REDTOP vs REDTOP
So I found out that there is 2 type of redtops. the only difference is the head as far as I can see. So is the newer redtop with the cooling fins better by far then the older one?
#3 | |
![]() Join Date: Mar 2002
just an age difference, that's all. You'll never notice it.
1993, Russ.
lol.. its not possible for people to know about this back in 1991... seeing as how the S13 blacktop sr didnt come out till what.. 96? something like that. but yes. to the original poster. get the third version of the redtop instead, it is the best one. came with 275hp and 300ft/lb of torque stock and was endurance tested at the nissan factory and it was able to maintain a steady 8000rpm for 10 hours straight without any catastrophic failure. it is marked by cooling fins that are slightly slanted to the right on the head of the motor, and a red valve cover that has a slight tinge of orange in it hope this helps ![]() |
#6 | |
#7 | |
![]() Join Date: Apr 2002
/sarcasm is this for real? All the S13 redtops are pretty much the same, minor differences and of course, as MrMeph mentioned, really the biggest factor is age.
89 S13 hatch/////98 Subaru 2.5RS |
#8 | |
#9 | |
this has all 4 versions of the SR and the differences etc http://srownersclub.com/jdm_engines.asp and here is a useful thread full of info and links etc http://www.zilvia.net/f/showthread.php?t=62607
#10 | |
There is a slight discrepancy in port hieght from inlet to valve seat on the Finned Late model heads and the Unfinned heads. The unfinned heads are just IMO. But for some reason the Built motor im doing it finned. The un-finned head is longer ports barely or some crap. I could be talking out of my ass. The Black top s13 is lower port and the VTC heads are the shortest.
Like Me on FaceBook ![]() |
#14 |
OK, does anyone have actual specs? I mean everyone has different info about them, but all and all the finned one is newer so it would be a better buy fo rthe same price. right?
#15 |
Paint the finned redtop valve cover black, and resell it to some newb as a blacktop . . .
. . . any way to tell if this has happened (besides fresh paint on the valve cover)? No sense getting scammed - any dates/numbers to check on the motor itself? |
#16 | |
#17 |
i'd just get the newest one, type x black top, lower mileage, the ecu can also tell you what year unless someone decides to fvck with the harness to run different ecus which does happen
or just rebuild any old redtop, and you won't have to worry if it comes with fins or not |
#18 |
you can also tell the o2 sensor. Skinny= redtops Fat= blacktops... Although I have a fat o2 sensor and it has a red valve cover. I should check the ecu sometime to what it really is...not that it matters to me.
#19 | |
