Old 01-30-2007, 04:45 PM   #1
240sx2jz
240sx2jz's Avatar
240sx2jz is an unknown quantity at this point
Oxidizing Intercooler Help!!!
anyone know how to get rid of oxidation on an intercooler?? i have some oxidation on the endtanks but im not that worried about that, its more the tubes and fins im worried about. i was forced to drive it to work in a thin layer of snow (i think there was salt on the roads) last year and its been in storage but unfortunately the oxidation has continued. i need to stop it in its track before my greddy four row goes bye bye. any ideas??
Dane
240sx2jz is offline   Reply With Quote
Old 01-30-2007, 09:04 PM   #2
nuclearz
nuclearz is an unknown quantity at this point
Aluminum oxidation forms a protective layer of oxidation. Once it has formed it will stop. Not like Iron rust.
Just wash it off really good to get rid of the salt.
nuclearz is offline   Reply With Quote
Old 01-30-2007, 09:10 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
sand + paint?
Old 01-30-2007, 09:19 PM   #4
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
the fins? haha
Yeah just wash it off...it's something you have to deal with...
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 01-30-2007, 09:40 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
sand blast.. lol.. didn't read the fins was the problem
Old 01-30-2007, 10:32 PM   #6
180sx Fan
180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all
wouldnt a sand blaster bend the fuck out of the fins?
180sx Fan is offline   Reply With Quote
Old 01-30-2007, 11:43 PM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
Yeah probably.
Old 01-30-2007, 11:55 PM   #8
240sx2jz
240sx2jz's Avatar
nuclearz, didnt even think of that, i weld aluminum all the time, so i am aware of the super thin very hard and heat resistant oxidation layer . but im sure you guys have seen when aluminum sits for a while it gets the white spots on it?? i didnt know if there was some sort of chemical solution that would take that off. but thanks for the responses guys.
Old 01-31-2007, 12:54 AM   #9
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
get your shit anodized, will form a protective layer.
MegasquirtCA is offline   Reply With Quote
Old 01-31-2007, 07:40 AM   #10
nsany(atl)
nsany(atl) is an unknown quantity at this point
you can use a diluted acid that detail shops use, will make it nice and shiny, only downfall is it may leave streaks
'92 C-West Sil/80 SR ***SOLD***
'95 Track car
nsany(atl) is offline   Reply With Quote
Old 01-31-2007, 10:48 AM   #11
byhi
byhi's Avatar
byhi is an unknown quantity at this point
yes acid works, as well as using xylene (xytol alcohol)
or you could have it sand blasted, im sure that wouldnt hurt anything too much so long as you used a less abrasive material, just to sort of scuff the surface, then clear coat it!
byhi is offline   Reply With Quote
Old 01-31-2007, 11:08 AM   #12
axiomatik
axiomatik's Avatar
yeah, the oxidation is purely cosmetic, it won't corrode through like rust will. Anodizing is actually just oxidation with a few other materials mixed in, which is why it prevents oxidizing, it is already fully oxidized. I'm sure there are some chemicals that will clean it right off, but unless you do something to coat it, it will just naturally oxidize again.
Old 01-31-2007, 12:22 PM   #13
240sx2jz
240sx2jz's Avatar
ok thanks a lot guys, i think ill try the xylene, i got some kickin around from boostin the octane in my gas for some higher boost pulls .
Old 01-31-2007, 12:34 PM   #14
RightWheelDrive
RightWheelDrive is on a distinguished road
maybe you should try vinegar first. Vinegar+Salt if you want it stronger. Much cheaper. I haven't needed to try it yet but I hear it works. My water resource prof. told me they use that method to clean big machines and prevent build up in pipes.
RightWheelDrive is offline   Reply With Quote
Old 01-31-2007, 02:30 PM   #15
SANdisk
SANdisk's Avatar
SANdisk is an unknown quantity at this point
also a s.s. wire brush very genltly would do the trick.
SANdisk is offline   Reply With Quote
Old 02-01-2007, 08:38 AM   #16
MegasquirtCA
Also if you anodize your intercooler Black gives it a form of stealth, security, and protection to the environment. Getting a intercooler anodized the size of those on SSAC are around $80 to the whole intercooler. This wont affect the cooling characteristics as like mention before, anodizing oxidizes the aluminum and while its being oxidized they add a DYE which is whatever color you want and the DYE pretty much is soaks into the metal by the use of electricity which than seals it in. It adds a layer I believe about 0.003 of an inch.
