![]() I think my slave cylinder is going out if not out...cause I can't shift into any gears with out force. If im right, is it relatively easy to replace/fix?
(Im sure I dont have long b4 im not able to drive) its a daily driver thanks! |
^^^^^^^^^^don't forget to bleed, that is all, it's easy.
I got one from autozone for like 26$ there are KA Fsm's floating around here for download. get one, the slave is the exact same on the , same procedure to change |
The hardest part about changing the slave cylinder is bleeding it... do yourself a favor and remove that little bleeder block while you are it. It tends to trap air and makes bleeding the whole thing alot easier.
