006, 10:57 AM   #28
BC240
BC240's Avatar
Awesome man, go rip it up
Old 12-23-2006, 01:51 PM   #29
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
Damn, I'm having the same exact issue... I guess I'll try doing that too.
Nancy Kappa Monkey Squad
9524tee is offline   Reply With Quote
Old 01-30-2007, 03:31 PM   #30
underconstruction
underconstruction is an unknown quantity at this point
Do you know the model number of that fuel filter? did you have to modify anything to get it to fit?
underconstruction is offline   Reply With Quote
