Old 02-06-2007, 11:22 AM   #1
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
how to bleed a sr20det clutch.
does any know how to bleed the clutch for an sr tranny. i need to do it because my clutch isnt hard. every time i press the clutch it goes down quick and it stays on the floor. i have to bring it up with my foot. it doesnt come up by it self. does any one know a website with pics or info. thanks lmk
grnappletree14 is offline   Reply With Quote
Old 02-06-2007, 11:29 AM   #2
vqboodah
vqboodah's Avatar
vqboodah is on a distinguished road
you bleed it just like how you bleed a brake pedal. bleed it right at the slave cylinder on the tranny.
vqboodah is offline   Reply With Quote
Old 02-06-2007, 11:36 AM   #3
Gramentz
Gramentz's Avatar
Gramentz is making a name for him/her selfGramentz is making a name for him/her self
Pump the clutch a few times and hold it to the floor. Unscrew the bleeder on the slave cylinder. Wait for brake fluid to come out, tighten bleeder. Repeat procedure until all of the air is out of the line. Top off the fluid.
Fully Built
Gramentz is offline   Reply With Quote
Old 02-06-2007, 12:24 PM   #4
twofourzerosx
twofourzerosx can only hope to improve
the trick is to never disconnect the slave cylinder, simply unbolt it from the trani next time you pull the motor... then you never have to bleed it again
twofourzerosx is offline   Reply With Quote
Old 02-06-2007, 03:14 PM   #5
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
Search. and Check the FSM.
I gravity bled mine because I was alone. Just fit a clear home depot line over the screw nipple, turn it, and keep adding fluid to the resevoir until all the bubbles stop comming out.
ive heard it takes a while if you have the clutch damper in. I removed mine when I bled the clutch so it only took about 10 minutes to bleed the whole thing.
look for a Clutch damper delete DIY thread on zilvia or something. I know there are some out there.
itll tell u how to bleed it in the same thread.
redsuns3838 is offline   Reply With Quote
Old 02-06-2007, 03:41 PM   #6
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
speed bleeders. i saved my mom from having to pump my stage 2 for me.
DoriftoPnoy is offline   Reply With Quote
