Old 02-13-2007, 05:34 PM   #1
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
wiring problem
hey, ill go straight to my problem. I was replacing my injectors and when i finished, i drove it and it was fine, no more leaking gas. The next day, i drove it to the post office and it was fine but the next time i started it, there was nothing. The interior electricals still work but the engine wont crank.
I tried to jump start it but still nothing. I measured the battery voltage and its at 12.5 volts and like 14 something when i have the jumper cables connected but it still wont crank. I then look more closely and found that i left a screwdriver on the fuse box and it fell between the harness and alternator.
Now im thinking the screwdriver touched a terminal on the alternator and grounded itself out and i blew a fuse. I check the fuses and they all seem fine. I search the forums and find people talking about fusible links and a 100A fuse.
Im thinking the fusible links are the things connected right off the positive terminal. Someone tell me if they are. And I cant find the 100A fuse. I look in the fuse/relay box by the battery and the highest is a 75A. Someone help!
undesiredshoe is offline   Reply With Quote
Old 02-13-2007, 05:35 PM   #2
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
take off the terminals and check out your wires.
s13gold is offline   Reply With Quote
