Old 01-30-2007, 12:26 AM   #1
eerrrrr
eerrrrr's Avatar
eerrrrr will become famous soon enougheerrrrr will become famous soon enougheerrrrr will become famous soon enough
jic coilovers with camber plates
first off id like to know what kind these are. heres a pic.
ill have more, but my d-cam died on me.
also one of the front camber plates doesnt have that small knob to adjust something. its the thing right on top where u turn. i guess its for softness or hardness??? it clicks only 4 times left and right.
also one of the camber plates moves freely. r they supposed to be pretty stiff and not move on the coilovers? this is my first set of coilovers with camber plates.
eerrrrr is offline   Reply With Quote
Old 01-30-2007, 01:18 AM   #2
thepest
thepest's Avatar
thepest is on a distinguished road
Send a message via AIM to thepest
Looks like the jic FLT-A1. Search and tell me what you think.
thepest is offline   Reply With Quote
Old 01-30-2007, 03:40 AM   #3
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
isnt there an "identify this thread" somewhere around here
markyboi is offline   Reply With Quote
Old 01-30-2007, 05:04 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
yup, look like A1's to me too. That's not a 'camber plate' missing something, thats the damper adjustment. You might be able to adjust the damper by sticking something in there to turn the 'blade' lookin thing that actually goes into the shock, but it's iffy. I'd either run em how they are if none are blown, or ditch em for cheap.
Old 01-30-2007, 10:16 AM   #5
eerrrrr
eerrrrr's Avatar
cool. i got them cheap. theyre not blown or anything. i forgot about the IDENTIFY THIS THREAD. also i had other questions to ask. so is it still ok to use if the camber plate moves freely? or is there a way to tighten it up?
Old 01-30-2007, 01:40 PM   #6
GSXRJJordan
we must be looking at two seperate things... If the camber plate can move freely, then NO, you can't use em... it looked to me like the camber bolts were ok, and the adjuster on the right-most coilover was what was missing.
Old 01-30-2007, 05:20 PM   #7
eerrrrr
eerrrrr's Avatar
ill have a vid up of what im talking about soon. hopefully it will help.
Old 01-30-2007, 09:14 PM   #8
Gilboyto
Gilboyto is making a name for him/her selfGilboyto is making a name for him/her self
I just looked at my order and I had ordered FLT-A1's, but mine are inverted monotube ones with the adjustment on top...and have purple springs? Maybe mine are newer, weird.
Gilboyto is offline   Reply With Quote
Old 01-31-2007, 01:22 AM   #9
Crono562
Crono562's Avatar
Crono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of lightCrono562 is a glorious beacon of light
no hes not missing the dampening adjuster, the far right and far left are the front coilovers which can have their dampening adjusted from the bottom of the coilover, however it does like like u need to tighten the nut on the far right coilover, if look carefully at the far left you can see threads past the nut, but not so on the right, that could be why the camber plate is loose.
Mikey "Whitey" Ernst
'www.justdrift.com'
Crono562 is offline   Reply With Quote
Old 01-31-2007, 09:49 PM   #10
eerrrrr
eerrrrr's Avatar
heres a link to the vid. i just uploaded to youtube i dont think itll work right away....maybe in a couple of hours.
http://www.youtube.com/watch?v=VAFY9gk9wnA
Old 02-01-2007, 09:55 AM   #11
eerrrrr
eerrrrr's Avatar
Video Works Now!!!!!!!!!!!!!!!!!!!!
Old 02-01-2007, 10:37 AM   #12
S14DB
AFC #1
S14DB's Avatar
The Pillow ball is loose but usable.
Old 02-01-2007, 03:39 PM   #13
eerrrrr
eerrrrr's Avatar
how do i adjust that
Old 02-01-2007, 04:58 PM   #14
projectRDM
projectRDM's Avatar
It's a bearing, you can't adjust it.
Old 02-01-2007, 05:03 PM   #15
eerrrrr
eerrrrr's Avatar
so i cant really do anything to make it stable like the other one then? will this affect handling performance? if its safe to use, ill install tomorrow or sat.
Old 02-01-2007, 05:07 PM   #16
johngriff
johngriff's Avatar
You are getting moooar coil overs? let me know by p/ming me.
As far as the pillow ball, it is ok to use. It might make noise when braking/turning hard if its dying.
You can have them replaced by JIC in 562.
[email protected]
