Old 02-04-2007, 02:50 AM   #1
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
so my windshield wipers just started going off...
so tonight i was driving down the road with a friend and my windshield wipers started going off all the sudden. i thought my friend hit the switch, but as it turns out, something is messed up. i disconnected the harness and unscrewed the lever mechanism from the steering columb and it the stopped. does that mean the lever/switch mechanism is broken? im going to try cleaning it out, anyone have any advice?
thanks,
Greg
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 02-04-2007, 02:54 AM   #2
McRussellPants
240SX windshield wipers are lame like that.
I took mine out and use Rain-x
McRussellPants is offline   Reply With Quote
Old 02-04-2007, 02:55 AM   #3
EJ253
EJ253's Avatar
how could i fix it tho?
Secret Society
Old 02-04-2007, 03:32 AM   #4
xxslidewaysxx
xxslidewaysxx is an unknown quantity at this point
Send a message via AIM to xxslidewaysxx
if they started going all crazy like when you accelerate or rev, check your alternator fuse
xxslidewaysxx is offline   Reply With Quote
Old 02-04-2007, 03:49 AM   #5
EJ253
EJ253's Avatar
they just started going as if i switched them on the lower setting, they dont pause inbetween, just a slow steady "back and forth"
ill check the fuse in the morning. its almost 4am.
thanks,
Greg
Old 02-04-2007, 05:20 PM   #6
Irukandji
Wiper amp possibly?
Irukandji is offline   Reply With Quote
Old 02-04-2007, 06:10 PM   #7
ms!3
welcome to the club
ms!3 is offline   Reply With Quote
Old 02-05-2007, 10:55 PM   #8
EJ253
EJ253's Avatar
damn it. thats gay. i tryied cleaning it out with canned air. didnt help.
dealership. tomorrow.
Old 02-06-2007, 12:28 AM   #9
sebazztard
sebazztard is an unknown quantity at this point
ha that happened to me. i thought it was really odd at the time. what i did for the meantime was i took a blown fuse, attachted wires to both ends, stuck them in the fuse panel for the wipers and routed the wires to sit in my door panel with one end attached to good fuse and i just stuck the wire on the other side when i needed to use the wipers. i kept it like that for a few months, and just for the hell of it i tried putting a new fuse back in the panel and i never had a problem with it since. worked for me.
sebazztard is offline   Reply With Quote
Old 02-06-2007, 07:05 AM   #10
jdm_eg6
jdm_eg6's Avatar
jdm_eg6 is an unknown quantity at this point
had the same problem happen to me. it was the wiper switch. i think it was like 60 bucks from nissan. if you want, you can pull out the fuse in the kick panel. but its also the fuse for your radio. i was rolling around with no radio for a bit. no radio > people thinking i'm crazy trying to whipe dry glass.
edit- this is my bro's username.
jdm_eg6 is offline   Reply With Quote
Old 02-06-2007, 04:36 PM   #11
sw20>>s14
sw20>>s14's Avatar
same thing happened to me at the track! haha...its the windshield wiper amp...i got mine from R240NA for cheap and last time i checked he has a lot lying around...save yourself some money for something so miniscule...they are model specific though...i forgot which ones for which, but russ should be able to clarify for you...
sw20>>s14 is offline   Reply With Quote
Old 02-06-2007, 10:05 PM   #12
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Do you have lowering springs or coilovers? If so, your passenger side fender harness might be rubbing. My car has all kinds of crazy electrical problems thanks to my fender harnesses, I'm relocating them to the engine bay tomorrow.
Old 02-06-2007, 10:31 PM   #13
Shadytrixta1
Shadytrixta1 is on the path to ruinShadytrixta1 is on the path to ruinShadytrixta1 is on the path to ruin
Mine did the same thing, but if I put it all the way down to the fast wipe postition they stay off.Hopefully its just the stalk/switch.
Shadytrixta1 is offline   Reply With Quote
Old 02-06-2007, 10:48 PM   #14
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
happened to me after i washed my engine bay, i undid the amp and there was water inside, so i dried off, blew on it to get any dust and stuff out, and it hasnt done it since. but my wipers havent worked perfect since my Sr swap so who knows exactly what it is
redsuns3838 is offline   Reply With Quote
Old 02-06-2007, 11:14 PM   #15
EJ253
EJ253's Avatar
i just got my engine bay washed too!
can you please post a picture of where the "wiper amp" is. i dont know where it is. or please give a detailed description of where it would be.
also, can someone post a picture of which fuse is which next to the kick panel? a pic of the fusebox cover for the kickpanel would be great too
thank you,
Greg
