DD/mountian driving sway bars
So I've Ben looking for some aftermarket sway bars. I'm not to sure what to get. I'm not going to drift this car since its my DD. I'm looking for more for a setup witch will let me handle the mountain roads better. My price range in around $300 because i need to also buy a new steering rack this week. The reason I'm not sure what to buy is because i have Ben reading certain ones are for drifting.
This is what i have Ben looking at. Will it work for what I'm looking for? Suspension Techniques Front and Rear Sway Bar Set Nissan 240sx 89-94. Front Bar Diameter 1 1/16 inch, rear bar diameter 13/16 inch. http://storesense.megawebservers.com...and/Detail.bok __________________________________________________ _________ and should i get aftermarket end links while I'm down there?
Parking lot pimping ![]() |
i was also looking at the GODSPEED anti sway cars, they are alot cheeper.
FRONT- 30.05mm REAR - 28.29mm -Full Chromemoly Construction, Handling Master -Bolt On, Stock Mounting -No Adjustment Necessary -Solid Bushings Included what is the differance? just quality? and why would these be crap compared to the other ones?
Nooooo
The Godspeed sways are chromoly tube & they are crush bent instead of mandrel bent. I was seriously considering getting these bars, but I realized that the rear bar was WAY thick. The front/rear ratio gets all out of wack & would probably create massive oversteer. I think i'm going to go with the ST ones. Best bang / Buck |
#9 | |
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink. |
#11 | |
usdm hicas = 21mm jdm hicas (on some models, i think just the 89-90 models) = 17mm stock ones = 15mm i had all three |
![]() Join Date: Nov 2004
Blah blah blah. Whiteline. You can adjust them.
And there isn't a huge need to upgrade the end links. So you can save a little money. And remember, most stuff marketed for, "drifting" and what not is just regular performance parts. Named to appeal to a certain crowd. If you do go the cheaper way, as said by n1sm0r, get a hicas rear bar. And while you're at it, get a hicas steering rack. Better steering ratio imo.
![]() Join Date: Jul 2003
stock bars from an S14 SE with upgraded endlinks (ball joints) would probably make a big difference, Turdz was considering making his own and IIRC found that the price is favorable to purchasing new ones.
You can always ask SPL or any largus dealer if u wanna shell out some cash Stock bushings will probably reduce the effectiveness of any bigger sway bar you get. Just a thought, haven't done it myself. |
#14 |
There is also Tanabe and Largus anti-sway bars. The Tanabe ones should be around your price range.
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
#16 | |
![]() Join Date: Sep 2004
Trader Rating: (24)
I already have s/t bars on my s13, just curious. Alex |
#18 |
I used to have Largus sway bars F & R. They are really thick, but super super super lightweight. If you set the front sway on the first hole understeer goes away. They made the car feel a lot more solid on the mountain roads & when my car would oversteer it felt very controllable. I can't really say anything about daily driving because my car was rough on the streets since I would keep my coilovers on medium to hard dampening.
SHIFT_zilvia |
#19 |
Zilvia Contributor
![]() Join Date: Oct 2001
![]() ![]() Feedback Score: 1 reviews
I heard the R32 rear sway bar is like 25mm or 27mm thick and bolts up...you might research that a bit and try hitting up a Skyline chat board's "for sale" section.
-m
400x200 ![]() |
#20 |
I think whitelines are good, but can also be expensive. I just put the Suspension Techniques on mine, got both for a steal. Summit had them for $240 for front and rear kit. I noticed a huge increase in the rear especially, and the front doesnt roll as much either.
Heres some pics of them installed incase you wanted to see... Heres the rear with endlink... ![]() Heres the front comparison: ![]() And heres the front with the endlink: ![]() |
#21 |
That green is awesome. And the red bushings = good bushings
#24 | |
wow they dont look much biger than stock is it really worth the money? jsut for a referance i have front/rear strut tower brace, rear under brace, front power/under/subframe or whatever brace, c pillar bar, Tokico blues and cut stock springs. would i notice biger swaybars? and its an s13 btw.
#25 | |
ohh, also jsut wondering if the 300zx bars or s14 bars will fit?
#26 |
You would notice that your car's suspension is crappier than it already is. First purchase real suspension and get rid of those blow shock and ghetto modded springs. Sway bars will make a HUGE diff in how your car handles. And did you miss EVERYTHING said in this thread? Edit: ghsajgnwq; ;kaqspghal Damnit. I said it before and I'll say it again. Sway bars aren't ment to stiffen your car. They stop body roll. And they help maximize your contact patch. Stop being so fucking ghetto Do it rite or don't do it at all. Because all you are going to do is trash up your car worse than it is.
#27 |
I know the sway bars don't stiffen my car up, from the way i understand they try apply the highest percentage coupling between both sides, and to increase the spring rate on the side is compressed the most.
Stop being so fucking ghetto Do it rite or don't do it at all. Because all you are going to do is trash up your car worse than it is.[/QUOTE] oh and i am asking because i want to do it right and take the "fucking ghettoness" out of it. So im buying good quality sway bars, new shocks and lowering springs. Theres no way im going to put coilovers on my dd. A to expensive and B not worth the money its not a race car, its a sports car. Also my car is not trashed. thanks for the help on telling that i would feel a huge difference of the aftermarket sway bars. I appreciate it.
#28 | |
