Old 02-12-2007, 07:46 PM   #1
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Is This Bad?
Background Info:
No shit, there I was waiting in line at the automatic carwash on post. Unfortunately, a dozen other apparently had the same idea.
So, after the umpteen minutes I'm finally done with the car wash I notice that my temp gauge has just gone through the roof.
I pull into one of the manual car wash stalls and check under the hood to see what the problem is. At the same time I follow all the standard over-heating procedures (turn the heater to hot on the highest settings, etc.) Additionally, I try spraying down the inside of the engine bay with water in the hopes of dissapating some of the heat. I turn off the engine and continue spraying.
Let it cool down for a few minutes and try to start her up. NOTHING! Try again. Again nothing. I figure I must fried something when I was spraying down the engine bay.
So I tow my car back to my apartment and check the engine bay the next day to see what's up.
Problem #1: Electrical connection from fan to fan relay was loose and came undone. That explains the overheating.
Problem #2: Somehow the timing got all jacked up. So I pull the CAS and after a million tries I finally fire up the engine only to see cloud of white smoke envelope me and the car. AWESOME!
So, tomorrow I'm gonna a do a compression test (although I don't know if I dare run the car up to operating temperature) to see if I'm looking at "just" a head gasket or if I need to install new piston rings also.
Fuck.
HalveBlue is offline   Reply With Quote
Old 02-12-2007, 07:47 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Not if you're Spy Hunter.
Head Gasket FTL.
Old 02-12-2007, 07:48 PM   #3
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
i would say blown hg
benefitx is offline   Reply With Quote
Old 02-12-2007, 07:50 PM   #4
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
You have one of two things...
blown hg, or bad ring. White is water, blue is smoke.
How does your oil/coolant look? If either one is fucked, STOP RUNNING IT.
gotta240 is offline   Reply With Quote
Old 02-12-2007, 08:17 PM   #5
kleenS14
kleenS14's Avatar
kleenS14 is an unknown quantity at this point
Def. looks like a good ol' busted head gasket. Have fun!
kleenS14 is offline   Reply With Quote
Old 02-12-2007, 08:25 PM   #6
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
just cross your fingers and hope its just a piston ring....
swayray is offline   Reply With Quote
Old 02-12-2007, 08:25 PM   #7
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
..........blue and whie smoke.
s13gold is offline   Reply With Quote
Old 02-12-2007, 08:38 PM   #8
iiEddieGii
iiEddieGii is a well-known jackass
Send a message via AIM to iiEddieGii
Does the white smoke smell more like steam or fuel?
Even though I doubt it's the problem, a stuck fuel injector could also be possible.
Did you run the car hot recently? That could also be a sign of a blown hg.
iiEddieGii is offline   Reply With Quote
Old 02-12-2007, 09:13 PM   #9
Team Rootbeer
Team Rootbeer's Avatar
Team Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really nice
Send a message via AIM to Team Rootbeer
could also be blown turbo oil seal.
my car does the same thing, but stops when i start driving it, or it warms up just a bit. been doing it forever. i think its my turbo, as my coolant and oil both look fine. also hear it could be exh valve guides/seats.
Originally Posted by hotrodv
90% of the cars posted here are stock or with original rims painted black
I'm not an asshole but is the true..
Team Rootbeer is offline   Reply With Quote
Old 02-12-2007, 09:19 PM   #10
SSC299
SSC299's Avatar
SSC299 is an unknown quantity at this point
Send a message via AIM to SSC299
I would say hg with that smoke.... but would it be running that smoothly?
SSC299 is offline   Reply With Quote
Old 02-12-2007, 09:19 PM   #11
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
why would you spray/hose down your engine bay with water?
why didnt you just turn the car off to prevent more heat?
markyboi is offline   Reply With Quote
Old 02-12-2007, 09:29 PM   #12
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Hot engine + Cold (or just not so hot) water = Bad news. Being that you did that, and pending what exactly you sprayed, you could be looking at simply a HG, or a ring or two... to something as serious as a warped/cracked head, or a crack in the block itself. My dad told me to NEVER spray a hot motor with colder water for that reason.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 02-12-2007, 09:34 PM   #13
Team Rootbeer
so did you look at your oil/coolant yet?
is the oil milky looking?
Old 02-12-2007, 09:35 PM   #14
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
^^----absolutely correct heat transfer is bad bad news on an aluminum head...
Landers is offline   Reply With Quote
Old 02-12-2007, 09:37 PM   #15
snappy
snappy's Avatar
snappy is an unknown quantity at this point
Blown HG for sure same thing happen to me, then a week later my car was hella chuggin. It would barely start.
Originally Posted by holemilk00 View Post
Its a 98 LE (leather edition)
snappy is offline   Reply With Quote
Old 02-12-2007, 10:18 PM   #16
HalveBlue
HalveBlue's Avatar
I didn't turn the car off because you're not supposed to turn it off immediately. Besides, I needed to get the car out of the car wash. I turned the car off after I realized the e-fan wasn't working properly.
This all happened within a matter of 30-60 seconds after I realized what was going on.
You got me on the water part though. Didn't think that one through at the time. Very stupid move on my part in retrospect.
Tomorrow I'll check the fluids and compression (unless there's another blizzard moving in).
Old 02-13-2007, 12:19 AM   #17
spiker
spiker has a little shameless behavior in the past
<- thats where my money is at from u spraying the water
spiker is offline   Reply With Quote
Old 02-13-2007, 04:39 AM   #18
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
if theres coolent in your oil, oil in your coolent, or your coolent smells like gas its headgasket.
Parking lot pimping
JDMClifford is offline   Reply With Quote
