Old 02-12-2007, 06:15 AM   #1
jakal
jakal's Avatar
jakal is on a distinguished road
How do you install a Driver Side Window on s14????
okay, i just bought a window for my 95 s14....it should come i hope, but i was wondering how the hell do you install a driver side window??? anyone know how to?? it would be much appreciated and i would save 150.00......thanks in advance!
body: 1995 240sx NON SE (meaning 4 Lugs, NO LSD)
jakal is offline   Reply With Quote
Old 02-12-2007, 10:03 AM   #2
projectRDM
projectRDM's Avatar
Two M6 nuts on the bottom of the glass. There's a stop at each side on top of the door you might need to adjust, otherwise if you can't do it by just looking at it you need to find another hobby. It's simple.
Old 02-12-2007, 10:38 AM   #3
contranication
contranication's Avatar
contranication is an unknown quantity at this point
Send a message via AIM to contranication Send a message via Yahoo to contranication
It also helps to move the window up and down so you can line up the regulator with the holes in the door to tighten the nuts... besides that you might need someone to hold the window for you
contranication is offline   Reply With Quote
Old 02-12-2007, 11:01 AM   #4
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
It's simple. ( I have an S13 so it may vary)
-Remove the door panel, it has a screw in the handle, and possibly another under a cover near the door jam
-Remove the plastic film with the white shit all over it
-Move the window up a little to reach the 10mm bolts holding it to the track
-Unbolt them and tilt window forward to pull up and out of the door
-Make sure to align the window in the guides on the sides and try not to scratch it, and don't overtighten the bolts
-Then do it all in reverse and you should be kosher. Like I said I have an S13 so it may be a little different but if you have some mechanical knowledge you should be fine. GL and if you have any questions just ask. Peace
SDS13COUPE is offline   Reply With Quote
