Old 12-29-2006, 08:13 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Why are SLICK street tires so SLICK!?
I know...dumb question.....but......
Does anyone know why BALD street tires are LESS grippy than they were when they had tread.
The way i look at it.....A bald tire has much more contact patch, and is made of the same material, so shouldn't it grip better IN PERFECT ROAD CONDITIONS. Meaning NO SAND, GRAVEl, WATER, ETC?
Obviously they would suck with roads that are anything less than perfect, but why even on perfect roads does traction with SLICK tires suck?
gotta240 is offline   Reply With Quote
Old 12-29-2006, 08:41 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
Different compounds of rubber act differently.
The rubber in your pencil eraser isn't the same as the rubber in your tires or the rubber in R-compounds or the rubber in a condom.
Same way eyeglasses aren't made the same as drinking glasses or Pyrex cookware.
Originally Posted by PHLIP
Old 12-29-2006, 09:25 PM   #3
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
^good answer
lexus baby
5t341tH is offline   Reply With Quote
Old 12-29-2006, 11:38 PM   #4
yudalicious
yudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond repute
actually, from what I gather, tires can have different compounds in layers. But most likely by the time they're worn down to the bars the material is probably heat cycled to death.
yudalicious is offline   Reply With Quote
Old 12-29-2006, 11:43 PM   #5
chmercer
chmercer's Avatar
yeah, heat cycling. if you shave a tire you are right it can grip better with less tread.
chmercer is offline   Reply With Quote
Old 12-29-2006, 11:51 PM   #6
smelly240
smelly240's Avatar
and if u cut some reverse camber in the tire - u get even more contact patch
tire cuttin machines are so fun - its like shiny black confetti or silly string.
Old 12-30-2006, 03:16 AM   #7
gotta240
Mrmemphis- I'm not asking why my "street slicks" don't work as good as real slicks. Thats like comparing oranges to apples... I'm wondering why the SAME RUBBER that the tread is made out of grips WORSE when there is MORE of it.....
Sounds like the consensus is heat cycling.... Interesting and thanks for the replies.
So theoretically, I could take a set of regular bfg or falken street tires, shave them bald, and they SHOULD have more traction on perfect grounds than they previously did WITH tread...right?
Old 12-30-2006, 06:14 AM   #8
nsany(atl)
nsany(atl) is an unknown quantity at this point
I think when you get down that far you may be into the bonding material so it sticks to the cords
'92 C-West Sil/80 SR ***SOLD***
'95 Track car
nsany(atl) is offline   Reply With Quote
Old 12-30-2006, 06:19 AM   #9
Phlip
Yes, I look like that
Phlip's Avatar
Perhaps you missed:
Your tires are harder than traditional "slicks," the rubber was DESIGNED to have tread, and the tread design was in place to assure maximum traction in the conditions that one may expect to find themselves in driving a car on the street.
Wear that tread out, you have exceeded the useful life of that tire by stripping it of the one thing it was designed for.
Weirdo
And I write too!
Old 12-30-2006, 11:57 AM   #10
gotta240
I understand that i'm not using it for what it was designed for. I also understand they were DESIGNED to have tread for the "conditions that one may expect to find themselves in driving a car on the street". I'm not surprised they don't work better, i'm just wondering WHY.
I'm not even talking about road conditions...I'm talking about smooth track conditions.
Not, "because they weren't designed for that" type of why, but because after x uses they get so hot they turn rock solid, or another forums reply was because they thought the tread itself actually flexed a lot, reducing the breaking point.
Sorry to beat this to death, but i'm just curious.... So has anyone taken a fully treaded tire and shaved it to a slick? Was the grip better? How long long did the grip last before it felt like a crappy tire made of ice?
Again, thanks for the replies. Its amazing how two different boards come up with 100percent different answers....
Old 12-30-2006, 12:29 PM   #11
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
not to mention even if you DID shave them down and get more contact patch blah blah, it would burn out super quick even grip racing and if you hit any rain on the street kiss ur ass goodbye
redsuns3838 is offline   Reply With Quote
Old 12-30-2006, 12:36 PM   #12
gotta240
i know..i'm not trying to do this, i just like to know how/why things work. My 255 rears bald feel like 225 or 215's with tread even on PERFECT surfaces... Just curious as to why...thats all.
so, DOES shaving down a new treated tire(normal tire)=more grip?
if so, how long till it "heat cycles" to death?
Old 12-30-2006, 12:47 PM   #13
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
i think if you shaved ALL the tread off of a new tire you would have enough rubber left for like a day
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 12-30-2006, 01:16 PM   #14
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
Heat cycling breaks down and reduces the rubbers' properties over time, and street tires are not the same compound as race slicks.
In a lot of instances the reason people shave tires is to reduce tread wiggle not just for straight line traction.
sncs14 is offline   Reply With Quote
Old 12-30-2006, 01:18 PM   #15
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Can I just ask what kind of tire do you have?
MrChow is offline   Reply With Quote
Old 12-30-2006, 01:32 PM   #16
ep510
ep510's Avatar
ep510 is an unknown quantity at this point
Although R's or slicks do not have a lot of grooves showing like your street tires do --there is usually 2/32 to 4 or 5/32nds of "rubber" still there.
When an R compound DOT approved tire or a true racing slick is worn down to the point your tires are now --they do not grip well either and will slide around like your car is on glass. The Rubber is still what grips the road (or dirt or whatever) ---not having grooves or "tread" just give more contact patch and less opportunity for the tread blocks to move around and overheat the surrounding rubber or chunk off.
the grooves or tread blocks are there to evacuate water, snow, dirt or whatever --different tread patterns for different types of driving environments.
ep510 is offline   Reply With Quote
Old 12-30-2006, 02:13 PM   #17
yudalicious
Heat cycling, the end. Though to point out something interesting, I've heard that the Falken FM901s' inner layer of rubber is similar compound to the RT215/615 so some autocrossers were buying them new and shaving them instead of buying the RT215/615s. Again, this is hearsay, just thought I throw it out there.
Autocrossers do buy performance tires and shave them, ie kumho mx, to reduce tread squirm.
Old 12-30-2006, 04:23 PM   #18
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
That's odd, since the FM901 is made by dunlop. Industry espionage and compound thievery!
turtl631 is offline   Reply With Quote
Old 12-30-2006, 05:05 PM   #19
yudalicious
lol, you hoe. sorry, eh, what's the other Falken tire, er.. hm... I think it was the FK451...
Old 12-30-2006, 07:25 PM   #20
gotta240
shit...i hope its not the FK451!!! THATS THE TIRE I'M ROLLING ON!!!
255, almost no tread left, and i can drift all day long on these....not grippy when slick by any means. (gotta be carefull on my downshifts or unwanted drift is initiated)
Old 12-30-2006, 11:41 PM   #21
cdlong
again, shaving tread and wearing tread off are two very different things. your tires are shot, shaved tires just have less tread squirm.
cdlong is offline   Reply With Quote
Old 12-31-2006, 06:00 AM   #22
aznpoopy
aznpoopy's Avatar
the main purpose of shaving is to control the temperature of the tire. reducing flex in the tire aka tread squirm is a means to an end. less squirm = less heat.
a shaved tire and a worn out daily driven tire are two very different things.
tire rubber is not the same throughout it's entire lifetime. every time you drive, the tire gets hot. when you park the car, it cools down again. doing this over and over changes the rubber. hell, tirerack can explain it better than me.
Originally Posted by tirerack
the heat generated every time a tire is driven activates bonding agents in the rubber. As this process is repeated continually throughout the tire's life, its rubber compounds gradually harden and lose flexibility reducing the tire's grip. Therefore, a shaved "new" tire will provide more traction than a tire worn to the exact same tread depth after being driven for thousands of miles on the road.
http://www.tirerack.com/tires/tirete....jsp?techid=67
Old 12-31-2006, 08:30 AM   #23
driftenthusiast
driftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to all
I dont know about shaving normal street tires. Tires like Toyo RA-1's are desinged to be shaved. They have horizontal tread thats pretty shallow, and that is desinged if your running rain or want to use them on the street. Then they have lateral grooves that most people shave then down to if you want to run them on the track.
NEW
Shaved
driftenthusiast is offline   Reply With Quote
Old 12-31-2006, 11:23 AM   #24
gotta240
Alright, i got it. Thanks guys! That makes perfect sence now.
