Old 01-22-2002, 09:04 AM   #1
WhiteS13
WhiteS13 is an unknown quantity at this point
Send a message via ICQ to WhiteS13
My 1993 240SX shakes when I'm stopped at a light.  There's a revolving motion from the motor that increases when I'm at a standstill.
I'm assuming it might be an engine mount, but wanted to confirm with everyone first.  Just incase it is a known problem?
WhiteS13 is offline
Old 01-22-2002, 10:01 AM   #2
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
My 89 coupe does the same thing <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('> Its real anoying.
Mine will shake more the lower the RPMs go down @ idle. Is yours the same way? Im still trying to figure out what it is.
West is offline
Old 01-22-2002, 10:07 AM   #3
MorganS13
MorganS13 is an unknown quantity at this point
yea mine does that too when i'm sitting at a light with my foot on the brake. &nbsp;when i took it to the dealer they said it was my brake cylinder starting to go or somethin along those lines. &nbsp;Oh yea my drivers side rear caliper has been siezed for a couple months now too, would that have anything to do with my brake cylinder going bad?
MorganS13 is offline
Old 01-22-2002, 10:07 AM   #4
WhiteS13
West, you've explained it perfectly. That's exactly what my car does. When I'm sitting around idling, it starts shaking, and gets a little worse with more time. Once I start driving, it's gone. Stop again, and it starts all over.
I figure it's a torn or worn engine mount because the shaking feels more like a revolving motion. It actually makes my feel dizzy.
(Edited by WhiteS13 at 5:20 am on Jan. 22, 2002)
WhiteS13 is offline
Old 01-22-2002, 10:09 AM   #5
MorganS13
actually mines more like my idle will fluctuate between 500-700 RPM and thats what causes my car to shake
Old 01-22-2002, 11:20 AM   #6
West
OMNOMNOMNOM
West's Avatar
Idle Problem
When the car sits at idle the rpm needle is solid but the car trembles slightly. I had the dealer look at engine mounts and 3 techs said they were ok. What else could this be? Next step... Tried, new plugs, rotor, distributor cap. When car is pushed to the limit,(like 100MPH+ for 2-5 min) the idle tremble disappears. It cools down and there it is again. Strange.... any ideas?
-Dave
'91
ICQ:3489486
[email protected]
Re. 1
Check the electrical connectors on the injectors by &quot;gently&quot; shaking them while the engine is idling. &nbsp;I had a corroded connector on one injector and it caused similar symptoms.
Doug
Re. 2
Check your spark plugs for cracks. Run your engin in the dark and look for arcing of the plugs and wires. Don't forget to rev the motor to put it under a load.
Check for white deposites on your coil. This indicates that the coil is breaking down and electrcity is arcing to ground.
Also put some fuel injector cleaner in your fuel.
[email protected]
Re. 3
I had been having what felt like clutch slippage, kind of cyclic bogging down, in low revs. Car didn't lack upper end, or bother on hills though. I went through the bother of getting to the AIV, removing the top, and rinsing it out with electrical contact cleaner (its what I had, as I was also degreasing All contacts). (my speedo still wonk work right.) On removing the top clamp, the valve unit, was stuck. Some gentle pulling released it. The valve had to be stuck to some degree. Clean, bolt it back up, no bogging. Engine breaking smooth again. I feel (without real evidence) that this could be an additonal idle-type problem. I did have the unit replaced prior due to catastropic engine stalling when pushing the clutch and breaking. The unit seems to be easy to clean. I feel silly now for having it repla$ed.
Idle problems should include: MAF, MAF connectors, AIV, AIV connectors....
[email protected]
Another Solution
My 1993 would stop intermitently with very unstable idle and lack of power afterwards. Then after 5 minutes everything was fine. Dealer detected bad air flow meter, probably I could do it myself by reading error codes, didn't have time to do it. Got a meter form a dealer for $450.00 (why is it so expensive?), installation took me 30 minutes. Running OK so far.
Vlad
Email: [email protected]
West is offline
Old 01-22-2002, 11:55 AM   #7
Azarael
Azarael is an unknown quantity at this point
My #### fiero shakes too <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'>
Azarael is offline
Old 01-22-2002, 12:16 PM   #8
fourg63
fourg63 is an unknown quantity at this point
I'm having the same problem on my Altima.It shakes like a mofo when idling.It idles at about 500 when sitting at a light with breaks engaged(auto).I know it's an idle motor problem since the more accessories(i.e. AC) I turn on the lower the idle gets.Once I put it in neutral, it gets better but not perfect.
fourg63 is offline
Old 01-22-2002, 03:33 PM   #9
geerhedz
geerhedz is an unknown quantity at this point
I started having the same trouble on mine just last week. &nbsp; I bought new plugs, and I figured I'd try to see what the stock ignition could handle as far as plug gap is concerned. &nbsp;So I gapped my plugs at around .40 versus .35 where there supposed to be. &nbsp;I didn't notice any diff in power but my idle suffered so I pulled the plugs out and gapped them back to .35 and It went away.
Hope this helps :cool:
geerhedz is offline
Old 01-23-2002, 10:20 AM   #10
West
OMNOMNOMNOM
West's Avatar
Went home today and fixed my idle. It was very ez actually. All I had to do was either open up the AIV and clean it out or do what I did and just break the tube that goes from the intake to the AIV and then put a small K&amp;N style filter over the intake hole where the AIV tube went out of the intake.
I also clean my throttle bodies and changed my spark plugs. The car runs really good for an 89 that once ran like shit <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> Im happy I paid $1200 for this car.
West is offline
Old 01-24-2002, 05:19 PM   #11
240racer
240racer's Avatar
240racer is an unknown quantity at this point
my car has that problem too. &nbsp;Where is the AIV and did you need to plug both ends of the tube. &nbsp;Also I have found some problems with the intake leaking after the MAF and when I fixed that it got a lot better
thanks
Adam
240racer is offline
Old 01-24-2002, 08:28 PM   #12
Skiman112
Skiman112 is an unknown quantity at this point
my car idles rough, but i thought it was b/c of my intake that i made. &nbsp;It idled really rough before i sealed up all the leaks in the intake. &nbsp;You can see my masterpiece at www.msrg.8k.com
Skiman112 is offline
Old 03-22-2004, 12:23 PM   #13
260sx
260sx's Avatar
260sx is an unknown quantity at this point
ah hah! same problem goes here...
however.... didnt seem to find any resolution to it... my air intake is fine... just removed my aiv... i dont think there's a problem.... so what could be wrong...???
i guess new distributor is needed... but not sure..
260sx is offline
Old 03-22-2004, 12:31 PM   #14
AN89HATCH
AN89HATCH is a well-known jackass
s13
My 89 240 did the same exact thing, I found out it was the spark plugs, i replaced them, now my idle is perfect, no more shaking
slide your ride.com
AN89HATCH is offline
Old 03-22-2004, 12:44 PM   #15
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Well this is actually an easy problem for the most part. It is a 4 cylinder which means there are less power strokes to keep the motor turning as compared to a 8 cylinder. The reason for a flywheel is to keep the motor spinnng between power strokes. The shaking is most likely more noticeable with a lighter flywheel. So getting used to this shaking would be a good thing, unless u decide to get a 6 or 8 cylinder. Its a 4 cylinder motor that has a longer stroke and bigger bore so it is inevitable.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline
Old 03-24-2004, 08:49 AM   #16
260sx
260sx's Avatar
yea i know... i've heard that striaght sixes are best for not bouncing around. but still... all other fours doesnt do it and i'm pretty sure nissan dont intend to make it shaking like its gonna die, which it never did... but the shaking is just unpleasant when you have a hot chick ridin along.
260sx is offline
Old 03-24-2004, 12:00 PM   #17
West
OMNOMNOMNOM
West's Avatar
Congrats for reviving a 2 year old thread!
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline
