KA-T Declaration of Specs THREAD
Hey guys, I just wanted to see who else in the world is KA-T. I'd love to know specs, Dyno results, thresholds, experiences, as well as see some pictures! This isnt meant to be a FAQ thread, but more of a "heres what im doing" thread
For instance. 1. posts specs/mods 2. post how long it has lasted 3. numbers you've made on the dyno 4. what and why it blew up (if applicable) 5. experiences, thoughts (pros, cons) 6. pics are always welcome i will start, because it would be lame if i didn't new setup for 2007 1. KA24DE block bored 0.040 thousandths over (just shy of 2.5 liters) - Wiseco 10.5:1 pistons - Cometic .060 (thicker than stock) Headgasket - Head QZ removed = lower displacement + quicker late combustion sweep - Effective compression = 10.1:1 - ARP head studs Studs - Micropolished crankshaft - complete head and valve overhaul (love starting fresh) - Custom MurphyBHP tubular Manifold - Cheapturbo.com garrett 50 trim turbo - JGS precision wastegate - JGS precision Motor mounts - Siemens 560 cc injectors - greddy fuel rail - greddy emanage - Fidanza Flywheel - Spec stage 3 clutch - V mount intercooler setup with blowthrough Z32 MAFS 2. This one is almost fully together, im super excited to tune it and get it out there. But ,my last setup was without an aftermarket headgasket, and blew the stock one at 12lbs.... .after 8 miles of driving,.... ouch, but i expected it. So i wasnt too mad. But this one should be good for 12 lbs (and thats beign careful since its a high compression boost motor. 3. No numbers yet, but with a full blown turbo power calculator and being very pecimistic about intercooler efficiency and a low duty cycly it said i should make 340 whp at around 5500 rpm, and 370 TQ at ...... 3500 rpm... wow 4. easy, it blew up because i got power hungry and i knew we were doing a full build for the 2007 season, so i had fun with it, no biggie 5. With my experiences are the common experiences with what everyone says. - the KA makes awesome torque but has some reliability issues whereas the Sr is a good motor too, and it is reliable, jsut not as powerful without a boost-hike or a turbo upgrade. - Also, the KA (for me) seemed liek the right choice as i have the minset that you should never give away displacement... sure we could argue about circuit cars etc etc, and im NOT a muscle car guy, i just saw the 2.4 as an advantage especially since the guy that im co-building with (learning new stuff everyday too, this kid can literally reassembly any nissan motor with not one ounce of help, its insane) has built several 500+ whp KA-T's (including his wifes) that have all been high compression turbo motors, and all have been blasts to see in action!! 6. look for a pics update in the next week, right now all i have are pics of the block and head, and other random finished parts, so i would love to wait until the motor is fully together to put up a pic or two for the fans, lol. also i will take a pic or two of the V-mount upon completion and maybe give them a post-up. anyhow, what else are others doing out there, share your experiences, im deffinately interested to know who else is doing what. thanks |
#4 | |
![]() Join Date: Jul 2005
there's something here |
Drifterella
Alright, I'll throw my setup for this year. This will be the second setup in the car.
-Wiseco 9:1 .020 over pistons -Pauter Rods -Head QZ removed -Ported Head -Cometic Headgasket (Stock thickness) -Supertech valve springs and retainers -ARP Studs -knife edged/polished crank -Custom exhaust manifold -Custom intake manifold (w/ velocity stacks) -Q45 Throttle Body -50mm ebay wastegate -ITS T4/T67 -Greddy Type R bov -1000cc injectors -Meth injection -Paxton external pump -Aeromotive regulator - -10an fuel lines - D21 Flywheels -300zx Clutchmaster Stage 5 Clutch -Autronic SMC standalone Theres more I'm sure, but thats all I feel like typing right now. |
#7 | |
Drifterella
I laughed at that too. Because 95% of the time its true. My first built motor lasted 462 miles. |
![]() ![]() Feedback Score: 1 reviews
Stock Motor
FP t3-t04e 60-1 AEM EMS 740cc Top Feed Injectors Top Feed Fuel Rail Stainless Steel Braided Fuel Lines Aeromotive AFPR Walbro 255lph Fuel pump Custom 2.5" Tig Welded Intercooler Piping Hybrid Intercooler 24X12X3 HKS SSQV BOV Tial 38mm Wastegate Custom Log Manifold 382hp 370tq tuned for e85. 2. Its been going strong for a couple months. It is my daily driver. |
![]() Join Date: Aug 2005
.040 over bore
Custom Ross forged pistons (garunteed up to 30psi)w/ rings and pins Stock rods, polished & resized with ARP bolts Mild P&P Clevite rod/main bearings Fel-pro gasket set ARP Head studs OEM timing chain kit 3 angle valve job Upgraded valve springs and valves Brass freeze plugs polished, cryotreated crank AMS GT32 JGS SOHC starter kit, treated with high temp powdercoat Turbo XS DTec FC Performance oil pump OEM water pump Heat treated tranny,flywheel bolts OEM IM/ Turbo manifold studs RPS streetmax clutch Resurfaced stock flywheel MSD BTM DW 650cc injectors Z32 MAF 255 lph fuel pump JGS custom tubular IM Nismo FPR JGS wastgate Greddy RS BOV JGS MMs Nismo tranny mount |
Stock ka24de, great compression
Cometic hg ARP headstuds Rebuilt Garret T25 SR370cc or 470's haven't decided Reinforced X02 manifold Divorced turbo elbow JGS oil line kit MSD SCI-L w/ 2 Step rev limiter Flex downpipe manual boost controller set at 10psi Aurora plug wires Warlboro 255 HKS SSQV Bov SR SMIC ACT 6 puck solid disc SPL aluminum subframe bushings Solid motor mounts Altima dual fans w/ stock radiator New waterpump/thermostat Basic tune up 2.75 inch exhaust Apexi SAFC went the "cheap" route. Should be getting around 220whp once everything is up and running. |
#12 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
ok i'll join in on this....
My Ka24det setup Engine 0.02 over bore JE Pistons 8.5:1 CR Crower Rods UR Crank Pulley Cosmetic HG ARP Headstuds Fel-pro Gasket set OEM timing chain kit Nismo Motor Mounts Magnacore Wires Agency Power Throttle Pulley Transmission Nismo Transmission Mount Centerforce Stage 2 Clutch Fidanza Lightweight Flywheel J30 VLSD Redline MT-90 Transmission Fluid Cooling Some OE Replacement Radiator Perm-a-cool Electric Fan Nismo Thermostat Nismo Radiator Cap Redline Water Wetter Ebay FMIC Turbo/Exhaust GT28R From a s15 dual BB turbo SSAC Manifold (Cracked)-getting a JGY.CC one next HKS Hi-Power Exhaust 80mm Project Nissan Test Pipe Nismo Exhaust Hangers Greddy MX Downpipe Greddy Turbo Outlet Greddy Type-S BOV Z32 MAF Custom Piping Stainless Steel oil/water lines AEM Dry Flow Filter Fuel/Tuning A'pexi Safc II SR 370cc Injectors Nismo FPR Walbro 255LPH Fuel Pump Innovative Wideband Z32 Fuel Filter Misc. Autometer Oil Pressure Gauge Autometer Boost Gauge Greddy Oil Catch Can With this setup i made 253hp like 3 months ago, but atm im running NA because of the cracked manifold.
Slip Gypsies Blog Quote:
![]() ![]() ![]() Feedback Score: 1 reviews
stock fuel pump
stock block 103k 370cc jgs full turbo kit, intercooler and pipes. t3t04 aem ems aem 3 bar map gm ait 240hp 247tq at 8psi on 92 pump tuned by me |
#14 |
stock block-165k when turbo .. only drive it for 4k miles so far
t3/t4 .82-8psi ssac mani cuztom outlet trust dp custom ebay fmic/piping 550cc safc aem uego r33 fp n60 maf |
#15 |
![]() Join Date: Sep 2006
People posting specs, please fill out the rest...knowing your feedback, thoughts, and how durable your motor is/was is MUCH more important to me than knowing you ran a NISMO mount.
loading HATERS.....99% ███████████████] |
#16 |
T25 off a Blacktop
370 Injectors Xo2 Manifold Ebay intercooler and piping SAFC II Walbro Fuel Pump JGS Oil Line Kit Autometer Boost and Oil Pressure gauges Cant decide which BOV to use. Not sure what elbow, DP or exhaust ill buy yet either. The basic cheap 200hp build. |
#17 |
well, ill post mine, even though im still in the process (waiting for the block)
I have an AMS Shortblock KA24de All necessary machine work on block Clevite Main and Rod Bearings Arias 8.8:1 .020" over pistons AMS/Turbo240 Sportsman Series Rods Full motor Fel-Pro gasket and seal set Cleaned/milled head (*may decide to do other headwork) ARP main/head studs Nismo motormounts Lightened stock flywheel Spec stage 3 370cc injectors (for now) z32 maf (true, not knockoff) Garret t3/t4 hybrid .63 custom log mani ebay IC 3" inlet and outlet + custom piping *walboro 255lph fuel pump and nismo fpr *jgy 38mm wastegate *jgy bov *engine management still not decided *=still need to purchase |
#18 | |
Trader Rating: (31)
2. mine has lasted about 3 months so far, although i didnt blow my motor but just craked the manifold, so watch for that...
3. as posted before i made 253hp 4. cracked the manifold because my downpipe doesnt have any flex piping on it and the manifold design is shitty 5. I really love my setup, since it runs and pulls like it came from the factory like this...
#19 |
![]() Join Date: Sep 2004
My KA24DET (motor was sold a long time ago)
Stock 91 KA24DE 102,XXX miles SSAC Manifold T04E home made 2 inch IC piping SR 370cc injectors E-bay intercooler XS BOV (crap) 2.5 inch turbo back (crap) Misc. J30 LSD 6 Puck clutch Nex coilovers I loved it very fun, needed tuning but still beat S2000's, G35's & Z's. When motor and tranny was sold the guy that bought it loved it and said it made 208whp when he had in dynoed, im not sure what he had done to it last i heard its still running strong and this was about a year ago. |
#20 |
![]() Join Date: Oct 2006
Trader Rating: (26)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 26 reviews
95 ka24de 120k
ssac manifold t3 super60 jgs oil lines 2.5 ic pipeing ebay fmic dsm bov custom dp safcII msd btm wideband n60 maf im just about done with the build and im going to dyno it soon if this thread is still going ill post it on here with video. |
#21 | ||
what in the hell?
wow, do some more research. btw, before you start flaming, i have parts in my room ready to be assembled.. paycheck by paycheck. |
#22 | |
OMG you're right, what am i thinking, damn, i guess i shoulda done some research..... poor me... making 370 ft lbs of torque at 3500 rpm at 11 lbs of boost.... man, where did i go wrong... also, the final compression was not reached by the ehadgasket alone, if you re-read, we removed the quench-zone and bored it to lower it as well |
#23 | |
![]() Join Date: May 2003
2) +3years at 12psi, over 20,000 miles so far...75% of those miles on the track, the other 25% on the drive(s) to the track. 3) 310rwhp at 12psi 4) Started with a non-intercooled setup at ~6psi, and I was using a JWT N/A tuned ECU with WAY too much timing advance built in...lasted 2 weeks. 5) Do it right the first time...and T25's don't belong on a KA. T3 or larger, please. 6) See website (sig) for pics and dyno charts, etc... - Brian
www.KA24DEvelopment.com |
#24 | |
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
2. Almost 6 months now and roughly 4,000 miles 3. yev yet to put it on a dyno 4. still running 5. boosting this motor brought the ka to life. This is my second turbo car and so far im loving every second of it. Just don't cut corners and do everything right the first time and it will save you so much cash. 6. ![]() ![]()
92 Hatch, KA-T, T28, 12 PSI, FMIC, 3" TBE, EFI ECU, 440cc Inj, And more... |
#25 |
![]() Join Date: Jun 2005
I am thinking of going KA T and I just put a re-conditioned motor a 1000 mimles ago so its like rebuilt. What do you think about running 6 psi intercooled? whats the longevity on that you think roughly?
#26 | |
Drifterella
![]() Here is the new setup in progress. (Being mocked up with old blown motor) ![]() |
#27 |
![]() Join Date: Aug 2003
1. posts specs/mods
-Stock motor at 40k miles -GT28RS @ 7lbs -Top Speed Manifold -z32TT fuel pump -stock MAF -SR 370CC injectors -FMIC -K&N Cone filter -SilkRoad 3in turbo elbow -Custom 3inch downpipe, but the end flange appears to be 2.25in -3in RSR catback -SAFCII with automatic ECU for now. Gettin the JWT ECU tuned at the moment 2. post how long it has lasted ~1000 miles so far. been to the drag strip: Ran 13.8 on 1/4 mile. went to an autoX event and it held up ok as well. Track time coming up Feb24/25. We'll see how it holds up. 3. numbers you've made on the dyno http://home.myuw.net/gmakx/pics/Silv...A-T%20dyno.jpg 4. what and why it blew up (if applicable) hasn't blown up yet. 5. experiences, thoughts (pros, cons) My only complaint is coming from NA KA, I've noticed it is harder to feather the throttle when coming around the corners. I was told to recirc the BOV and it should be much better.
![]() Last edited by NinjaGaiden; 02-08-2007 at 03:51 PM.. |
#28 |
No more nissan.
![]() Join Date: Jan 2003
Ok, ok.. Mine...
1. t3/t4 .50trim .63a/r Garrette tial 35mm wastegate ETD racing top mount tubular manifold cometic metal head gasket Starion-conquest FMIC Z32 MAFS 555cc Deatschwerkstershalgin Injectors Walboro 255lph fuel pump Z32 fuel filter HKS SSQV 3" exhaust, catco cat, resonator and Magnaflow muffler 2. still lasting (2 years of shitty ass tunes and random ass problems) 3. Never hit the dyno 4. Hasn't blown up 5. Fuckin' love it. Its FFAASSTT. Too much IC piping.. needs better management. I'm re-doing it once I have enough money to replace aforementioned parts. 6. check vB gallery.
#29 | |
![]() Join Date: Apr 2006
...sounds like he did but you need to do yours. there was a guy back in 2004 on honda-tech with a 11.5:1 with a gt2871r running like 18lbs with ITB's on it. There is nothing wrong with a lil compression on a boost motor, its when you put slack in the tuning you get problems. Lower compression just gives you more buffer room for error in your tuning. I see lots of built KA-t's with lil to no tuning and they wonder why they had problems... ![]() |
#30 | |
1. Bo0st Design's old turbo kit(bought from a friend), t3/to4e garret .57trim 60a/r(something like that)
2.25" fmic piping(bo0st designs) piping with greddy core tial 38mm wg with 8lb spring safc2(street tuned using zeitronix wideband/datalogger) retarded base timing 16* walbro 255lph deatschwerks 480cc injectors 1g dsm bov recirctulated z32 maf z32 fuel filter Ebay xtd stage 3 clutch 2. 28k mile motor was installed summer of 06, then the turbo went on Dec of 06. Still running strong with no problems... 3. dynoed when the mainfold had 2 cracks, i made 217whp and 235trq 4. no explosion 5. love the power, feel, handle, and outcome...cant complain 6. pics are always welcome ![]() ^^crack 1^^ ![]() ^^crack 2^^ thankgod i got them welded...feels so0 much better! ![]() ![]() ![]() ![]() ^^pic from dec 06^^ still looks the same...besides the added koyo and a yr's worth of dirt 7. 1/4 times(with fixed manifold)- took it to the track last saturday, ran 3 times 1st run 60ft- 2.557 1/4- 14.743 mph- 102.35 2nd run 60ft- 2.195 1/4- 13.740 mph- 103.60 3rd run 60ft- 2.223 1/4- 13.744 mph- 104.77 keep in mind, this is on full coilover supension, with almost all after market adjustable arms and rear drift wheels/tires 225/45/17 feddy ss595 Quote:
duh mah! wheels and suspension! Last edited by AzNCmB; 02-10-2007 at 10:41 AM.. |
