Old 02-02-2007, 06:10 AM   #1
samplesurf
samplesurf's Avatar
samplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to all
relocating maf near TB on sr?
alright so ive been looking through some mags lately and ive seen more than a few turbo g35s and 350zs and they still run their maf up there next to the throttle body in the pressurized piping, how is this possible and how does it affect driveability?it seems like it would be ok if u put the bov between the two... i can see this can be an advantage for us sr folks in situations like blowing off a coupler or somethin so u can still get somewhere u can fix it rather than being on the side of the freeway?also it would be able to more accurately measure volume and temp going directly into the motor, such as nitrous sprayed on the IC with the maf in the regular spot u may get a lean condition if u arent set up for it, but with the maf there it would be able to more accurately determine the fuel needed,.... any thoughts on this?
samplesurf is offline   Reply With Quote
Old 02-02-2007, 06:15 AM   #2
broken240sx
broken240sx is on the path to ruinbroken240sx is on the path to ruin
I think you are good to go with that...2 concerns
- blowby oil in your MAF
- z32 maf is plastic, may not be best boost piping at 30psi for example
drivability after a boost leak likely would be a huge advantage of that setup
broken240sx is offline   Reply With Quote
Old 02-02-2007, 06:28 AM   #3
samplesurf
samplesurf's Avatar
well shouldnt have any blowby as long as u have a catch can, and i do, also id only be boosting up to 20psi so it seems like it would work
Old 02-02-2007, 06:55 AM   #4
yokotas13
yokotas13's Avatar
search blowthrough
i had a post like a month ago on this stuff. good informatin in it!
yokotas13 is offline   Reply With Quote
Old 02-02-2007, 02:03 PM   #5
boost_it7
boost_it7 is making his/her stupidity well-knownboost_it7 is making his/her stupidity well-knownboost_it7 is making his/her stupidity well-known
Send a message via AIM to boost_it7
Yeah, it's called a blow-through MAF. Sport Compact Car magazine had some issues with this setup on their turbo Ford Focus. Somehow, the airflow meter was getting really eratic readings. It turned out that the scavenging effect that happens in the manifold was being detected by the MAF, so at certain RPMs the reading was inaccurate. They converted to a pull-through style MAF and the problem went away.
I don't think you would have the same problem as the Focus if you put the MAF in front of the intercooler, or at least further from the TB.
boost_it7 is offline   Reply With Quote
Old 02-03-2007, 06:11 AM   #6
GSXRJJordan
GSXRJJordan's Avatar
Ton's of hassle, as long as you're having to buy something, get a MAP-ECU and go the way REAL turbo cars do (as well as sportbikes), with a MAP sensor. Talk about worry free ~ plus no restrictions on airflow
Old 02-03-2007, 10:15 AM   #7
O3DigitalBath
O3DigitalBath's Avatar
O3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud of
Send a message via AIM to O3DigitalBath
more tuning is involved with MAP baised and its not quite as accurate (only measuring pressure rather than flow)...but they are a hell of a lot easier to work with and are WAY cheaper.
GM 3bars are like $26 new at the auto parts stores...MAF's...closer to like 2-3 hundred.
O3DigitalBath is offline   Reply With Quote
