Old 01-04-2007, 10:32 AM   #1
2_fast_240
2_fast_240's Avatar
2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore
Altering compression ratio?
Ok, so ive been thinking about turbocharging or supercharging my KA here lately but it has 10.5:1 CR pistons in it right now. ive heard how different thickness head gaskets can change CR and that got me to thinkin. now im sure i cant get a head gasket thick enough to lower the CR to a boostable amount, but would it be possible to put a metal spacer type deal in there and just put a gasket on either side. Kind of like the opposite of head shaving. Someone tell me if there is a reason this idea might go terribly wrong or some factor im not considering because it seems like it would work fine to me.
2_fast_240 is offline   Reply With Quote
Old 01-04-2007, 10:38 AM   #2
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
you could run boost on that compression ratio. I wouldnt want to do to much with out race fuel. would be intresting to see the numbers it would make.
A thicker head gasket wont changer your CR that much. It wouldn't probably get it under 10.0:1
KA-T_240 is offline   Reply With Quote
Old 01-04-2007, 10:51 AM   #3
2_fast_240
2_fast_240's Avatar
Dude, did you even read the post. i know a thicker head gasket wont change it much. Thats why im thinking about making some kind of metal spacer and putting a gasket on each side of the spacer.
Old 01-04-2007, 12:22 PM   #4
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
the spacer sounds like a bad idea. i doubt it would seal well. and with the amount of money involved you could probably buy another engine and swap it in and then sell yours at a profit. if i had an s13 and lived close to virginia, i'd be all over it.
not to mention the issues the thick head gasket would cause with cam timing and combustion chamber shape.
cdlong is offline   Reply With Quote
Old 01-04-2007, 01:38 PM   #5
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Suck it up and quit being a baby. People run boost on motors with higher compression then that. Super charge it mildly and be happy
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 01-04-2007, 08:56 PM   #6
2_fast_240
2_fast_240's Avatar
1)What would cause it to not seal well as long as the spacer was ground and perfectly flat/parallel.
2)This would cost me next to nothing since my dad owns a machine shop.
3)Exactly what issues would this cause with cam timing and combustion chamber shape, can someone elaborate on this. Because im not gonna attempt it if it will cause problems elsewhere.
4)What about this makes me a baby
5)If I were to supercharge it the way it is, would I be able to safely tune it with just a safc-2 and a lm-1
Old 01-04-2007, 09:01 PM   #7
Ninjabread
Ninjabread's Avatar
the problem is that with that spacer, you would be changing your cam specs and shit. no good.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 01-04-2007, 09:03 PM   #8
wootwoot
It will change the combustion chamber design and can make the squish area not as efficent. Can also mess with timing because of the new angles required and the extra length of belt. SCC did a thing on it not to long ago, look through some mags. They show the math so you can figure out if its bad or not
Old 01-04-2007, 09:08 PM   #9
johngriff
johngriff's Avatar
Worked on an AUDI TT that utilized 6 cyl with head spacer plate for lowered compression, and turbos.
It worked: Horribly
Blown gaskets out the mother fucking ass.
PLUS, PLUS PLUS
A Custom timing chain will have to be fasioned because of the differnece in height.
You can run a turbo with this compression ratio, just need good gas, and VERY good timing. Very good timing.
I hear EMS system calling your name.
[email protected]
Old 01-04-2007, 09:15 PM   #10
2_fast_240
2_fast_240's Avatar
To tell you the truth im a lot more interested in a supercharger than a turbo. If i were to run like 5 psi would I still need to get an EMS to adjust timing.
Old 01-04-2007, 09:20 PM   #11
bamaboy
bamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfection
if you are just going 5 psi then don't worry about dropping you compression ratio....you should be fine if that's as high as you want to go.
Right now you are my biggest fan. You are to me what a sex tape is to Paris Hilton, not the best publicity in the world, but at least I'm on people's mind and it has something to do with a pussy!!! HAAHAAAAAAA
bamaboy is offline   Reply With Quote
Old 01-04-2007, 09:26 PM   #12
2_fast_240
2_fast_240's Avatar
So your saying I will be fine running 5 psi and tuning it with just a safc-2 and lm-1. Or are you saying I will be fine as long as I get an EMS to tune it.
Old 01-04-2007, 10:33 PM   #13
johngriff
johngriff's Avatar
NO SAFC, you must have timing control.
You will be fine as long as you have an ems to tune it. SAFC-II = Destroyed timing map on ECCS nissan.
[email protected]
Old 01-04-2007, 11:12 PM   #14
cdlong
1)the answer to the first part of the question is in the second part of the question.
2)you would need new, possibly custom head bolts also. those would be fun to make
3)no expert on combustion chamber design, but as stated, it would reduce the quencing ability of the quench areas. i don't know how much that would harm the combustion process but in some engines it can kill any gains you hope to make in other areas. the SCC article referenced earlier was in the october '06 issue in the dear dave column. i can't find it on the website so head to your library, it's a good read. post up what you get on here, i'm curious now.
4)you are trying to half-ass something? i don't know, i didn't say it.
5)get a Bikirom, fuel and timing control and you can easily upgrade injectors, mafs, etc. and it's only like $450.
on a general note, 5 psi coming out of a non intercooled supercharger is a lot different than 5 psi out of a small turbo. some superchargers aren't too effecient and heat up the air a lot. no actual facts to offer you, just urguing you to research it some more.
Old 01-05-2007, 01:50 AM   #15
McRussellPants
run sand through your motor untill your rings and pistons are so bad your actual compression is 8.0:1
that or the head spacer, either are equally ghetto.
McRussellPants is offline   Reply With Quote
Old 01-05-2007, 07:10 AM   #16
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
if you can keep intake temps down and have timing control, that compression is probably alrite.
skatanic28 is offline   Reply With Quote
Old 01-05-2007, 11:19 AM   #17
johngriff
johngriff's Avatar
Ask Neme(evan) about biki rom
[email protected]
Old 01-05-2007, 02:22 PM   #18
cdlong
i've only heard good things about them, and i was about to buy one. searching through some of his posts it looks like he's haveing other issues with his car. for the price it's awesome, not everyone can afford a standalone.
Old 01-05-2007, 02:59 PM   #19
johngriff
johngriff's Avatar
yeah but paying for mistakes is even worse!
[email protected]
Old 01-05-2007, 03:17 PM   #20
S14DB
AFC #1
S14DB's Avatar
Standalone is cheaper than rebuilding the motor.
Old 01-05-2007, 03:28 PM   #21
cdlong
what would blow the motor, the tuning, or the quality/design of the Biki?
if it's the tuning, that's the owner/user's fault.
if it's the design, what is it missing?
like i said, i've heard only good things about the biki, the quality can't be bad across the board.
Old 01-05-2007, 05:08 PM   #22
johngriff
johngriff's Avatar
I am NOT a biki rom expert. NOT IN THE LEAST.
Evan was quite upset, and cant get his AFRs dialed in at all with it. He is going Haltech, once i make some majic happen for him.
You should really ask him the specifics.
[email protected]
Old 01-06-2007, 12:30 PM   #23
NemeGuero
No more nissan.
NemeGuero's Avatar
Biki is just hard to deal with. Tuning ISN'T real time so you're constantly making "guessing" changes and then re-uploading maps.
Sometimes the changes you make are beneficial, sometimes they aren't.
If you don't know ROM tuning or don't know someone who is willing to spend hours upon hours doing it for you $$$$$$$$, then don't get it.
BikiRom V3 (the latest software release) is terrible for self tuning. The display was much better in V1 and at least made it semi-doable for tuning.
I fixed the running issues with my car. It runs good now.. except my tune is still kinda rich, part throttle tune is all over the place, and I know I'm not extracting even close to all my engine's power potential.
You get what you pay for. And paying the hours to have someone tune your ROM for you equates buying a GOOD EMS and paying 3 hours to have it dialed in fuckin' PRO status.
I bet you've been waiting for me to say that, eh John? haha
