Old 02-10-2007, 12:38 PM   #1
ZenkitonS14
ZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfection
Uncaptive/Drooping Springs
All of you super slammed guys. How many of you guys on coilovers are drooping your rear springs. How long have you been on that setup and If you 3 wheel up driveways and the spring gets loose is it safe? My ride height is maxed out and its still not low enough. My only option now is to droop
On S14 btw
Email
Jake@optionimports.com
[email protected]
Tel: 626-581-7200
Fax: 626-330-3155
275 S 3rd Ave. #2
La Puente, CA 91746
ZenkitonS14 is offline   Reply With Quote
Old 02-10-2007, 12:59 PM   #2
Duzzes_Wild
Duzzes_Wild can only hope to improve
drooping, wth is drooping it doesnt sound safe, if you mean preloading the spring , it is relatively safe
Duzzes_Wild is offline   Reply With Quote
Old 02-10-2007, 01:54 PM   #3
ZenkitonS14
^^^NOT preloading the spring. Im like 1/2 an inch uncaptive. Seems fine to me. I just want to know how many other people are doing this too.
Email
[email protected]
Tel: 626-581-7200
Fax: 626-330-3155
275 S 3rd Ave. #2
La Puente, CA 91746
Old 02-10-2007, 03:01 PM   #4
S14DB
AFC #1
S14DB's Avatar
What coils? You have no height adjustment I assume.
Old 02-10-2007, 04:32 PM   #5
McRussellPants
KTS have been cooking on an inch of droop for about 2 months now.
when they shit their pants Im just gonna get Z32 front replacement shocks.
McRussellPants is offline   Reply With Quote
Old 02-10-2007, 06:04 PM   #6
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
What is the advantage of the Z32 front shocks?
Oh, I'm also on KTS with about 1/2in of droop in the rear for a little over a year now. No problems so far
DRFT180 is offline   Reply With Quote
Old 02-10-2007, 06:07 PM   #7
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
wtf is "droop"???
gotta240 is offline   Reply With Quote
Old 02-10-2007, 07:00 PM   #8
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Do you mean that the spring does not touch the upper mount? That's bad for the coilover and will shorten its life, move the collars that the springs sit on higher.
What are the benefits to Z32 shocks? I'm guessing they sit lower, but why go from coilovers to Z32 shocks?
Old 02-10-2007, 07:23 PM   #9
ZenkitonS14
[QUOTE=Matej]Do you mean that the spring does not touch the upper mount? That's bad for the coilover and will shorten its life, move the collars that the springs sit on higher.
yes, when the car is up in the air the spring is loose. Mine dont really have much room to move from side to side but u can woble them by hand when the car is jacked up in the rear.
[QUOTE=Matej]What coils? You have no height adjustment I assume.
Megan street. Yes, they are height adjustable, but the body adjustments lowest setting isnt low enough for me.
Email
[email protected]
Tel: 626-581-7200
Fax: 626-330-3155
275 S 3rd Ave. #2
La Puente, CA 91746
Old 02-10-2007, 07:54 PM   #10
Matej
Trader Rating: (39)
When you installed them, did you leave the springs at the factory height, or did you adjust them? I have Megan Streets as well. The spring height comes pre-adjusted to the optimum setting from the factory, so I didn't change it. I only adjusted the body height to go as low as possible, and I also took out the bottom collars, now I scrape ground everywhere. I'm not sure how big the difference for S14's is though.
Old 02-10-2007, 07:55 PM   #11
seekanddestroy
seekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choices
Not having preload on them is fine as long as its not a rally car, they will pop right back in their perches without damage when you lift a wheel in a driveway, etc. Most cars actually don't have height adjustable coilovers readily available, so no preload is common on a lot of coilovers that have shorter springs when you lower the car more.
seekanddestroy is offline   Reply With Quote
Old 02-10-2007, 08:04 PM   #12
ZenkitonS14
At first I didnt touch the preload, but after I maxed out the ride height, it still was too high. You took out rear collars?
Mine arent drooped THAT much(maybe like 3/4" at the most, they barely woble, Theyre not TOO loose. Theres some guys that run like 2" uncaptive!!!
Email
[email protected]
Tel: 626-581-7200
Fax: 626-330-3155
275 S 3rd Ave. #2
La Puente, CA 91746
Old 02-10-2007, 08:04 PM   #13
seekanddestroy
If you are REALLY worried about it, simply get some longer springs.. this will let you lower the preload perch, and still be able to put preload on the spring.
You can get new springs from Eibach.
Old 02-10-2007, 08:08 PM   #14
Matej
Trader Rating: (39)
If it's still not low enough after you remove the bottom collars, all you can do is preload the springs, which will also take care of your drooping problem.
Old 02-10-2007, 08:10 PM   #15
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
That defeats the whole purpose of wanting to go lower.
Nizzan4u2nv is offline   Reply With Quote
Old 02-10-2007, 08:12 PM   #16
Nizzan4u2nv
Cant do that for the rear of s14. That doesnt give any adjustment, and nothing will hold the spring up. That will work for the front though.
Old 02-10-2007, 08:18 PM   #17
seekanddestroy
Yeah, my bad... got confused there for a sec. You would have to have the shock shafts shortened.
Old 02-10-2007, 08:24 PM   #18
Matej
Trader Rating: (39)
Sorry, I assumed they were pretty much the same as the S13 ones, I apologize.
